Param_Double_Port_uses_i Class Reference
#include <Param_Double_Port_uses_i.hxx>
 Param_Double_Port_uses_i (Engines_ParallelDSC_i *par_compo, std::string port_name, CORBA::ORB_ptr orb)
virtual ~Param_Double_Port_uses_i ()
virtual void add_port_to_component ()
virtual void start_port ()
void configure_port_method_put (int totalNbElt)
void put (const Ports::Param_Double_Port::seq_double &param_data)
void get_results (Ports::Param_Double_Port::seq_double_out param_results)
CORBA::ORB_var _orb
std::string _port_name
Engines_ParallelDSC_i * _par_compo
Ports::Param_Double_Port_var _proxy_port
PortProperties_i * _fake_properties
Ports::PortProperties_var _fake_prop_ref
Ports::PaCO_Param_Double_Port * _provides_port
◆ Param_Double_Port_uses_i()
Param_Double_Port_uses_i::Param_Double_Port_uses_i ( Engines_ParallelDSC_i *  par_compo,
CORBA::ORB_ptr  orb
◆ ~Param_Double_Port_uses_i()
Param_Double_Port_uses_i::~Param_Double_Port_uses_i ( )
References _provides_port.
◆ add_port_to_component()
void Param_Double_Port_uses_i::add_port_to_component ( )
◆ configure_port_method_put()
void Param_Double_Port_uses_i::configure_port_method_put ( int  totalNbElt)
◆ get_results()
void Param_Double_Port_uses_i::get_results ( Ports::Param_Double_Port::seq_double_out  param_results)
◆ put()
void Param_Double_Port_uses_i::put ( const Ports::Param_Double_Port::seq_double &  param_data)
◆ start_port()
void Param_Double_Port_uses_i::start_port ( )
◆ _fake_prop_ref
Ports::PortProperties_var Param_Double_Port_uses_i::_fake_prop_ref
◆ _fake_properties
PortProperties_i* Param_Double_Port_uses_i::_fake_properties
◆ _orb
◆ _par_compo
Engines_ParallelDSC_i* Param_Double_Port_uses_i::_par_compo
◆ _port_name
std::string Param_Double_Port_uses_i::_port_name
◆ _provides_port
Ports::PaCO_Param_Double_Port* Param_Double_Port_uses_i::_provides_port
◆ _proxy_port
Ports::Param_Double_Port_var Param_Double_Port_uses_i::_proxy_port
Referenced by start_port().
