Container_proxy_impl_final Class Reference
#include <SALOME_ParallelContainerProxy_i.hxx>
Inheritance diagram for Container_proxy_impl_final:
struct  proxy_object
 Container_proxy_impl_final (CORBA::ORB_ptr orb, paco_fabrique_thread *fab_thread, PortableServer::POA_ptr poa, std::string containerName, bool is_a_return_proxy=false)
virtual ~Container_proxy_impl_final ()
virtual void Shutdown ()
virtual ::CORBA::Boolean load_component_Library (const char *componentName, CORBA::String_out reason)
virtual Engines::EngineComponent_ptr create_component_instance (const char *componentName)
virtual Engines::EngineComponent_ptr create_component_instance_env (const char *componentName, const Engines::FieldsDict &env, CORBA::String_out reason)
Static Protected Attributes
static std::map< std::string, int > _cntInstances_map
static std::map< std::string, void * > _library_map
static std::map< std::string, void * > _toRemove_map
static omni_mutex _numInstanceMutex
Private Types
typedef void(* PACO_TEST_FUNCTION) ()
typedef PortableServer::ObjectId *(* FACTORY_FUNCTION) (CORBA::ORB_ptr, paco_fabrique_thread *, PortableServer::POA_ptr, PortableServer::ObjectId *, RegistryConnexion **, const char *, int)
std::map< std::string, std::string > _libtype_map
std::list< Container_proxy_impl_final::proxy_object > _par_obj_inst_list
int _numInstance
std::string _hostname
std::string _containerName
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
SALOME_NamingService * _NS
paco_fabrique_thread * _fab_thread
◆ FACTORY_FUNCTION
typedef PortableServer::ObjectId *(* Container_proxy_impl_final::FACTORY_FUNCTION) (CORBA::ORB_ptr, paco_fabrique_thread *, PortableServer::POA_ptr, PortableServer::ObjectId *, RegistryConnexion **, const char *, int)
◆ PACO_TEST_FUNCTION
typedef void(* Container_proxy_impl_final::PACO_TEST_FUNCTION) ()
◆ Container_proxy_impl_final()
Container_proxy_impl_final::Container_proxy_impl_final ( CORBA::ORB_ptr  orb,
paco_fabrique_thread *  fab_thread,
bool  is_a_return_proxy = false
◆ ~Container_proxy_impl_final()
Container_proxy_impl_final::~Container_proxy_impl_final ( )
References _id, and _NS.
◆ create_component_instance()
Engines::EngineComponent_ptr Container_proxy_impl_final::create_component_instance ( const char *  componentName)
◆ create_component_instance_env()
◆ load_component_Library()
CORBA::Boolean Container_proxy_impl_final::load_component_Library ( const char *  componentName,
◆ Shutdown()
◆ _cntInstances_map
std::map< std::string, int > ParallelGlobalProcessVar_i::_cntInstances_map
staticprotectedinherited
◆ _containerName
◆ _fab_thread
paco_fabrique_thread* Container_proxy_impl_final::_fab_thread
◆ _hostname
std::string Container_proxy_impl_final::_hostname
◆ _id
PortableServer::ObjectId* Container_proxy_impl_final::_id
◆ _library_map
◆ _libtype_map
std::map<std::string, std::string> Container_proxy_impl_final::_libtype_map
◆ _NS
◆ _numInstance
◆ _numInstanceMutex
◆ _par_obj_inst_list
std::list<Container_proxy_impl_final::proxy_object> Container_proxy_impl_final::_par_obj_inst_list
◆ _poa
◆ _toRemove_map
std::map< std::string, void * > ParallelGlobalProcessVar_i::_toRemove_map
