SALOME_Launcher Class Reference
#include <SALOME_Launcher.hxx>
Inheritance diagram for SALOME_Launcher:
 SALOME_Launcher (CORBA::ORB_ptr orb, PortableServer::POA_var poa)
 SALOME_Launcher (CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *externalNS)
virtual ~SALOME_Launcher ()
 destructor More...
CORBA::Long createJob (const Engines::JobParameters &job_parameters)
void launchJob (CORBA::Long job_id)
char * getJobState (CORBA::Long job_id)
char * getAssignedHostnames (CORBA::Long job_id)
void exportInputFiles (CORBA::Long job_id)
void getJobResults (CORBA::Long job_id, const char *directory)
void clearJobWorkingDir (CORBA::Long job_id)
CORBA::Boolean getJobDumpState (CORBA::Long job_id, const char *directory)
CORBA::Boolean getJobWorkFile (CORBA::Long job_id, const char *work_file, const char *directory)
void stopJob (CORBA::Long job_id)
void removeJob (CORBA::Long job_id)
char * dumpJob (CORBA::Long job_id)
CORBA::Long restoreJob (const char *dumpedJob)
CORBA::Long createJobWithFile (const char *xmlExecuteFile, const char *clusterName)
 CORBA Method: Create a job in the launcher with a file. More...
CORBA::Boolean testBatch (const Engines::ResourceParameters &params)
 CORBA Method: the test batch configuration. More...
void Shutdown ()
 CORBA method: shutdown all the containers, then the ContainerManager servant. More...
CORBA::Long getPID ()
 CORBA Method: Returns the PID of the process. More...
virtual void addObserver (Engines::SalomeLauncherObserver_ptr observer)
 CORBA Method: Add a new observer to the launcher. More...
virtual void removeObserver (Engines::SalomeLauncherObserver_ptr observer)
virtual Engines::JobsList * getJobsList ()
 CORBA Method: Returns current launcher jobs list. More...
virtual Engines::JobParameters * getJobParameters (CORBA::Long job_id)
 CORBA Method: Returns the job description. More...
virtual void loadJobs (const char *jobs_file)
 CORBA Method: Loads jobs saved in jobs_file. More...
virtual void saveJobs (const char *jobs_file)
 CORBA Method: Save jobs of Launcher (in any steps) in file jobs_file. More...
void DeclareUsingSalomeSession ()
SALOME_ResourcesManager * getResourcesManager () const
static JobParameters_cpp JobParameters_CORBA2CPP (const Engines::JobParameters &job_parameters)
static Engines::JobParameters_var JobParameters_CPP2CORBA (const JobParameters_cpp &job_parameters)
Static Public Attributes
static const char * _LauncherNameInNS = "/SalomeLauncher"
virtual void notifyObservers (const std::string &event_name, const std::string &event_data)
 Internal Method: Notify observers on a new event. More...
void init (CORBA::ORB_ptr orb, PortableServer::POA_var poa)
CORBA::ORB_var _orb
PortableServer::POA_var _poa
SALOME_ContainerManager * _ContManager
SALOME_ResourcesManager * _ResManager
SALOME_NamingService_Abstract * _NS = nullptr
std::list< Engines::SalomeLauncherObserver_var > _observers
Launcher_cpp _l
◆ SALOME_Launcher() [1/2]
SALOME_Launcher::SALOME_Launcher ( CORBA::ORB_ptr  orb,
orb
References _NS, init(), MESSAGE, salome::orb, and SALOME_ContainerPy::poa.
◆ SALOME_Launcher() [2/2]
SALOME_NamingService_Abstract *  externalNS
◆ ~SALOME_Launcher()
SALOME_Launcher::~SALOME_Launcher ( )
destructor
References _NS, and MESSAGE.
◆ addObserver()
void SALOME_Launcher::addObserver ( Engines::SalomeLauncherObserver_ptr  observer)
References _l, _observers, _orb, Launcher_cpp::getJobs(), launcher_use_case::job_id, and MESSAGE.
◆ clearJobWorkingDir()
void SALOME_Launcher::clearJobWorkingDir ( CORBA::Long  job_id)
◆ createJob()
◆ createJobWithFile()
CORBA::Long SALOME_Launcher::createJobWithFile ( const char *  xmlExecuteFile,
const char *  clusterName
xmlExecuteFile: .xml to parse that contains job description
clusterName: machine chosen
References _l, Launcher_cpp::createJobWithFile(), SALOME::INTERNAL_ERROR, LauncherException::msg, and THROW_SALOME_CORBA_EXCEPTION.
◆ DeclareUsingSalomeSession()
void SALOME_Launcher::DeclareUsingSalomeSession ( )
◆ dumpJob()
◆ exportInputFiles()
void SALOME_Launcher::exportInputFiles ( CORBA::Long  job_id)
◆ getAssignedHostnames()
char * SALOME_Launcher::getAssignedHostnames ( CORBA::Long  job_id)
◆ getJobDumpState()
CORBA::Boolean SALOME_Launcher::getJobDumpState ( CORBA::Long  job_id,
const char *  directory
◆ getJobParameters()
Engines::JobParameters * SALOME_Launcher::getJobParameters ( CORBA::Long  job_id)
◆ getJobResults()
void SALOME_Launcher::getJobResults ( CORBA::Long  job_id,
◆ getJobsList()
Engines::JobsList * SALOME_Launcher::getJobsList ( )
References _l, getJobParameters(), and Launcher_cpp::getJobs().
◆ getJobState()
char * SALOME_Launcher::getJobState ( CORBA::Long  job_id)
◆ getJobWorkFile()
CORBA::Boolean SALOME_Launcher::getJobWorkFile ( CORBA::Long  job_id,
const char *  work_file,
◆ getPID()
CORBA::Long SALOME_Launcher::getPID ( )
◆ getResourcesManager()
SALOME_ResourcesManager * SALOME_Launcher::getResourcesManager ( ) const
◆ init()
◆ JobParameters_CORBA2CPP()
JobParameters_cpp SALOME_Launcher::JobParameters_CORBA2CPP ( const Engines::JobParameters &  job_parameters)
References Engines::JobParameters::env_file, JobParameters_cpp::env_file, Engines::JobParameters::exclusive, JobParameters_cpp::exclusive, Engines::JobParameters::extra_params, JobParameters_cpp::extra_params, Engines::JobParameters::in_files, JobParameters_cpp::in_files, Engines::JobParameters::job_file, JobParameters_cpp::job_file, Engines::JobParameters::job_name, JobParameters_cpp::job_name, Engines::JobParameters::job_type, JobParameters_cpp::job_type, Engines::JobParameters::launcher_args, JobParameters_cpp::launcher_args, Engines::JobParameters::launcher_file, JobParameters_cpp::launcher_file, Engines::JobParameters::local_directory, JobParameters_cpp::local_directory, Engines::JobParameters::maximum_duration, JobParameters_cpp::maximum_duration, Engines::JobParameters::mem_per_cpu, JobParameters_cpp::mem_per_cpu, Engines::JobParameters::out_files, JobParameters_cpp::out_files, Engines::JobParameters::partition, JobParameters_cpp::partition, Engines::JobParameters::pre_command, JobParameters_cpp::pre_command, Engines::JobParameters::queue, JobParameters_cpp::queue, Engines::JobParameters::resource_required, JobParameters_cpp::resource_required, resourceParameters_CORBAtoCPP(), Engines::JobParameters::result_directory, JobParameters_cpp::result_directory, Engines::JobParameters::specific_parameters, JobParameters_cpp::specific_parameters, Engines::JobParameters::verbose_py_log_level, JobParameters_cpp::verbose_py_log_level, Engines::JobParameters::wckey, JobParameters_cpp::wckey, Engines::JobParameters::work_directory, and JobParameters_cpp::work_directory.
Referenced by createJob().
◆ JobParameters_CPP2CORBA()
◆ launchJob()
void SALOME_Launcher::launchJob ( CORBA::Long  job_id)
◆ loadJobs()
void SALOME_Launcher::loadJobs ( const char *  jobs_file)
◆ notifyObservers()
void SALOME_Launcher::notifyObservers ( const std::string &  event_name,
const std::string &  event_data
References _observers, and MESSAGE.
Referenced by createJob(), loadJobs(), removeJob(), restoreJob(), saveJobs(), and stopJob().
◆ removeJob()
◆ removeObserver()
void SALOME_Launcher::removeObserver ( Engines::SalomeLauncherObserver_ptr  observer)
References _observers, and _orb.
◆ restoreJob()
CORBA::Long SALOME_Launcher::restoreJob ( const char *  dumpedJob)
◆ saveJobs()
void SALOME_Launcher::saveJobs ( const char *  jobs_file)
References _l, notifyObservers(), and Launcher_cpp::saveJobs().
◆ Shutdown()
void SALOME_Launcher::Shutdown ( )
◆ stopJob()
◆ testBatch()
◆ _ContManager
SALOME_ContainerManager* SALOME_Launcher::_ContManager
◆ _l
◆ _LauncherNameInNS
const char * SALOME_Launcher::_LauncherNameInNS = "/SalomeLauncher"
Referenced by init(), and Shutdown().
◆ _NS
SALOME_NamingService_Abstract* SALOME_Launcher::_NS = nullptr
◆ _observers
std::list<Engines::SalomeLauncherObserver_var> SALOME_Launcher::_observers
◆ _orb
◆ _poa
◆ _ResManager
SALOME_ResourcesManager* SALOME_Launcher::_ResManager
Referenced by init(), Shutdown(), and testBatch().
