unittester
Collaboration diagram for unittester:
def unittester.run (modulePath, functionName)
 This function should be used for very basic unit tests and only for a rapid development. More...
def unittester.tryfunction (function, *argv)
 This function is for debug only. More...
def KERNEL_PY.kernel.unittester.run (modulePath, functionName)
def KERNEL_PY.kernel.unittester.tryfunction (function, *argv)
Run very basic unit tests
◆ run() [1/2]
def unittester.run (   modulePath,
  functionName
◆ run() [2/2]
def KERNEL_PY.kernel.unittester.run (   modulePath,
  functionName
A better way should be the pyunit framework. The function functionName is supposed here to return a boolean value indicating if the test is OK (True) or NOT OK (False)
rapid development. A better way should be the pyunit framework.
Referenced by KERNEL_PY.kernel.unittester.TEST_myTestIsNotOk().
◆ tryfunction() [1/2]
def unittester.tryfunction (   function,
*  argv
It executes the specified function with the specified arguments in a try/except block so as to display the exception in the case where an exception is raised (useful to debug server side of a CORBA process).
◆ tryfunction() [2/2]
def KERNEL_PY.kernel.unittester.tryfunction (   function,
*  argv
This function is for debug only. It executes the specified function with the
process).
