24#ifndef _PARAM_DOUBLE_PORT_USES_HXX_
25#define _PARAM_DOUBLE_PORT_USES_HXX_
27#include "SALOME_ParamPortsPaCO_Ports_Param_Double_Port_client.hxx"
32#include <paco_direct_comScheduling.h>
40 std::string port_name,
51 void get_results(Ports::Param_Double_Port::seq_double_out param_results);
Definition: ParallelDSC_i.hxx:40
Definition: Param_Double_Port_uses_i.hxx:37
PortProperties_i * _fake_properties
Definition: Param_Double_Port_uses_i.hxx:58
CORBA::ORB_var _orb
Definition: Param_Double_Port_uses_i.hxx:54
void configure_port_method_put(int totalNbElt)
Definition: Param_Double_Port_uses_i.cxx:95
Ports::PaCO_Param_Double_Port * _provides_port
Definition: Param_Double_Port_uses_i.hxx:60
std::string _port_name
Definition: Param_Double_Port_uses_i.hxx:55
Ports::Param_Double_Port_var _proxy_port
Definition: Param_Double_Port_uses_i.hxx:57
void put(const Ports::Param_Double_Port::seq_double ¶m_data)
Definition: Param_Double_Port_uses_i.cxx:104
virtual ~Param_Double_Port_uses_i()
Definition: Param_Double_Port_uses_i.cxx:45
Engines_ParallelDSC_i * _par_compo
Definition: Param_Double_Port_uses_i.hxx:56
Ports::PortProperties_var _fake_prop_ref
Definition: Param_Double_Port_uses_i.hxx:59
virtual void add_port_to_component()
Definition: Param_Double_Port_uses_i.cxx:55
Definition: Param_Double_Port_uses_i.cxx:110
Param_Double_Port_uses_i(Engines_ParallelDSC_i *par_compo, std::string port_name, CORBA::ORB_ptr orb)
Definition: Param_Double_Port_uses_i.cxx:26
virtual void start_port()
Definition: Param_Double_Port_uses_i.cxx:63
This class implements the interface Ports::PortProperties.
Definition: PortProperties_i.hxx:40
sequence< double > seq_double
Definition: SALOME_ParamPorts.idl:36
orb
Definition: salome.py:122
