SALOME_ContainerHelper Namespace Reference
class  ContainerLogInfo
class  ContainerLogInfoAbstract
class  ContainerLogInfoClt
class  DistributionOfExecs
class  DistriutionClass
class  FakeObjVisitor
class  InOutputObjVisitor
class  InOutputObjVisitorAbstract
class  InOutputObjVisitorCM
class  InOutputObjVisitorIter
class  ObjMemModel
class  OffsetType
class  ScriptExecInfo
class  ScriptExecInfoDeco
class  ScriptInfo
class  ScriptInfoAbstract
class  ScriptInfoClt
class  ScriptInfoDeco
def unserializeInt (structData, offset)
def unserializeString (structData, offset)
def unserializeContainerScriptExecPerfLog (structData, offset)
def unserializeContainerScriptPerfLog (structData, offset)
def unserializeContainerPerfLog (structData, offset)
def unserializeLogManager (structData)
def ListAllExecContainIn (listOfContainerLogInfo)
def ListAllExecFinishedContainIn (listOfContainerLogInfo)
def IsExecTimeHigherThan (execInstDeco, limitDuration)
def GetMaxTimeExec (listOfFinishedExecs)
def GetMinTimeExec (listOfFinishedExecs)
◆ GetMaxTimeExec()
def SALOME_ContainerHelper.GetMaxTimeExec (   listOfFinishedExecs)
Returns the instance among listOfFinishedExecs that spends the max time to be executed
Args:
listOfFinishedExecs ( list<ScriptExecInfoDeco> ) : instance of ScriptExecInfoDeco that have finished to be executed
Typically returned by ListAllExecFinishedContainIn
ScriptExecInfoDeco :
Referenced by SALOME_ContainerHelper.DistributionOfExecs.ComputeDistributionOfExecTime().
◆ GetMinTimeExec()
def SALOME_ContainerHelper.GetMinTimeExec (   listOfFinishedExecs)
Returns the instance among listOfFinishedExecs that spends the min time to be executed
Args:
◆ IsExecTimeHigherThan()
def SALOME_ContainerHelper.IsExecTimeHigherThan (   execInstDeco,
  limitDuration
Example of Usage :
[elt for elt in allexecs if IsExecTimeHigherThan(elt,datetime.timedelta(hours=1))]
Args:
execInstDeco (ScriptExecInfoDeco)
limitDuration (datetime.timedelta)  Ex (datetime.timedelta(hours=1))
References IsExecTimeHigherThan().
Referenced by IsExecTimeHigherThan().
◆ ListAllExecContainIn()
def SALOME_ContainerHelper.ListAllExecContainIn (   listOfContainerLogInfo)
For all ContainerLogInfo contained in listOfContainerLogInfo extract all ScriptExecInfo contained recursively
in it. This method filters all "side" executions like those positionning environment for exemple.
See also : ListAllExecFinishedContainIn
Args:
listOfContainerLogInfo (list<ContainerLogInfo>) : instance typically returned by salome.LogManagerLoadFromFile
list<ScriptExecInfoDeco> : all ScriptExecInfoDeco instance contained recursively in all input ContainerLogInfo instances
Referenced by ListAllExecFinishedContainIn().
◆ ListAllExecFinishedContainIn()
def SALOME_ContainerHelper.ListAllExecFinishedContainIn (   listOfContainerLogInfo)
in it. This method filters all "side" executions like those positionning environment for exemple and those not finished.
See also : ListAllExecContainIn
Args:
References ListAllExecContainIn().
◆ unserializeContainerPerfLog()
def SALOME_ContainerHelper.unserializeContainerPerfLog (   structData,
  offset
◆ unserializeContainerScriptExecPerfLog()
def SALOME_ContainerHelper.unserializeContainerScriptExecPerfLog (   structData,
  offset
◆ unserializeContainerScriptPerfLog()
def SALOME_ContainerHelper.unserializeContainerScriptPerfLog (   structData,
  offset
◆ unserializeInt()
def SALOME_ContainerHelper.unserializeInt (   structData,
  offset
◆ unserializeLogManager()
def SALOME_ContainerHelper.unserializeLogManager (   structData)
◆ unserializeString()
def SALOME_ContainerHelper.unserializeString (   structData,
  offset
