KERNEL_PY Namespace Reference
namespace  batchmode_salome
namespace  Help
namespace  iparameters
namespace  kernel
namespace  kernel_test
namespace  omnipatch
namespace  PyInterp
namespace  salome_ComponentGUI
namespace  salome_genericobj
namespace  salome_iapp
namespace  salome_kernel
namespace  salome_notebook
namespace  salome_psutil
namespace  salome_pynode
namespace  salome_study
namespace  salome_test
namespace  salome_version
class  Barrier
class  ContainerLauncherCM
class  LockGuardCM
class  LogManagerLaunchMonitoringFileCtxMgr
class  SessionContextManager
def extend_path (pname)
def standalone ()
def withServers ()
def salome_init (path=None, embedded=False, iorfakensfile=None, forced=False)
def salome_init_without_session_common (path=None, embedded=False)
def salome_init_without_session (path=None, embedded=False, iorfakensfile=None)
def salome_init_without_session_attached (path=None, embedded=False)
def salome_init_with_session (path=None, embedded=False)
def salome_close ()
def salome_NS ()
def salome_walk_on_containers (ns, root)
def salome_shutdown_containers_with_session ()
def retrieve_containers_in_ns ()
def get_all_containers ()
def salome_shutdown_containers_without_session ()
def salome_shutdown_containers ()
def ContainerManagerSetOverrideEnvForContainersSimple (self, env)
def LogManagerNaiveFetch (self)
def LogManagerFetch (self, clearMemory=False)
def LogManagerDumpInFile (self, fileName, clearMemory=False)
def LogManagerLaunchMonitoringDumpFile (self, intervalInMs, outFileName)
def LogManagerDumpIORInFile (self, iorFileName)
def LogManagerLoadFromFile (fileName)
def LogManagerLoadFromIORFile (iorFile)
def LogManagerFinalFetchBeforeDying (self)
def LogManagerGetLatestMonitoringDumpFile (self)
Variables
string ROOT_PYTHONPACKAGE_NAME = "salome"
string MATCH_ENDING_PATTERN = "site-packages" + os.path.sep + "salome"
 flags = None
 orb
 lcc
 naming_service
 cm
 sg
 esm
 dsm
 logm
 modulcat
 rm
 lm
 myStudy
 myStudyName
bool salome_initial = True
string CM_NAME_IN_NS = "/ContainerManager"
string RM_NAME_IN_NS = "/ResourcesManager"
string DSM_NAME_IN_NS = "/DataServerManager"
string ESM_NAME_IN_NS = "/ExternalServers"
string LOGM_NAME_IN_NS = "/LogManager"
string LAUNCHER_NAME_IN_NS = "/SalomeLauncher"
 __all__ = dir()
◆ ContainerManagerSetOverrideEnvForContainersSimple()
def KERNEL_PY.ContainerManagerSetOverrideEnvForContainersSimple (   self,
  env
◆ extend_path()
def KERNEL_PY.extend_path (   pname)
References extend_path(), and salome_utils.verbose().
Referenced by extend_path().
◆ get_all_containers()
def KERNEL_PY.get_all_containers ( )
◆ LogManagerDumpInFile()
def KERNEL_PY.LogManagerDumpInFile (   self,
  fileName,
  clearMemory = False
◆ LogManagerDumpIORInFile()
def KERNEL_PY.LogManagerDumpIORInFile (   self,
  iorFileName
◆ LogManagerFetch()
def KERNEL_PY.LogManagerFetch (   self,
  clearMemory = False
Fetch data from server in one shot mode.
References SALOME_ContainerHelper.unserializeLogManager().
◆ LogManagerFinalFetchBeforeDying()
def KERNEL_PY.LogManagerFinalFetchBeforeDying (   self)
◆ LogManagerGetLatestMonitoringDumpFile()
def KERNEL_PY.LogManagerGetLatestMonitoringDumpFile (   self)
◆ LogManagerLaunchMonitoringDumpFile()
def KERNEL_PY.LogManagerLaunchMonitoringDumpFile (   self,
  intervalInMs,
  outFileName
This method loops indefinitely every intervalInMs milliseconds to dump the singleton
content of perf log stored in salome.logm.
This method runs in a dedicated subprocess that can be killed at any time.
So subprocess code must deal with.
See also LogManagerGetLatestMonitoringDumpFile
References SalomeOnDemandTK.extension_utilities.format, and salome.LogManagerDumpInFile().
◆ LogManagerLoadFromFile()
def KERNEL_PY.LogManagerLoadFromFile (   fileName)
◆ LogManagerLoadFromIORFile()
def KERNEL_PY.LogManagerLoadFromIORFile (   iorFile)
◆ LogManagerNaiveFetch()
def KERNEL_PY.LogManagerNaiveFetch (   self)
Fetch data from server with multiple CORBA invokations.
◆ retrieve_containers_in_ns()
def KERNEL_PY.retrieve_containers_in_ns ( )
Referenced by get_all_containers().
◆ salome_close()
◆ salome_init()
def KERNEL_PY.salome_init (   path = None,
  embedded = False,
  iorfakensfile = None,
  forced = False
Initialize SALOME client process (that can also be server).
3 modes of initialization exists:
- SSL mode (see salome_init_without_session)
- SSL mode attached in the context of python execution inside SALOME_Container_No_NS_Serv server (typically YACS)
- Classical mode (see salome_init_with_session)
:param iorfakensfile: filename inside which IOR of fake NS will be written
:param forced: tell if the multi-initialization protection mecanism of salome_init must be skiped of not
               (typically in the context where a path to a study is given whereas a previous initialisation without it was done)
References salome_init_with_session(), salome_init_without_session(), and salome_init_without_session_attached().
Referenced by KERNEL_PY.SessionContextManager.__enter__(), and salome_shutdown_containers_with_session().
◆ salome_init_with_session()
def KERNEL_PY.salome_init_with_session (   path = None,
  embedded = False
Performs only once SALOME general purpose initialisation for scripts.
Provides:
orb             reference to CORBA
lcc             a LifeCycleCorba instance
naming_service  a naming service instance
cm              reference to the container manager
esm             reference to external server manager
dsm             reference to shared dataserver manager
modulcat        reference to modulecatalog instance
sg              access to SALOME GUI (when linked with IAPP GUI)
myStudy         active study itself (CORBA reference)
myStudyName     active study name
References salome_iapp.salome_iapp_init(), salome.salome_init(), KERNEL_PY.salome_kernel.salome_kernel_init(), and KERNEL_PY.salome_study.salome_study_init().
Referenced by salome_init().
◆ salome_init_without_session()
def KERNEL_PY.salome_init_without_session (   path = None,
  embedded = False,
Force creation of all servants needed by SALOME session in the current process.
A Fake NamingService is created storing reference of all servants in the current process.
References salome_init_without_session_common().
Referenced by LogManagerLoadFromIORFile(), and salome_init().
◆ salome_init_without_session_attached()
def KERNEL_PY.salome_init_without_session_attached (   path = None,
  embedded = False
Configuration SSL inside a python interpretor launched in the SALOME_Container_No_NS_Serv.
In this configuration, a local FakeNamingService is created and remote objects are stored in it.
lcc is pointing to the FakeNamingService above.
◆ salome_init_without_session_common()
◆ salome_NS()
def KERNEL_PY.salome_NS ( )
◆ salome_shutdown_containers()
def KERNEL_PY.salome_shutdown_containers ( )
◆ salome_shutdown_containers_with_session()
def KERNEL_PY.salome_shutdown_containers_with_session ( )
◆ salome_shutdown_containers_without_session()
def KERNEL_PY.salome_shutdown_containers_without_session ( )
◆ salome_walk_on_containers()
def KERNEL_PY.salome_walk_on_containers (   ns,
  root
◆ standalone()
def KERNEL_PY.standalone ( )
◆ withServers()
def KERNEL_PY.withServers ( )
Variable Documentation
◆ __all__
KERNEL_PY.__all__ = dir()
◆ cm
KERNEL_PY.cm
◆ CM_NAME_IN_NS
string KERNEL_PY.CM_NAME_IN_NS = "/ContainerManager"
◆ dsm
KERNEL_PY.dsm
◆ DSM_NAME_IN_NS
string KERNEL_PY.DSM_NAME_IN_NS = "/DataServerManager"
◆ esm
KERNEL_PY.esm
◆ ESM_NAME_IN_NS
string KERNEL_PY.ESM_NAME_IN_NS = "/ExternalServers"
◆ flags
KERNEL_PY.flags = None
◆ LAUNCHER_NAME_IN_NS
string KERNEL_PY.LAUNCHER_NAME_IN_NS = "/SalomeLauncher"
◆ lcc
KERNEL_PY.lcc
◆ lm
KERNEL_PY.lm
◆ logm
KERNEL_PY.logm
◆ LOGM_NAME_IN_NS
string KERNEL_PY.LOGM_NAME_IN_NS = "/LogManager"
◆ MATCH_ENDING_PATTERN
string KERNEL_PY.MATCH_ENDING_PATTERN = "site-packages" + os.path.sep + "salome"
◆ modulcat
KERNEL_PY.modulcat
◆ myStudy
KERNEL_PY.myStudy
◆ myStudyName
KERNEL_PY.myStudyName
◆ naming_service
KERNEL_PY.naming_service
◆ orb
KERNEL_PY.orb
◆ rm
KERNEL_PY.rm
◆ RM_NAME_IN_NS
string KERNEL_PY.RM_NAME_IN_NS = "/ResourcesManager"
◆ ROOT_PYTHONPACKAGE_NAME
string KERNEL_PY.ROOT_PYTHONPACKAGE_NAME = "salome"
◆ salome_initial
bool KERNEL_PY.salome_initial = True
◆ sg
KERNEL_PY.sg
