Functions | |
| def | mkdir (path) |
| def | symlink (src, dest) |
| def | rmtree (dir) |
| def | get_lib_dir () |
| def | link_module (options) |
| def | link_extra_test (options) |
| def | main () |
Variables | |
| string | py_version = 'python%s.%s' % (sys.version_info[0], sys.version_info[1]) |
| int | verbose = 0 |
| __lib__dir__ = None | |
| def virtual_salome.get_lib_dir | ( | ) |
Referenced by link_module().
| def virtual_salome.link_extra_test | ( | options | ) |
References rmtree(), and symlink().
Referenced by appli_gen.install().
| def virtual_salome.link_module | ( | options | ) |
References get_lib_dir(), mkdir(), rmtree(), and symlink().
Referenced by appli_gen.install(), and main().
| def virtual_salome.main | ( | void | ) |
References link_module().
| def virtual_salome.mkdir | ( | path | ) |
Create a directory and all the intermediate directories if path does not exist
Referenced by SALOME_PyNode.BigObjectDirHandlerOnDiskSSDNoShare.__enter__(), GetTmpDir(), appli_gen.install(), and link_module().
| def virtual_salome.rmtree | ( | dir | ) |
Remove (recursive) a directory if it exists
Referenced by link_extra_test(), and link_module().
| def virtual_salome.symlink | ( | src, | |
| dest | |||
Create a link if it does not exist
Referenced by appli_gen.install(), link_extra_test(), and link_module().
private |
| string virtual_salome.py_version = 'python%s.%s' % (sys.version_info[0], sys.version_info[1]) |
| int virtual_salome.verbose = 0 |
Referenced by killSalomeWithPort.__guessPiDictFilename(), launchConfigureParser.xml_parser.__init__(), addToKillList.addToKillList(), SALOME_utilities.BEGIN_OF(), SALOME_utilities.END_OF(), salome.extend_path(), KERNEL_PY.extend_path(), addToKillList.findFileDict(), launchConfigureParser.get_env(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.import_component(), launchConfigureParser.xml_parser.importFile(), nameserver.NamingServer.initNSArgs(), addToKillList.killList(), killSalomeWithPort.killMyPort(), killSalomeWithPort.main(), SALOME_utilities.MESSAGE(), SALOME_utilities.MYTRACE(), SALOME_utilities.REPERE(), killSalomeWithPort.shutdownMyPort(), runSalomeOld.startSalome(), and runSalomeOld.useSalome().
