SALOMESDS::DataServerManager Class Reference
#include <SALOMESDS_DataServerManager.hxx>
Inheritance diagram for SALOMESDS::DataServerManager:
 DataServerManager (const SALOME_CPythonHelper *pyHelper, CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, SALOME_NamingService_Abstract *ns=nullptr)
 ~DataServerManager ()
SALOME::StringVec * listScopes ()
SALOME::StringVec * listAliveAndKickingScopes ()
SALOME::DataScopeServer_ptr getDefaultScope ()
CORBA::Boolean isAliveAndKicking (const char *scopeName)
SALOME::DataScopeServerBase_ptr retriveDataScope (const char *scopeName)
SALOME::DataScopeServer_ptr createDataScope (const char *scopeName)
SALOME::DataScopeServer_ptr giveADataScopeCalled (const char *scopeName, CORBA::Boolean &isCreated)
SALOME::DataScopeServerTransaction_ptr createDataScopeTransaction (const char *scopeName)
SALOME::DataScopeServerTransaction_ptr giveADataScopeTransactionCalled (const char *scopeName, CORBA::Boolean &isCreated)
void removeDataScope (const char *scopeName)
void cleanScopesInNS ()
void shutdownScopes ()
SALOME::RequestSwitcherDSM_ptr getRequestSwitcher ()
void holdRequests ()
void activeRequests ()
CORBA::ORB_var getORB ()
SALOME::StringVec * listScopes_unsafe ()
SALOME::DataScopeServerTransaction_ptr giveADataScopeTransactionCalled_unsafe (const char *scopeName, CORBA::Boolean &isCreated)
static std::string CreateAbsNameInNSFromScopeName (const std::string &scopeName)
static CORBA::Boolean IsAliveAndKicking (SALOME::DataScopeServerBase_ptr scopePtr)
static SALOME::DataScopeServerBase_var GetScopePtrGivenName (const std::string &scopeName, const std::vector< std::string > &scopes, SALOME_NamingService_Abstract *ns)
Static Public Attributes
static const char NAME_IN_NS [] ="/DataServerManager"
static const char DFT_SCOPE_NAME_IN_NS [] ="Default"
std::vector< std::string > listOfScopesCpp ()
SALOME::DataScopeServerBase_var getScopePtrGivenName (const std::string &scopeName)
CORBA::Boolean isAliveAndKicking_unsafe (const char *scopeName)
SALOME::DataScopeServerBase_ptr retriveDataScope_unsafe (const char *scopeName)
SALOME_NamingService_Abstract * _ns = nullptr
 naming service object is owned More...
CORBA::ORB_var _orb
PortableServer::POA_var _poa
 single thread poa More...
AutoServantPtr< RequestSwitcherDSM > _rs
std::mutex _mutex
◆ DataServerManager()
◆ ~DataServerManager()
DataServerManager::~DataServerManager ( )
References _ns.
◆ activeRequests()
void DataServerManager::activeRequests ( )
◆ cleanScopesInNS()
◆ CreateAbsNameInNSFromScopeName()
std::string DataServerManager::CreateAbsNameInNSFromScopeName ( const std::string &  scopeName)
◆ createDataScope()
SALOME::DataScopeServer_ptr DataServerManager::createDataScope ( const char *  scopeName)
◆ createDataScopeTransaction()
SALOME::DataScopeServerTransaction_ptr DataServerManager::createDataScopeTransaction ( const char *  scopeName)
◆ getDefaultScope()
SALOME::DataScopeServer_ptr DataServerManager::getDefaultScope ( )
◆ getORB()
CORBA::ORB_var SALOMESDS::DataServerManager::getORB ( )
◆ getRequestSwitcher()
SALOME::RequestSwitcherDSM_ptr DataServerManager::getRequestSwitcher ( )
◆ getScopePtrGivenName()
SALOME::DataScopeServerBase_var DataServerManager::getScopePtrGivenName ( const std::string &  scopeName)
◆ GetScopePtrGivenName()
SALOME::DataScopeServerBase_var DataServerManager::GetScopePtrGivenName ( const std::string &  scopeName,
const std::vector< std::string > &  scopes,
SALOME_NamingService_Abstract *  ns
◆ giveADataScopeCalled()
SALOME::DataScopeServer_ptr DataServerManager::giveADataScopeCalled ( const char *  scopeName,
CORBA::Boolean &  isCreated
◆ giveADataScopeTransactionCalled()
SALOME::DataScopeServerTransaction_ptr DataServerManager::giveADataScopeTransactionCalled ( const char *  scopeName,
◆ giveADataScopeTransactionCalled_unsafe()
SALOME::DataScopeServerTransaction_ptr DataServerManager::giveADataScopeTransactionCalled_unsafe ( const char *  scopeName,
◆ holdRequests()
void DataServerManager::holdRequests ( )
◆ isAliveAndKicking()
CORBA::Boolean DataServerManager::isAliveAndKicking ( const char *  scopeName)
◆ IsAliveAndKicking()
CORBA::Boolean DataServerManager::IsAliveAndKicking ( SALOME::DataScopeServerBase_ptr  scopePtr)
◆ isAliveAndKicking_unsafe()
CORBA::Boolean DataServerManager::isAliveAndKicking_unsafe ( const char *  scopeName)
◆ listAliveAndKickingScopes()
SALOME::StringVec * DataServerManager::listAliveAndKickingScopes ( )
< TODO: size_t to CORBA::ULong
References _mutex, isAliveAndKicking_unsafe(), listOfScopesCpp(), SALOMEDS::lock(), and TestKernelHelpers::ret.
◆ listOfScopesCpp()
◆ listScopes()
SALOME::StringVec * DataServerManager::listScopes ( )
◆ listScopes_unsafe()
SALOME::StringVec * DataServerManager::listScopes_unsafe ( )
References listOfScopesCpp(), and TestKernelHelpers::ret.
Referenced by SALOMESDS::RequestSwitcherDSM::listScopes(), and listScopes().
◆ removeDataScope()
void DataServerManager::removeDataScope ( const char *  scopeName)
◆ retriveDataScope()
SALOME::DataScopeServerBase_ptr DataServerManager::retriveDataScope ( const char *  scopeName)
◆ retriveDataScope_unsafe()
SALOME::DataScopeServerBase_ptr DataServerManager::retriveDataScope_unsafe ( const char *  scopeName)
◆ shutdownScopes()
void DataServerManager::shutdownScopes ( )
◆ _mutex
◆ _ns
◆ _orb
◆ _poa
◆ _rs
AutoServantPtr<RequestSwitcherDSM> SALOMESDS::DataServerManager::_rs
Referenced by getRequestSwitcher().
◆ DFT_SCOPE_NAME_IN_NS
const char DataServerManager::DFT_SCOPE_NAME_IN_NS ="Default"
◆ NAME_IN_NS
