KERNEL_PY.salome_version Namespace Reference
def getVersionFile (mod)
def getVersion (mod="KERNEL", full=False)
def getVersionMajor (mod="KERNEL")
def getVersionMinor (mod="KERNEL")
def getVersionRelease (mod="KERNEL")
def getVersions (mod="KERNEL")
def getXVersion (mod="KERNEL")
def isDevelopmentVersion (mod="KERNEL")
Variables
list __ALL__
dictionary _salome_versions = {}
◆ getVersion()
def KERNEL_PY.salome_version.getVersion (   mod = "KERNEL",
  full = False
Get SALOME module version number
Parameters:
- mod  : SALOME module name, default is 'KERNEL'
- full : take into account development marker (in this case 'dev' is added
         to the end of version value for development version), False by default
Returns: version number string or None if VERSION file is not found
References KERNEL_PY.salome_version.getVersionFile().
Referenced by KERNEL_PY.salome_version.getVersionMajor(), KERNEL_PY.salome_version.getVersionMinor(), KERNEL_PY.salome_version.getVersionRelease(), and KERNEL_PY.salome_version.isDevelopmentVersion().
◆ getVersionFile()
def KERNEL_PY.salome_version.getVersionFile (   mod)
◆ getVersionMajor()
def KERNEL_PY.salome_version.getVersionMajor (   mod = "KERNEL")
Get SALOME module major version number
Parameters:
Returns: version major number string or None if VERSION file is not found
References KERNEL_PY.salome_version.getVersion().
Referenced by KERNEL_PY.salome_version.getVersions().
◆ getVersionMinor()
def KERNEL_PY.salome_version.getVersionMinor (   mod = "KERNEL")
Get SALOME module minor version number
Parameters:
Returns: version minor number string or None if VERSION file is not found
◆ getVersionRelease()
def KERNEL_PY.salome_version.getVersionRelease (   mod = "KERNEL")
Get SALOME module release version number
Parameters:
Returns: version release number string or None if VERSION file is not found
◆ getVersions()
def KERNEL_PY.salome_version.getVersions (   mod = "KERNEL")
Get SALOME module version as list of [major, minor, release] numbers
Parameters:
Returns: version numbers list
References KERNEL_PY.salome_version.getVersionMajor(), KERNEL_PY.salome_version.getVersionMinor(), and KERNEL_PY.salome_version.getVersionRelease().
Referenced by KERNEL_PY.salome_version.getXVersion().
◆ getXVersion()
def KERNEL_PY.salome_version.getXVersion (   mod = "KERNEL")
Parameters:
References KERNEL_PY.salome_version.getVersions().
◆ isDevelopmentVersion()
def KERNEL_PY.salome_version.isDevelopmentVersion (   mod = "KERNEL")
Checks if the version of SALOME module is marked as development one
Parameters:
Returns: Return True for delopment version of module or False otherwise
Variable Documentation
◆ __ALL__
list KERNEL_PY.salome_version.__ALL__
Initial value:
1= [
2 "getVersion",
3 "getVersionMajor",
4 "getVersionMinor",
5 "getVersionRelease",
6 "getVersions",
7 "getXVersion",
8 "isDevelopmentVersion",
9 ]
◆ _salome_versions
dictionary KERNEL_PY.salome_version._salome_versions = {}
