KERNEL_PY.kernel.threadhelper Namespace Reference
class  PeriodicTimer
class  Runner
def testIfContinue ()
def endedAction ()
def TEST_PeriodicTimer ()
def function_ok (nbsteps=5)
def function_with_exception ()
def infinite_function ()
def runWithRunner (functionToRun)
def runWithTimeout (functionToRun, timeout=10)
def TEST_Timeout ()
def TEST_Runner ()
def myCallbackFunction ()
def TEST_runWithCallback ()
Variables
string __author__ = "gboulant"
string __date__ = "$1 avr. 2010 18:12:38$"
string testfilename = "/tmp/threadhelperTestFile"
◆ endedAction()
def KERNEL_PY.kernel.threadhelper.endedAction ( )
◆ function_ok()
def KERNEL_PY.kernel.threadhelper.function_ok (   nbsteps = 5)
Fonction qui se termine correctement
◆ function_with_exception()
def KERNEL_PY.kernel.threadhelper.function_with_exception ( )
Fonction qui aboutie � une lev�e d'exception
◆ infinite_function()
def KERNEL_PY.kernel.threadhelper.infinite_function ( )
fonction de dur�e infinie (tant qu'il y a du courant �l�ctrique) pour
le test du timeout.
◆ myCallbackFunction()
def KERNEL_PY.kernel.threadhelper.myCallbackFunction ( )
◆ runWithRunner()
def KERNEL_PY.kernel.threadhelper.runWithRunner (   functionToRun)
Ex�cute la fonction avec le runner. On illustre ici la modalit�
d'utilisation du Runner.
Referenced by KERNEL_PY.kernel.threadhelper.TEST_Runner().
◆ runWithTimeout()
def KERNEL_PY.kernel.threadhelper.runWithTimeout (   functionToRun,
  timeout = 10
Referenced by KERNEL_PY.kernel.threadhelper.TEST_Timeout().
◆ TEST_PeriodicTimer()
def KERNEL_PY.kernel.threadhelper.TEST_PeriodicTimer ( )
◆ TEST_Runner()
def KERNEL_PY.kernel.threadhelper.TEST_Runner ( )
◆ TEST_runWithCallback()
def KERNEL_PY.kernel.threadhelper.TEST_runWithCallback ( )
References unittester.run().
◆ TEST_Timeout()
def KERNEL_PY.kernel.threadhelper.TEST_Timeout ( )
◆ testIfContinue()
def KERNEL_PY.kernel.threadhelper.testIfContinue ( )
Variable Documentation
◆ __author__
string KERNEL_PY.kernel.threadhelper.__author__ = "gboulant"
◆ __date__
string KERNEL_PY.kernel.threadhelper.__date__ = "$1 avr. 2010 18:12:38$"
◆ testfilename
string KERNEL_PY.kernel.threadhelper.testfilename = "/tmp/threadhelperTestFile"
