SALOMESDS::DataScopeServerBase Class Reference
#include <SALOMESDS_DataScopeServer.hxx>
Inheritance diagram for SALOMESDS::DataScopeServerBase:
 DataScopeServerBase (const SALOME_CPythonHelper *pyHelper, CORBA::ORB_ptr orb, SALOME::DataScopeKiller_var killer, const std::string &scopeName, SALOME_NamingService_Container_Abstract *ns)
 DataScopeServerBase (const DataScopeServerBase &other)
void ping ()
 Called remotely -> to protect against throw. More...
char * getScopeName ()
SALOME::StringVec * listVars ()
CORBA::Boolean existVar (const char *varName)
SALOME::BasicDataServer_ptr retrieveVarInternal (const char *varName)
void deleteVar (const char *varName)
CORBA::Boolean shutdownIfNotHostedByDSM (SALOME::DataScopeKiller_out killer)
SALOME::ByteVec * fetchSerializedContent (const char *varName)
SALOME::SeqOfByteVec * getAllKeysOfVarWithTypeDict (const char *varName)
SALOME::ByteVec * getValueOfVarWithTypeDict (const char *varName, const SALOME::ByteVec &constKey)
void takeANap (CORBA::Double napDurationInSec)
 ~DataScopeServerBase ()
BasicDataServer * retrieveVarInternal2 (const std::string &varName)
void registerToSalomePiDict () const
void setPOA (PortableServer::POA_var poa)
void registerInNS (SALOME::DataScopeServerBase_ptr ptr)
PyObject * getGlobals () const
PyObject * getLocals () const
PyObject * getPickler () const
PortableServer::POA_var getPOA () const
CORBA::ORB_var getORB ()
std::string getScopeNameCpp () const
std::vector< std::string > getAllVarNames () const
bool isExistingVar (const std::string &varName) const
void checkNotAlreadyExistingVar (const std::string &varName) const
void checkExistingVar (const std::string &varName) const
PickelizedPyObjServer * checkVarExistingAndDict (const std::string &varName)
void moveStatusOfVarFromRdWrToRdOnly (const std::string &varName)
void moveStatusOfVarFromRdOnlyToRdWr (const std::string &varName)
void moveStatusOfVarFromRdExtOrRdExtInitToRdExtInit (const std::string &varName)
void moveStatusOfVarFromRdExtOrRdExtInitToRdExt (const std::string &varName)
CORBA::Object_var activate ()
void enforcedRelease ()
static std::string BuildTmpVarNameFrom (const std::string &varName)
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::const_iterator retrieveVarInternal3 (const std::string &varName) const
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::iterator retrieveVarInternal4 (const std::string &varName)
SALOME_NamingService_Container_Abstract * _ns = nullptr
const SALOME_CPythonHelper * _pyHelper = nullptr
PortableServer::POA_var _poa
CORBA::ORB_var _orb
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > > _vars
SALOME::DataScopeKiller_var _killer
Static Protected Attributes
static std::size_t COUNTER =0
◆ DataScopeServerBase() [1/2]
DataScopeServerBase::DataScopeServerBase ( const SALOME_CPythonHelper *  pyHelper,
CORBA::ORB_ptr  orb,
const std::string &  scopeName,
SALOME_NamingService_Container_Abstract *  ns
◆ DataScopeServerBase() [2/2]
DataScopeServerBase::DataScopeServerBase ( const DataScopeServerBase &  other)
◆ ~DataScopeServerBase()
DataScopeServerBase::~DataScopeServerBase ( )
◆ activate()
◆ BuildTmpVarNameFrom()
std::string DataScopeServerBase::BuildTmpVarNameFrom ( const std::string &  varName)
◆ checkExistingVar()
void DataScopeServerBase::checkExistingVar ( const std::string &  varName) const
◆ checkNotAlreadyExistingVar()
◆ checkVarExistingAndDict()
◆ deleteVar()
◆ enforcedRelease()
◆ existVar()
CORBA::Boolean DataScopeServerBase::existVar ( const char *  varName)
◆ fetchSerializedContent()
◆ getAllKeysOfVarWithTypeDict()
SALOME::SeqOfByteVec * DataScopeServerBase::getAllKeysOfVarWithTypeDict ( const char *  varName)
◆ getAllVarNames()
std::vector< std::string > DataScopeServerBase::getAllVarNames ( ) const
◆ getGlobals()
PyObject * SALOMESDS::DataScopeServerBase::getGlobals ( ) const
◆ getLocals()
PyObject * SALOMESDS::DataScopeServerBase::getLocals ( ) const
◆ getORB()
CORBA::ORB_var SALOMESDS::DataScopeServerBase::getORB ( )
◆ getPickler()
PyObject * SALOMESDS::DataScopeServerBase::getPickler ( ) const
◆ getPOA()
◆ getScopeName()
char * DataScopeServerBase::getScopeName ( )
References _name.
Referenced by SALOMESDS::BasicDataServer::getScopeName().
◆ getScopeNameCpp()
std::string SALOMESDS::DataScopeServerBase::getScopeNameCpp ( ) const
◆ getValueOfVarWithTypeDict()
◆ isExistingVar()
bool DataScopeServerBase::isExistingVar ( const std::string &  varName) const
◆ listVars()
SALOME::StringVec * DataScopeServerBase::listVars ( )
< TODO: size_t to CORBA::ULong
References _vars, pythfilter::name, KERNEL_PY.batchmode_salome::obj, and TestKernelHelpers::ret.
Referenced by SALOMESDS::RequestSwitcher::listVars().
◆ moveStatusOfVarFromRdExtOrRdExtInitToRdExt()
◆ moveStatusOfVarFromRdExtOrRdExtInitToRdExtInit()
◆ moveStatusOfVarFromRdOnlyToRdWr()
◆ moveStatusOfVarFromRdWrToRdOnly()
◆ ping()
void DataScopeServerBase::ping ( )
◆ registerInNS()
void DataScopeServerBase::registerInNS ( SALOME::DataScopeServerBase_ptr  ptr)
◆ registerToSalomePiDict()
void DataScopeServerBase::registerToSalomePiDict ( ) const
◆ retrieveVarInternal()
SALOME::BasicDataServer_ptr DataScopeServerBase::retrieveVarInternal ( const char *  varName)
◆ retrieveVarInternal2()
◆ retrieveVarInternal3()
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::const_iterator DataScopeServerBase::retrieveVarInternal3 ( const std::string &  varName) const
◆ retrieveVarInternal4()
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::iterator DataScopeServerBase::retrieveVarInternal4 ( const std::string &  varName)
◆ setPOA()
void DataScopeServerBase::setPOA ( PortableServer::POA_var  poa)
◆ shutdownIfNotHostedByDSM()
◆ takeANap()
void DataScopeServerBase::takeANap ( CORBA::Double  napDurationInSec)
◆ _killer
SALOME::DataScopeKiller_var SALOMESDS::DataScopeServerBase::_killer
◆ _name
std::string SALOMESDS::DataScopeServerBase::_name
◆ _ns
SALOME_NamingService_Container_Abstract* SALOMESDS::DataScopeServerBase::_ns = nullptr
◆ _orb
◆ _poa
◆ _pyHelper
const SALOME_CPythonHelper* SALOMESDS::DataScopeServerBase::_pyHelper = nullptr
Referenced by registerToSalomePiDict().
◆ _vars
◆ COUNTER
std::size_t DataScopeServerBase::COUNTER =0
staticprotected
Referenced by BuildTmpVarNameFrom().
