JobParameters_cpp Struct Reference
#include <Launcher.hxx>
Data Fields
std::string job_name
std::string job_type
std::string job_file
std::string pre_command
std::string env_file
std::list< std::string > in_files
std::list< std::string > out_files
std::string work_directory
std::string local_directory
std::string result_directory
std::string maximum_duration
resourceParams resource_required
std::string queue
std::string partition
std::string verbose_py_log_level
bool exclusive
unsigned int mem_per_cpu
std::string wckey
std::string extra_params
std::map< std::string, std::string > specific_parameters
std::string launcher_file
std::string launcher_args
◆ env_file
std::string JobParameters_cpp::env_file
◆ exclusive
◆ extra_params
std::string JobParameters_cpp::extra_params
◆ in_files
std::list<std::string> JobParameters_cpp::in_files
◆ job_file
std::string JobParameters_cpp::job_file
◆ job_name
std::string JobParameters_cpp::job_name
◆ job_type
std::string JobParameters_cpp::job_type
◆ launcher_args
std::string JobParameters_cpp::launcher_args
◆ launcher_file
std::string JobParameters_cpp::launcher_file
◆ local_directory
std::string JobParameters_cpp::local_directory
◆ maximum_duration
std::string JobParameters_cpp::maximum_duration
◆ mem_per_cpu
unsigned int JobParameters_cpp::mem_per_cpu
◆ out_files
std::list<std::string> JobParameters_cpp::out_files
◆ partition
std::string JobParameters_cpp::partition
◆ pre_command
std::string JobParameters_cpp::pre_command
◆ queue
std::string JobParameters_cpp::queue
◆ resource_required
◆ result_directory
std::string JobParameters_cpp::result_directory
◆ specific_parameters
std::map<std::string, std::string> JobParameters_cpp::specific_parameters
◆ verbose_py_log_level
std::string JobParameters_cpp::verbose_py_log_level
◆ wckey
std::string JobParameters_cpp::wckey
◆ work_directory
std::string JobParameters_cpp::work_directory
