Launcher_cpp Class Reference
#include <Launcher.hxx>
 Launcher_cpp ()
virtual ~Launcher_cpp ()
 destructor More...
void createJob (Launcher::Job *new_job)
int createJob (const JobParameters_cpp &job_parameters)
void launchJob (int job_id)
std::string getJobState (int job_id)
std::string getAssignedHostnames (int job_id)
void exportInputFiles (int job_id)
void getJobResults (int job_id, std::string directory)
void clearJobWorkingDir (int job_id)
bool getJobDumpState (int job_id, std::string directory)
bool getJobWorkFile (int job_id, std::string work_file, std::string directory)
long getMaximumDurationInSecond (int job_id)
void stopJob (int job_id)
void removeJob (int job_id)
std::string dumpJob (int job_id)
int restoreJob (const std::string &dumpedJob)
JobParameters_cpp getJobParameters (int job_id)
std::list< int > loadJobs (const char *jobs_file)
 Load the jobs from the file "jobs_file" and add them to the Launcher. More...
void saveJobs (const char *jobs_file)
 Save the jobs of the Launcher to the file "jobs_file". More...
long createJobWithFile (std::string xmlExecuteFile, std::string clusterName)
std::map< int, Launcher::Job * > getJobs ()
void addJobDirectlyToMap (Launcher::Job *new_job)
Launcher::Job * findJob (int job_id)
void SetResourcesManager (std::shared_ptr< ResourcesManager_cpp > &rm)
virtual void notifyObservers (const std::string &, const std::string &)
int addJob (Launcher::Job *new_job)
ParserLauncherType ParseXmlFile (std::string xmlExecuteFile)
std::shared_ptr< ResourcesManager_cpp > _ResManager
std::map< int, Launcher::Job * > _launcher_job_map
int _job_cpt
◆ Launcher_cpp()
Launcher_cpp::Launcher_cpp ( )
orbDefine a CORBA single thread policy for the server, which avoid to deal with non thread-safe usage like Change_Directory in SALOME naming service
References _job_cpt, and LAUNCHER_MESSAGE.
◆ ~Launcher_cpp()
Launcher_cpp::~Launcher_cpp ( )
destructor
References _launcher_job_map, and LAUNCHER_MESSAGE.
◆ addJob()
◆ addJobDirectlyToMap()
◆ clearJobWorkingDir()
void Launcher_cpp::clearJobWorkingDir ( int  job_id)
◆ createJob() [1/2]
int Launcher_cpp::createJob ( const JobParameters_cpp &  job_parameters)
References LAUNCHER_INFOS.
◆ createJob() [2/2]
void Launcher_cpp::createJob ( Launcher::Job *  new_job)
Referenced by addJob(), and SALOME_Launcher::createJob().
◆ createJobWithFile()
long Launcher_cpp::createJobWithFile ( std::string  xmlExecuteFile,
◆ dumpJob()
std::string Launcher_cpp::dumpJob ( int  job_id)
Referenced by SALOME_Launcher::dumpJob().
◆ exportInputFiles()
void Launcher_cpp::exportInputFiles ( int  job_id)
◆ findJob()
Launcher::Job * Launcher_cpp::findJob ( int  job_id)
◆ getAssignedHostnames()
std::string Launcher_cpp::getAssignedHostnames ( int  job_id)
◆ getJobDumpState()
bool Launcher_cpp::getJobDumpState ( int  job_id,
◆ getJobParameters()
JobParameters_cpp Launcher_cpp::getJobParameters ( int  job_id)
◆ getJobResults()
void Launcher_cpp::getJobResults ( int  job_id,
◆ getJobs()
std::map< int, Launcher::Job * > Launcher_cpp::getJobs ( )
◆ getJobState()
std::string Launcher_cpp::getJobState ( int  job_id)
Referenced by SALOME_Launcher::getJobState().
◆ getJobWorkFile()
bool Launcher_cpp::getJobWorkFile ( int  job_id,
◆ getMaximumDurationInSecond()
long Launcher_cpp::getMaximumDurationInSecond ( int  job_id)
◆ launchJob()
void Launcher_cpp::launchJob ( int  job_id)
Referenced by SALOME_Launcher::launchJob(), and main().
◆ loadJobs()
list< int > Launcher_cpp::loadJobs ( const char *  jobs_file)
Return a list with the IDs of the jobs that were successfully loaded.
References addJob(), LAUNCHER_INFOS, Launcher::XML_Persistence::loadJobs(), and LauncherException::msg.
Referenced by SALOME_Launcher::loadJobs().
◆ notifyObservers()
virtual void Launcher_cpp::notifyObservers ( const std::string &  ,
const std::string &
◆ ParseXmlFile()
ParserLauncherType Launcher_cpp::ParseXmlFile ( std::string  xmlExecuteFile)
◆ removeJob()
void Launcher_cpp::removeJob ( int  job_id)
Referenced by SALOME_Launcher::removeJob().
◆ restoreJob()
int Launcher_cpp::restoreJob ( const std::string &  dumpedJob)
Referenced by SALOME_Launcher::restoreJob().
◆ saveJobs()
void Launcher_cpp::saveJobs ( const char *  jobs_file)
References _job_cpt, _launcher_job_map, and Launcher::XML_Persistence::saveJobs().
Referenced by SALOME_Launcher::saveJobs().
◆ SetResourcesManager()
void Launcher_cpp::SetResourcesManager ( std::shared_ptr< ResourcesManager_cpp > &  rm)
References salome::rm.
Referenced by SALOME_Launcher::init(), and main().
◆ stopJob()
void Launcher_cpp::stopJob ( int  job_id)
◆ _job_cpt
int Launcher_cpp::_job_cpt
◆ _launcher_job_map
std::map<int, Launcher::Job *> Launcher_cpp::_launcher_job_map
◆ _ResManager
std::shared_ptr<ResourcesManager_cpp> Launcher_cpp::_ResManager
