#include <LifeCycleCORBATest.hxx>
| void | setUp () |
| Set Trace mechanism. More... | |
| void | tearDown () |
| void | testFindOrLoad_Component_LaunchContainer () |
| Check FindOrLoad_Component. More... | |
| void | testFindOrLoad_Component_SameInstance () |
| void | testFindOrLoad_Component_PythonInCppContainer () |
| Check FindOrLoad_Component with Python Component on C++ Container load an engine, check that the CORBA object is not null. More... | |
| void | testFindOrLoad_Component_PythonSameInstance () |
| Check FindOrLoad_Component with Python Component on C++ Container. More... | |
| void | testFindOrLoad_Component_UnknownInCatalog () |
| Check FindOrLoad_Component with a component name not in catalog. More... | |
| void | testFindOrLoad_Component_LaunchContainerHostname () |
| Check FindOrLoad_Component with hostname given. More... | |
| void | testFindOrLoad_Component_SameContainer () |
| Check FindOrLoad_Component with and without local hostname given. More... | |
| void | testFindOrLoad_Component_UnknownMachine () |
| Check FindOrLoad_Component: check behaviour when ask for an unknown computer We must catch a Salome Exception with "unknown host" message. More... | |
| void | testFindOrLoad_Component_ParamsEmpty () |
| Check FindOrLoad_Component, empty params must give an instance. More... | |
| void | testFindOrLoad_Component_ParamsLocalContainer () |
| Check FindOrLoad_Component params = local container. More... | |
| void | testFindOrLoad_Component_ParamsContainerName () |
| Check FindOrLoad_Component params = containerName. More... | |
| void | testFindOrLoad_Component_RemoteComputer () |
| Check FindOrLoad_Component on remote computer. More... | |
| void | testFindOrLoad_Component_ParamsRemoteComputer () |
| Check FindOrLoad_Component with params on remote computer params empty except hostname. More... | |
| void | testFindOrLoad_Component_ParamsRemoteComputer2 () |
| Check FindOrLoad_Component with params on remote computer params empty except hostname and container_name. More... | |
| void | testgetLocalFile_localComputer () |
| Check SALOME_FileTransferCORBA on local machine. More... | |
| void | testgetLocalFile_remoteComputer () |
| Check SALOME_FileTransferCORBA on remote machine. More... | |
| std::string | GetRemoteHost () |
Protected Attributes | |
| CORBA::ORB_var | _orb |
| SALOME_NamingService | _NS |
private |
References GetTmpDir().
Referenced by setUp().
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
protected |
Get a remote HostName in the Resource Catalog
References _NS, Engines::ResourceParameters::can_run_containers, Engines::ResourceParameters::componentList, KERNEL_PY.batchmode_salome::obj, SALOME_LifeCycleCORBA::preSet(), SALOME_NamingService::Resolve(), and Engines::ContainerParameters::resource_params.
Referenced by testFindOrLoad_Component_ParamsRemoteComputer(), testFindOrLoad_Component_ParamsRemoteComputer2(), testFindOrLoad_Component_RemoteComputer(), and testgetLocalFile_remoteComputer().
| void LifeCycleCORBATest::setUp | ( | ) |
References _getTraceFileName(), _NS, _orb, KERNEL::GetRefToORB(), SALOME_NamingService::init_orb(), out, Utils_Identity::s, and traceFile.
| void LifeCycleCORBATest::tearDown | ( | ) |
| void LifeCycleCORBATest::testFindOrLoad_Component_LaunchContainer | ( | ) |
References _NS, SALOME_ContainerPy::containerName, and SALOME_LifeCycleCORBA::FindOrLoad_Component().
| void LifeCycleCORBATest::testFindOrLoad_Component_LaunchContainerHostname | ( | ) |
References _NS, SALOME_ContainerPy::containerName, DEVTRACE, and SALOME_LifeCycleCORBA::FindOrLoad_Component().
| void LifeCycleCORBATest::testFindOrLoad_Component_ParamsContainerName | ( | ) |
References _NS, Engines::ContainerParameters::container_name, SALOME_ContainerPy::containerName, SALOME_LifeCycleCORBA::FindOrLoad_Component(), and SALOME_LifeCycleCORBA::preSet().
| void LifeCycleCORBATest::testFindOrLoad_Component_ParamsEmpty | ( | ) |
References _NS, SALOME_LifeCycleCORBA::FindOrLoad_Component(), and SALOME_LifeCycleCORBA::preSet().
| void LifeCycleCORBATest::testFindOrLoad_Component_ParamsLocalContainer | ( | ) |
References _NS, SALOME_LifeCycleCORBA::FindOrLoad_Component(), Engines::ResourceParameters::hostname, test::hostname, SALOME_LifeCycleCORBA::preSet(), and Engines::ContainerParameters::resource_params.
| void LifeCycleCORBATest::testFindOrLoad_Component_ParamsRemoteComputer | ( | ) |
References _NS, SALOME_LifeCycleCORBA::FindOrLoad_Component(), GetRemoteHost(), Engines::ResourceParameters::hostname, SALOME_LifeCycleCORBA::preSet(), and Engines::ContainerParameters::resource_params.
| void LifeCycleCORBATest::testFindOrLoad_Component_ParamsRemoteComputer2 | ( | ) |
References _NS, Engines::ContainerParameters::container_name, SALOME_LifeCycleCORBA::FindOrLoad_Component(), GetRemoteHost(), Engines::ResourceParameters::hostname, SALOME_LifeCycleCORBA::preSet(), and Engines::ContainerParameters::resource_params.
| void LifeCycleCORBATest::testFindOrLoad_Component_PythonInCppContainer | ( | ) |
| void LifeCycleCORBATest::testFindOrLoad_Component_PythonSameInstance | ( | ) |
| void LifeCycleCORBATest::testFindOrLoad_Component_RemoteComputer | ( | ) |
References _NS, SALOME_ContainerPy::containerName, DEVTRACE, SALOME_LifeCycleCORBA::FindOrLoad_Component(), and GetRemoteHost().
| void LifeCycleCORBATest::testFindOrLoad_Component_SameContainer | ( | ) |
We must get the same container, the same instance of component
| void LifeCycleCORBATest::testFindOrLoad_Component_SameInstance | ( | ) |
| void LifeCycleCORBATest::testFindOrLoad_Component_UnknownInCatalog | ( | ) |
See list of catalog given to module catalog server. Here, we work with KERNEL_SRC/resources/KERNELCatalog.xml that contains only KERNEL, SalomeTestComponent and SALOME_TestComponentPy
| void LifeCycleCORBATest::testFindOrLoad_Component_UnknownMachine | ( | ) |
| void LifeCycleCORBATest::testgetLocalFile_localComputer | ( | ) |
References _NS, and SALOME_FileTransferCORBA::getLocalFile().
| void LifeCycleCORBATest::testgetLocalFile_remoteComputer | ( | ) |
References _NS, SALOME_FileTransferCORBA::getLocalFile(), and GetRemoteHost().
protected |
Referenced by GetRemoteHost(), setUp(), testFindOrLoad_Component_LaunchContainer(), testFindOrLoad_Component_LaunchContainerHostname(), testFindOrLoad_Component_ParamsContainerName(), testFindOrLoad_Component_ParamsEmpty(), testFindOrLoad_Component_ParamsLocalContainer(), testFindOrLoad_Component_ParamsRemoteComputer(), testFindOrLoad_Component_ParamsRemoteComputer2(), testFindOrLoad_Component_PythonInCppContainer(), testFindOrLoad_Component_PythonSameInstance(), testFindOrLoad_Component_RemoteComputer(), testFindOrLoad_Component_SameContainer(), testFindOrLoad_Component_SameInstance(), testFindOrLoad_Component_UnknownInCatalog(), testFindOrLoad_Component_UnknownMachine(), testgetLocalFile_localComputer(), and testgetLocalFile_remoteComputer().
protected |
Referenced by SALOME_Container.SALOME_Container_Abstract_i::__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::__init__(), SALOME_ContainerPy.SALOME_ContainerPy_i::__init__(), SALOME_ComponentPy.SALOME_ComponentPy_Gen_i::__init__(), SALOME_NamingServicePy.SALOME_NamingServicePy_i::__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i::create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i::create_pynode(), SALOME_Container.SALOME_Container_Abstract_i::create_pyscriptnode(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy::Register(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy::Resolve(), setUp(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::Shutdown().
