SALOMESDS::DataScopeServerTransaction Class Reference
#include <SALOMESDS_DataScopeServer.hxx>
Inheritance diagram for SALOMESDS::DataScopeServerTransaction:
 DataScopeServerTransaction (const SALOME_CPythonHelper *pyHelper, CORBA::ORB_ptr orb, SALOME::DataScopeKiller_var killer, const std::string &scopeName, SALOME_NamingService_Container_Abstract *ns)
 DataScopeServerTransaction (const DataScopeServerTransaction &other)
 ~DataScopeServerTransaction ()
void createRdOnlyVarInternal (const std::string &varName, const SALOME::ByteVec &constValue)
void createRdExtVarInternal (const std::string &varName, const SALOME::ByteVec &constValue)
void createRdExtVarFreeStyleInternal (const std::string &varName, const SALOME::ByteVec &constValue, std::string &&compareFuncContent, SALOME::AutoPyRef &&compareFunc)
void createRdExtInitVarInternal (const std::string &varName, const SALOME::ByteVec &constValue)
void createRdWrVarInternal (const std::string &varName, const SALOME::ByteVec &constValue)
PortableServer::POA_var getPOA4KeyWaiter () const
void addWaitKey (KeyWaiter *kw)
void pingKey (PyObject *keyObj)
void notifyKey (const std::string &varName, PyObject *keyObj, PyObject *valueObj)
SALOME::ByteVec * waitForMonoThrRev (SALOME::KeyWaiter_ptr kw)
SALOME::ByteVec * waitForAndKill (SALOME::KeyWaiter_ptr kw)
char * getAccessOfVar (const char *varName)
void fetchAndGetAccessOfVar (const char *varName, CORBA::String_out access, SALOME::ByteVec_out data)
 This method is here to retrieve atomically accessStr and picklization. More...
SALOME::Transaction_ptr createRdOnlyVarTransac (const char *varName, const SALOME::ByteVec &constValue)
SALOME::Transaction_ptr createRdExtVarTransac (const char *varName, const SALOME::ByteVec &constValue)
SALOME::Transaction_ptr createRdExtVarFreeStyleTransac (const char *varName, const SALOME::ByteVec &constValue, const char *compareFuncContent)
SALOME::Transaction_ptr createRdExtInitVarTransac (const char *varName, const SALOME::ByteVec &constValue)
SALOME::Transaction_ptr createRdWrVarTransac (const char *varName, const SALOME::ByteVec &constValue)
SALOME::Transaction_ptr addKeyValueInVarHard (const char *varName, const SALOME::ByteVec &key, const SALOME::ByteVec &value)
SALOME::Transaction_ptr addKeyValueInVarErrorIfAlreadyExisting (const char *varName, const SALOME::ByteVec &key, const SALOME::ByteVec &value)
SALOME::TransactionMultiKeyAddSession_ptr addMultiKeyValueSession (const char *varName)
SALOME::Transaction_ptr removeKeyInVarErrorIfNotAlreadyExisting (const char *varName, const SALOME::ByteVec &key)
SALOME::TransactionRdWrAccess_ptr createWorkingVarTransac (const char *varName, const SALOME::ByteVec &constValue)
SALOME::Transaction_ptr killVarTransac (const char *varName)
SALOME::KeyWaiter_ptr waitForKeyInVar (const char *varName, const SALOME::ByteVec &keyVal)
SALOME::KeyWaiter_ptr waitForKeyInVarAndKillIt (const char *varName, const SALOME::ByteVec &keyVal, SALOME::Transaction_out transac)
void atomicApply (const SALOME::ListOfTransaction &transactions)
SALOME::RequestSwitcher_ptr getRequestSwitcher ()
void ping ()
 Called remotely -> to protect against throw. More...
char * getScopeName ()
SALOME::StringVec * listVars ()
CORBA::Boolean existVar (const char *varName)
SALOME::BasicDataServer_ptr retrieveVarInternal (const char *varName)
void deleteVar (const char *varName)
CORBA::Boolean shutdownIfNotHostedByDSM (SALOME::DataScopeKiller_out killer)
SALOME::ByteVec * fetchSerializedContent (const char *varName)
SALOME::SeqOfByteVec * getAllKeysOfVarWithTypeDict (const char *varName)
SALOME::ByteVec * getValueOfVarWithTypeDict (const char *varName, const SALOME::ByteVec &constKey)
void takeANap (CORBA::Double napDurationInSec)
BasicDataServer * retrieveVarInternal2 (const std::string &varName)
void registerToSalomePiDict () const
void setPOA (PortableServer::POA_var poa)
void registerInNS (SALOME::DataScopeServerBase_ptr ptr)
PyObject * getGlobals () const
PyObject * getLocals () const
PyObject * getPickler () const
PortableServer::POA_var getPOA () const
CORBA::ORB_var getORB ()
std::string getScopeNameCpp () const
std::vector< std::string > getAllVarNames () const
bool isExistingVar (const std::string &varName) const
void checkNotAlreadyExistingVar (const std::string &varName) const
void checkExistingVar (const std::string &varName) const
PickelizedPyObjServer * checkVarExistingAndDict (const std::string &varName)
void moveStatusOfVarFromRdWrToRdOnly (const std::string &varName)
void moveStatusOfVarFromRdOnlyToRdWr (const std::string &varName)
void moveStatusOfVarFromRdExtOrRdExtInitToRdExtInit (const std::string &varName)
void moveStatusOfVarFromRdExtOrRdExtInitToRdExt (const std::string &varName)
CORBA::Object_var activate ()
void enforcedRelease ()
static std::string BuildTmpVarNameFrom (const std::string &varName)
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::const_iterator retrieveVarInternal3 (const std::string &varName) const
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::iterator retrieveVarInternal4 (const std::string &varName)
SALOME_NamingService_Container_Abstract * _ns = nullptr
const SALOME_CPythonHelper * _pyHelper = nullptr
PortableServer::POA_var _poa
CORBA::ORB_var _orb
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > > _vars
SALOME::DataScopeKiller_var _killer
Static Protected Attributes
static std::size_t COUNTER =0
PortableServer::POA_var _poa_for_key_waiter
std::list< KeyWaiter * > _waiting_keys
AutoServantPtr< RequestSwitcher > _rs
◆ DataScopeServerTransaction() [1/2]
DataScopeServerTransaction::DataScopeServerTransaction ( const SALOME_CPythonHelper *  pyHelper,
CORBA::ORB_ptr  orb,
const std::string &  scopeName,
SALOME_NamingService_Container_Abstract *  ns
◆ DataScopeServerTransaction() [2/2]
DataScopeServerTransaction::DataScopeServerTransaction ( const DataScopeServerTransaction &  other)
◆ ~DataScopeServerTransaction()
DataScopeServerTransaction::~DataScopeServerTransaction ( )
◆ activate()
◆ addKeyValueInVarErrorIfAlreadyExisting()
SALOME::Transaction_ptr DataScopeServerTransaction::addKeyValueInVarErrorIfAlreadyExisting ( const char *  varName,
const SALOME::ByteVec &  key,
const SALOME::ByteVec &  value
◆ addKeyValueInVarHard()
SALOME::Transaction_ptr DataScopeServerTransaction::addKeyValueInVarHard ( const char *  varName,
◆ addMultiKeyValueSession()
SALOME::TransactionMultiKeyAddSession_ptr DataScopeServerTransaction::addMultiKeyValueSession ( const char *  varName)
◆ addWaitKey()
void DataScopeServerTransaction::addWaitKey ( KeyWaiter *  kw)
◆ atomicApply()
void DataScopeServerTransaction::atomicApply ( const SALOME::ListOfTransaction &  transactions)
< TODO: size_t to CORBA::ULong
References SALOMESDS::DataScopeServerBase::_poa.
◆ BuildTmpVarNameFrom()
std::string DataScopeServerBase::BuildTmpVarNameFrom ( const std::string &  varName)
◆ checkExistingVar()
void DataScopeServerBase::checkExistingVar ( const std::string &  varName) const
◆ checkNotAlreadyExistingVar()
◆ checkVarExistingAndDict()
◆ createRdExtInitVarInternal()
void DataScopeServerTransaction::createRdExtInitVarInternal ( const std::string &  varName,
const SALOME::ByteVec &  constValue
◆ createRdExtInitVarTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::createRdExtInitVarTransac ( const char *  varName,
◆ createRdExtVarFreeStyleInternal()
◆ createRdExtVarFreeStyleTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::createRdExtVarFreeStyleTransac ( const char *  varName,
const SALOME::ByteVec &  constValue,
const char *  compareFuncContent
◆ createRdExtVarInternal()
void DataScopeServerTransaction::createRdExtVarInternal ( const std::string &  varName,
◆ createRdExtVarTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::createRdExtVarTransac ( const char *  varName,
◆ createRdOnlyVarInternal()
void DataScopeServerTransaction::createRdOnlyVarInternal ( const std::string &  varName,
◆ createRdOnlyVarTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::createRdOnlyVarTransac ( const char *  varName,
◆ createRdWrVarInternal()
void DataScopeServerTransaction::createRdWrVarInternal ( const std::string &  varName,
◆ createRdWrVarTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::createRdWrVarTransac ( const char *  varName,
◆ createWorkingVarTransac()
SALOME::TransactionRdWrAccess_ptr DataScopeServerTransaction::createWorkingVarTransac ( const char *  varName,
◆ deleteVar()
◆ enforcedRelease()
◆ existVar()
CORBA::Boolean DataScopeServerBase::existVar ( const char *  varName)
◆ fetchAndGetAccessOfVar()
void DataScopeServerTransaction::fetchAndGetAccessOfVar ( const char *  varName,
References SALOMESDS::DataScopeServerBase::fetchSerializedContent(), getAccessOfVar(), and TestSalomeSDSHelper0::varName.
Referenced by SALOMESDS::RequestSwitcher::fetchAndGetAccessOfVar().
◆ fetchSerializedContent()
◆ getAccessOfVar()
◆ getAllKeysOfVarWithTypeDict()
◆ getAllVarNames()
◆ getGlobals()
PyObject * SALOMESDS::DataScopeServerBase::getGlobals ( ) const
◆ getLocals()
PyObject * SALOMESDS::DataScopeServerBase::getLocals ( ) const
◆ getORB()
CORBA::ORB_var SALOMESDS::DataScopeServerBase::getORB ( )
◆ getPickler()
PyObject * SALOMESDS::DataScopeServerBase::getPickler ( ) const
◆ getPOA()
◆ getPOA4KeyWaiter()
PortableServer::POA_var SALOMESDS::DataScopeServerTransaction::getPOA4KeyWaiter ( ) const
◆ getRequestSwitcher()
SALOME::RequestSwitcher_ptr DataScopeServerTransaction::getRequestSwitcher ( )
◆ getScopeName()
char * DataScopeServerBase::getScopeName ( )
References SALOMESDS::DataScopeServerBase::_name.
Referenced by SALOMESDS::BasicDataServer::getScopeName().
◆ getScopeNameCpp()
std::string SALOMESDS::DataScopeServerBase::getScopeNameCpp ( ) const
◆ getValueOfVarWithTypeDict()
◆ isExistingVar()
bool DataScopeServerBase::isExistingVar ( const std::string &  varName) const
◆ killVarTransac()
SALOME::Transaction_ptr DataScopeServerTransaction::killVarTransac ( const char *  varName)
◆ listVars()
SALOME::StringVec * DataScopeServerBase::listVars ( )
References SALOMESDS::DataScopeServerBase::_vars, pythfilter::name, KERNEL_PY.batchmode_salome::obj, and TestKernelHelpers::ret.
Referenced by SALOMESDS::RequestSwitcher::listVars().
◆ moveStatusOfVarFromRdExtOrRdExtInitToRdExt()
◆ moveStatusOfVarFromRdExtOrRdExtInitToRdExtInit()
◆ moveStatusOfVarFromRdOnlyToRdWr()
◆ moveStatusOfVarFromRdWrToRdOnly()
◆ notifyKey()
void DataScopeServerTransaction::notifyKey ( const std::string &  varName,
PyObject *  keyObj,
PyObject *  valueObj
◆ ping()
void DataScopeServerBase::ping ( )
◆ pingKey()
void DataScopeServerTransaction::pingKey ( PyObject *  keyObj)
◆ registerInNS()
◆ registerToSalomePiDict()
void DataScopeServerBase::registerToSalomePiDict ( ) const
◆ removeKeyInVarErrorIfNotAlreadyExisting()
SALOME::Transaction_ptr DataScopeServerTransaction::removeKeyInVarErrorIfNotAlreadyExisting ( const char *  varName,
◆ retrieveVarInternal()
SALOME::BasicDataServer_ptr DataScopeServerBase::retrieveVarInternal ( const char *  varName)
◆ retrieveVarInternal2()
◆ retrieveVarInternal3()
std::list< std::pair< SALOME::BasicDataServer_var, BasicDataServer * > >::const_iterator DataScopeServerBase::retrieveVarInternal3 ( const std::string &  varName) const
◆ retrieveVarInternal4()
◆ setPOA()
void DataScopeServerBase::setPOA ( PortableServer::POA_var  poa)
◆ shutdownIfNotHostedByDSM()
◆ takeANap()
void DataScopeServerBase::takeANap ( CORBA::Double  napDurationInSec)
◆ waitForAndKill()
SALOME::ByteVec * DataScopeServerTransaction::waitForAndKill ( SALOME::KeyWaiter_ptr  kw)
◆ waitForKeyInVar()
SALOME::KeyWaiter_ptr DataScopeServerTransaction::waitForKeyInVar ( const char *  varName,
const SALOME::ByteVec &  keyVal
◆ waitForKeyInVarAndKillIt()
SALOME::KeyWaiter_ptr DataScopeServerTransaction::waitForKeyInVarAndKillIt ( const char *  varName,
const SALOME::ByteVec &  keyVal,
◆ waitForMonoThrRev()
SALOME::ByteVec * DataScopeServerTransaction::waitForMonoThrRev ( SALOME::KeyWaiter_ptr  kw)
◆ _killer
SALOME::DataScopeKiller_var SALOMESDS::DataScopeServerBase::_killer
◆ _name
◆ _ns
◆ _orb
◆ _poa
◆ _poa_for_key_waiter
PortableServer::POA_var SALOMESDS::DataScopeServerTransaction::_poa_for_key_waiter
◆ _pyHelper
const SALOME_CPythonHelper* SALOMESDS::DataScopeServerBase::_pyHelper = nullptr
◆ _rs
AutoServantPtr<RequestSwitcher> SALOMESDS::DataScopeServerTransaction::_rs
Referenced by getRequestSwitcher().
◆ _vars
◆ _waiting_keys
std::list< KeyWaiter * > SALOMESDS::DataScopeServerTransaction::_waiting_keys
Referenced by addWaitKey(), notifyKey(), and pingKey().
◆ COUNTER
std::size_t DataScopeServerBase::COUNTER =0
staticprotectedinherited
