Functions | |
| def | DumpComponent (SO, Builder, offset) |
| def | DumpStudy () |
| def | IDToObject (id) |
| def | ObjectToSObject (obj) |
| def | ObjectToID (obj) |
| def | IDToSObject (id) |
| def | generateName (prefix=None) |
| def | PersistentPresentation (theSO, theWithID) |
| def | GetTree (theSO) |
| def | CheckCopyPaste (theSO, theInfo, theComponentPaste) |
| def | GetComponentVersion (theComponent, all_versions=False) |
| def | FindFileInDataDir (filename) |
| def | openStudy (theStudyPath) |
| def | salome_study_init_without_session (theStudyPath=None) |
| def | salome_study_init (theStudyPath=None) |
| def | salome_study_close () |
Variables | |
| myStudy = None | |
| myStudyName = None | |
| def KERNEL_PY.salome_study.CheckCopyPaste | ( | theSO, | |
| theInfo, | |||
| theComponentPaste | |||
| def KERNEL_PY.salome_study.DumpComponent | ( | SO, | |
| Builder, | |||
| offset | |||
References KERNEL_PY.salome_study.DumpComponent().
Referenced by KERNEL_PY.salome_study.DumpComponent(), and KERNEL_PY.salome_study.DumpStudy().
| def KERNEL_PY.salome_study.DumpStudy | ( | ) |
Dump a study, given the ior
| def KERNEL_PY.salome_study.FindFileInDataDir | ( | filename | ) |
| def KERNEL_PY.salome_study.generateName | ( | prefix = None | ) |
| def KERNEL_PY.salome_study.GetComponentVersion | ( | theComponent, | |
all_versions = False |
| def KERNEL_PY.salome_study.GetTree | ( | theSO | ) |
References KERNEL_PY.salome_study.GetTree().
Referenced by KERNEL_PY.salome_study.CheckCopyPaste(), and KERNEL_PY.salome_study.GetTree().
| def KERNEL_PY.salome_study.IDToObject | ( | id | ) |
| def KERNEL_PY.salome_study.IDToSObject | ( | id | ) |
| def KERNEL_PY.salome_study.ObjectToID | ( | obj | ) |
References KERNEL_PY.salome_study.ObjectToSObject().
| def KERNEL_PY.salome_study.ObjectToSObject | ( | obj | ) |
Referenced by KERNEL_PY.salome_study.ObjectToID().
| def KERNEL_PY.salome_study.openStudy | ( | theStudyPath | ) |
| def KERNEL_PY.salome_study.PersistentPresentation | ( | theSO, | |
| theWithID | |||
References KERNEL_PY.salome_study.PersistentPresentation().
Referenced by KERNEL_PY.salome_study.CheckCopyPaste(), and KERNEL_PY.salome_study.PersistentPresentation().
| def KERNEL_PY.salome_study.salome_study_close | ( | ) |
Referenced by salome.salome_close(), and KERNEL_PY.salome_close().
| def KERNEL_PY.salome_study.salome_study_init | ( | theStudyPath = None | ) |
Performs only once study creation or connection.
optional argument : theStudyPath
None : attach to the currently active single study;
create new empty study if there is active study
<URL> (str) : open study with the given file name
References KERNEL_PY.salome_study.openStudy().
Referenced by salome.salome_init_with_session(), and KERNEL_PY.salome_init_with_session().
| def KERNEL_PY.salome_study.salome_study_init_without_session | ( | theStudyPath = None | ) |
Referenced by salome.salome_init_without_session_common(), and KERNEL_PY.salome_init_without_session_common().
| KERNEL_PY.salome_study.myStudy = None |
| KERNEL_PY.salome_study.myStudyName = None |
