ResourcesManager_cpp Class Reference
#include <ResourcesManager.hxx>
 ResourcesManager_cpp (const char *xmlFilePath)
 just for test More...
 ResourcesManager_cpp ()
 Standard constructor, parse resource file. More...
 ~ResourcesManager_cpp ()
 Standard Destructor. More...
std::vector< std::string > GetFittingResources (const resourceParams &params)
 get the list of resource names fitting constraints given by params More...
std::string Find (const std::string &policy, const std::vector< std::string > &listOfResources) const
 threadsafe More...
void AddResourceInCatalogNoQuestion (const ParserResourcesType &new_resource)
void AddResourceInCatalog (const ParserResourcesType &new_resource)
 add an entry in the resources catalog xml file. More...
void DeleteAllResourcesInCatalog ()
void DeleteResourceInCatalog (const char *name)
 Deletes a resource from the catalog. More...
void WriteInXmlFile (std::string xml_file)
 write the current data in memory in file. More...
const MapOfParserResourcesType & ParseXmlFiles ()
 parse the data type catalog More...
const MapOfParserResourcesType & GetList () const
 consult the content of the list More...
ParserResourcesType GetResourcesDescr (const std::string &name) const
 thread safe More...
void SelectOnlyResourcesWithOS (std::vector< std::string > &resources, std::string OS)
 Gives a sublist of resources with matching OS. More...
void KeepOnlyResourcesWithComponent (std::vector< std::string > &resources, const std::vector< std::string > &componentList)
 Gives a sublist of machines on which the component is known. More...
void AddDefaultResourceInCatalog ()
 Add the default local resource in the catalog. More...
std::list< std::string > _path_resources
 will contain the path to the resources catalog More...
std::list< std::string >::iterator _path_resources_it
MapOfParserResourcesType _resourcesList
 will contain the information on the data type catalog(after parsing) More...
std::map< std::string, LoadRateManager * > _resourceManagerMap
 a map that contains all the available load rate managers (the key is the name) More...
time_t _lasttime = 0
 contain the time where resourcesList was created More...
Static Protected Attributes
static const std::string DEFAULT_RESOURCE_NAME = "localhost"
 the name of the default local resource More...
◆ ResourcesManager_cpp() [1/2]
ResourcesManager_cpp::ResourcesManager_cpp ( const char *  xmlFilePath)
◆ ResourcesManager_cpp() [2/2]
ResourcesManager_cpp::ResourcesManager_cpp ( )
  • if ${APPLI} exists in environment, look for ${HOME}/${APPLI}/CatalogResources.xml
  • else look for default: ${KERNEL_ROOT_DIR}/share/salome/resources/kernel/CatalogResources.xml
  • parse XML resource file.
References _path_resources, _resourceManagerMap, AddDefaultResourceInCatalog(), altcycl, cycl, first, ParseXmlFiles(), and RES_MESSAGE.
◆ ~ResourcesManager_cpp()
ResourcesManager_cpp::~ResourcesManager_cpp ( )
References RES_MESSAGE.
◆ AddDefaultResourceInCatalog()
◆ AddResourceInCatalog()
◆ AddResourceInCatalogNoQuestion()
void ResourcesManager_cpp::AddResourceInCatalogNoQuestion ( const ParserResourcesType &  new_resource)
◆ DeleteAllResourcesInCatalog()
void ResourcesManager_cpp::DeleteAllResourcesInCatalog ( )
References _resourcesList.
◆ DeleteResourceInCatalog()
void ResourcesManager_cpp::DeleteResourceInCatalog ( const char *  name)
References _resourcesList, DEFAULT_RESOURCE_NAME, IDLparser::error(), pythfilter::name, and RES_INFOS.
◆ Find()
std::string ResourcesManager_cpp::Find ( const std::string &  policy,
const std::vector< std::string > &  listOfResources
threadsafe
References _resourceManagerMap, and _resourcesList.
◆ GetFittingResources()
std::vector< std::string > ResourcesManager_cpp::GetFittingResources ( const resourceParams &  params)
Steps: 1: Restrict list with resourceList if defined 2: If name is defined -> check resource list 3: If not 2:, if hostname is defined -> check resource list 4: If not 3:, sort resource with nb_proc, etc... 5: In all cases remove resource that does not correspond with OS 6: And remove resource with componentList - if list is empty ignored it...
References ResourceDataToSort::_CPUFreqMHzWanted, ResourceDataToSort::_memInMBWanted, ResourceDataToSort::_nbOfNodesWanted, ResourceDataToSort::_nbOfProcPerNodeWanted, ResourceDataToSort::_nbOfProcWanted, _resourcesList, resourceParams::can_launch_batch_jobs, resourceParams::can_run_containers, resourceParams::componentList, resourceParams::cpu_clock, IDLparser::error(), test::hostname, resourceParams::hostname, KeepOnlyResourcesWithComponent(), resourceParams::mem_mb, resourceParams::name, resourceParams::nb_node, resourceParams::nb_proc, resourceParams::nb_proc_per_node, resourceParams::OS, ParseXmlFiles(), RES_MESSAGE, resourceParams::resourceList, and SelectOnlyResourcesWithOS().
◆ GetList()
const MapOfParserResourcesType & ResourcesManager_cpp::GetList ( ) const
◆ GetResourcesDescr()
ParserResourcesType ResourcesManager_cpp::GetResourcesDescr ( const std::string &  name) const
thread safe
References _resourcesList, IDLparser::error(), and pythfilter::name.
◆ KeepOnlyResourcesWithComponent()
void ResourcesManager_cpp::KeepOnlyResourcesWithComponent ( std::vector< std::string > &  resources,
const std::vector< std::string > &  componentList
Referenced by GetFittingResources().
◆ ParseXmlFiles()
◆ SelectOnlyResourcesWithOS()
void ResourcesManager_cpp::SelectOnlyResourcesWithOS ( std::vector< std::string > &  resources,
std::string  OS
If parameter OS is empty, gives the complete list of resources
◆ WriteInXmlFile()
void ResourcesManager_cpp::WriteInXmlFile ( std::string  xml_file)
◆ _lasttime
time_t ResourcesManager_cpp::_lasttime = 0
Referenced by ParseXmlFiles().
◆ _path_resources
std::list<std::string> ResourcesManager_cpp::_path_resources
Referenced by ParseXmlFiles(), ResourcesManager_cpp(), and WriteInXmlFile().
◆ _path_resources_it
std::list<std::string>::iterator ResourcesManager_cpp::_path_resources_it
Referenced by ParseXmlFiles(), and WriteInXmlFile().
◆ _resourceManagerMap
std::map<std::string , LoadRateManager*> ResourcesManager_cpp::_resourceManagerMap
Referenced by Find(), and ResourcesManager_cpp().
◆ _resourcesList
◆ DEFAULT_RESOURCE_NAME
const string ResourcesManager_cpp::DEFAULT_RESOURCE_NAME = "localhost"
staticprotected
Referenced by AddDefaultResourceInCatalog(), AddResourceInCatalog(), DeleteResourceInCatalog(), and ParseXmlFiles().
