SALOMESDS::PickelizedPyObjRdExtServer Class Reference
#include <SALOMESDS_PickelizedPyObjRdExtServer.hxx>
Inheritance diagram for SALOMESDS::PickelizedPyObjRdExtServer:
 PickelizedPyObjRdExtServer (DataScopeServerBase *father, const std::string &varName, const SALOME::ByteVec &value)
 PickelizedPyObjRdExtServer (DataScopeServerBase *father, const std::string &varName, PyObject *obj)
 obj is consumed More...
virtual ~PickelizedPyObjRdExtServer ()
SALOME::PickelizedPyObjRdExtServer_ptr invokePythonMethodOn (const char *method, const SALOME::ByteVec &args)
 Called remotely -> to protect against throw. More...
virtual PickelizedPyObjRdExtInitServer * buildInitInstanceFrom (const std::string &varName)
std::string getAccessStr () const
void addKeyValueErrorIfAlreadyExisting (PyObject *key, PyObject *value)
void removeKeyInVarErrorIfNotAlreadyExisting (PyObject *key)
void setSerializedContent (const SALOME::ByteVec &newValue)
SALOME::ByteVec * fetchSerializedContent ()
bool isDict ()
void checkKeyNotAlreadyPresent (PyObject *key)
void checkKeyPresent (PyObject *key)
PyObject * getPyObj () const
virtual void addKeyValueHard (PyObject *key, PyObject *value)
PyObject * getPyObjFromPickled (const std::string &pickledData)
 New reference returned. More...
PyObject * getPyObjFromPickled (const std::vector< unsigned char > &pickledData)
std::string pickelize (PyObject *obj)
 obj is consumed by this method. More...
void setNewPyObj (PyObject *obj)
void setSerializedContentInternal (const SALOME::ByteVec &newValue)
SALOME::DataScopeServer_ptr getMyDataScopeServer ()
char * getVarName ()
char * getScopeName ()
void Register ()
void UnRegister ()
void Destroy ()
CORBA::Long getRCValue ()
DataScopeServerBase * getFather () const
std::string getVarNameCpp () const
void incrRef () const
bool decrRef () const
int getCounter () const
CORBA::Object_var activate ()
void enforcedRelease ()
static void FromByteSeqToCpp (const SALOME::ByteVec &bsToBeConv, std::string &ret)
static void FromCppToByteSeq (const std::string &strToBeConv, SALOME::ByteVec &ret)
static SALOME::ByteVec * FromCppToByteSeq (const std::string &strToBeConv)
static PyObject * GetPyObjFromPickled (const std::string &pickledData, DataScopeServerBase *dsb)
static PyObject * GetPyObjFromPickled (const std::vector< unsigned char > &pickledData, DataScopeServerBase *dsb)
static std::string Pickelize (PyObject *obj, DataScopeServerBase *dsb)
static PyObject * CreateDftObjFromType (PyObject *globals, const std::string &typeName)
Static Public Attributes
static const char ACCESS_REPR [] ="RdExt"
PortableServer::POA_var getPOA () const
PyObject * _self
PortableServer::POA_var _poa
DataScopeServerBase * _father
Static Protected Attributes
static const char FAKE_VAR_NAME_FOR_WORK []
void checkRdExtnessOf (const std::string &methodName, PyObject *argsPy)
void checkListRdExtnessOf (const std::string &methodName, PyObject *argsPy)
void checkDictRdExtnessOf (const std::string &methodName, PyObject *argsPy)
void checkDictSetitemRdExtness (PyObject *argsPy)
void checkKeyPresence (PyObject *key, bool presence)
std::string _var_name
unsigned int _cnt
◆ PickelizedPyObjRdExtServer() [1/2]
PickelizedPyObjRdExtServer::PickelizedPyObjRdExtServer ( DataScopeServerBase *  father,
const std::string &  varName,
const SALOME::ByteVec &  value
Referenced by invokePythonMethodOn().
◆ PickelizedPyObjRdExtServer() [2/2]
PyObject *  obj
obj is consumed
◆ ~PickelizedPyObjRdExtServer()
PickelizedPyObjRdExtServer::~PickelizedPyObjRdExtServer ( )
◆ activate()
◆ addKeyValueErrorIfAlreadyExisting()
void PickelizedPyObjServerModifiable::addKeyValueErrorIfAlreadyExisting ( PyObject *  key,
PyObject *  value
◆ addKeyValueHard()
void PickelizedPyObjServer::addKeyValueHard ( PyObject *  key,
PyObject *  value
◆ buildInitInstanceFrom()
◆ checkDictRdExtnessOf()
void PickelizedPyObjRdExtServer::checkDictRdExtnessOf ( const std::string &  methodName,
PyObject *  argsPy
References checkDictSetitemRdExtness().
Referenced by checkRdExtnessOf().
◆ checkDictSetitemRdExtness()
void PickelizedPyObjRdExtServer::checkDictSetitemRdExtness ( PyObject *  argsPy)
◆ checkKeyNotAlreadyPresent()
◆ checkKeyPresence()
void PickelizedPyObjServer::checkKeyPresence ( PyObject *  key,
bool  presence
privateinherited
◆ checkKeyPresent()
void PickelizedPyObjServer::checkKeyPresent ( PyObject *  key)
◆ checkListRdExtnessOf()
void PickelizedPyObjRdExtServer::checkListRdExtnessOf ( const std::string &  methodName,
PyObject *  argsPy
◆ checkRdExtnessOf()
void PickelizedPyObjRdExtServer::checkRdExtnessOf ( const std::string &  methodName,
PyObject *  argsPy
◆ CreateDftObjFromType()
PyObject * PickelizedPyObjServer::CreateDftObjFromType ( PyObject *  globals,
const std::string &  typeName
◆ decrRef()
◆ Destroy()
void BasicDataServer::Destroy ( )
◆ enforcedRelease()
◆ fetchSerializedContent()
SALOME::ByteVec * PickelizedPyObjServer::fetchSerializedContent ( )
◆ FromByteSeqToCpp()
◆ FromCppToByteSeq() [1/2]
SALOME::ByteVec * PickelizedPyObjServer::FromCppToByteSeq ( const std::string &  strToBeConv)
◆ FromCppToByteSeq() [2/2]
◆ getAccessStr()
std::string PickelizedPyObjRdExtServer::getAccessStr ( ) const
◆ getCounter()
int SALOMESDS::RefCountServ::getCounter ( ) const
◆ getFather()
◆ getMyDataScopeServer()
SALOME::DataScopeServer_ptr BasicDataServer::getMyDataScopeServer ( )
◆ getPOA()
PortableServer::POA_var BasicDataServer::getPOA ( ) const
◆ getPyObj()
◆ getPyObjFromPickled() [1/2]
◆ GetPyObjFromPickled() [1/2]
◆ getPyObjFromPickled() [2/2]
PyObject * PickelizedPyObjServer::getPyObjFromPickled ( const std::vector< unsigned char > &  pickledData)
◆ GetPyObjFromPickled() [2/2]
PyObject * PickelizedPyObjServer::GetPyObjFromPickled ( const std::vector< unsigned char > &  pickledData,
DataScopeServerBase *  dsb
◆ getRCValue()
CORBA::Long BasicDataServer::getRCValue ( )
◆ getScopeName()
char * BasicDataServer::getScopeName ( )
◆ getVarName()
char * BasicDataServer::getVarName ( )
References SALOMESDS::BasicDataServer::_var_name.
◆ getVarNameCpp()
◆ incrRef()
void RefCountServ::incrRef ( ) const
◆ invokePythonMethodOn()
◆ isDict()
◆ pickelize()
◆ Pickelize()
◆ Register()
void BasicDataServer::Register ( )
◆ removeKeyInVarErrorIfNotAlreadyExisting()
void PickelizedPyObjServerModifiable::removeKeyInVarErrorIfNotAlreadyExisting ( PyObject *  key)
◆ setNewPyObj()
◆ setSerializedContent()
void SALOMESDS::PickelizedPyObjServer::setSerializedContent ( const SALOME::ByteVec &  newValue)
◆ setSerializedContentInternal()
◆ UnRegister()
void BasicDataServer::UnRegister ( )
◆ _cnt
unsigned int SALOMESDS::RefCountServ::_cnt
mutableprivateinherited
◆ _father
◆ _poa
◆ _self
◆ _var_name
std::string SALOMESDS::BasicDataServer::_var_name
privateinherited
◆ ACCESS_REPR
const char PickelizedPyObjRdExtServer::ACCESS_REPR ="RdExt"
Referenced by getAccessStr().
◆ FAKE_VAR_NAME_FOR_WORK
const char SALOMESDS::PickelizedPyObjServer::FAKE_VAR_NAME_FOR_WORK[]
staticprotectedinherited
