SALOME_ResourcesCatalog_Handler Class Reference
#include <SALOME_ResourcesCatalog_Handler.hxx>
 SALOME_ResourcesCatalog_Handler (MapOfParserResourcesType &resources_list)
const MapOfParserResourcesType & GetResourcesAfterParsing () const
 Retrieves DS after the file parse. More...
virtual ~SALOME_ResourcesCatalog_Handler ()
void ProcessXmlDocument (xmlDocPtr theDoc)
 Processes XML document and fills the list of resources. More...
bool ProcessMachine (xmlNodePtr machine_descr, ParserResourcesType &resource)
bool ProcessCluster (xmlNodePtr cluster_descr, ParserResourcesType &resource)
bool ProcessMember (xmlNodePtr member_descr, ParserResourcesType &resource)
void PrepareDocToXmlFile (xmlDocPtr theDoc)
 Fill the document tree in xml file, used to write in an xml file. More...
std::string previous_component_name
MapOfParserResourcesType & _resources_list
const char * test_machine
const char * test_cluster
const char * test_name
const char * test_hostname
const char * test_type
const char * test_protocol
const char * test_cluster_internal_protocol
const char * test_batch
const char * test_mpi
const char * test_user_name
const char * test_appli_path
const char * test_can_launch_batch_jobs
const char * test_can_run_containers
const char * test_modules
const char * test_module_name
const char * test_components
const char * test_component_name
const char * test_os
const char * test_mem_in_mb
const char * test_cpu_freq_mhz
const char * test_nb_of_nodes
const char * test_nb_of_proc
const char * test_nb_of_proc_per_node
const char * test_batch_queue
const char * test_user_commands
const char * test_members
const char * test_working_directory
const char * test_mode
const char * test_is_cluster_head
◆ SALOME_ResourcesCatalog_Handler()
◆ ~SALOME_ResourcesCatalog_Handler()
SALOME_ResourcesCatalog_Handler::~SALOME_ResourcesCatalog_Handler ( )
◆ GetResourcesAfterParsing()
const MapOfParserResourcesType & SALOME_ResourcesCatalog_Handler::GetResourcesAfterParsing ( ) const
References _resources_list.
◆ PrepareDocToXmlFile()
◆ ProcessCluster()
◆ ProcessMachine()
bool SALOME_ResourcesCatalog_Handler::ProcessMachine ( xmlNodePtr  machine_descr,
ParserResourcesType &  resource
References ResourceDataToSort::_CPUFreqMHz, ResourceDataToSort::_memInMB, ResourceDataToSort::_Name, ResourceDataToSort::_nbOfNodes, ResourceDataToSort::_nbOfProcPerNode, ParserResourcesType::AppliPath, ParserResourcesType::batchQueue, ParserResourcesType::can_launch_batch_jobs, ParserResourcesType::can_run_containers, cluster, ParserResourcesType::ClusterInternalProtocol, ParserResourcesType::ComponentsList, ParserResourcesType::DataForSort, ParserResourcesType::getAccessProtocolTypeStr(), ParserResourcesType::getBatchTypeStr(), ParserResourcesType::getCanLaunchBatchJobsStr(), ParserResourcesType::getCanRunContainersStr(), ParserResourcesType::getClusterInternalProtocolStr(), ParserResourcesType::getMpiImplTypeStr(), ParserResourcesType::getResourceTypeStr(), test::hostname, ParserResourcesType::HostName, MESSAGE, ParserResourcesType::ModulesList, pythfilter::name, ParserResourcesType::Name, ParserResourcesType::OS, ParserResourcesType::Protocol, ParserResourcesType::setAccessProtocolTypeStr(), ParserResourcesType::setBatchTypeStr(), ParserResourcesType::setCanLaunchBatchJobsStr(), ParserResourcesType::setCanRunContainersStr(), ParserResourcesType::setClusterInternalProtocolStr(), ParserResourcesType::setMpiImplTypeStr(), ParserResourcesType::setResourceTypeStr(), single_machine, test_appli_path, test_batch, test_batch_queue, test_can_launch_batch_jobs, test_can_run_containers, test_cluster_internal_protocol, test_component_name, test_components, test_cpu_freq_mhz, test_hostname, test_is_cluster_head, test_mem_in_mb, test_mode, test_module_name, test_modules, test_mpi, test_name, test_nb_of_nodes, test_nb_of_proc_per_node, test_os, test_protocol, test_type, test_user_commands, test_user_name, test_working_directory, ParserResourcesType::type, ParserResourcesType::userCommands, ParserResourcesType::UserName, and ParserResourcesType::working_directory.
Referenced by ProcessXmlDocument().
◆ ProcessMember()
◆ ProcessXmlDocument()
void SALOME_ResourcesCatalog_Handler::ProcessXmlDocument ( xmlDocPtr  theDoc)
◆ _resources_list
MapOfParserResourcesType& SALOME_ResourcesCatalog_Handler::_resources_list
◆ previous_component_name
std::string SALOME_ResourcesCatalog_Handler::previous_component_name
◆ test_appli_path
const char* SALOME_ResourcesCatalog_Handler::test_appli_path
◆ test_batch
const char* SALOME_ResourcesCatalog_Handler::test_batch
◆ test_batch_queue
const char* SALOME_ResourcesCatalog_Handler::test_batch_queue
◆ test_can_launch_batch_jobs
const char* SALOME_ResourcesCatalog_Handler::test_can_launch_batch_jobs
◆ test_can_run_containers
const char* SALOME_ResourcesCatalog_Handler::test_can_run_containers
◆ test_cluster
const char* SALOME_ResourcesCatalog_Handler::test_cluster
◆ test_cluster_internal_protocol
const char* SALOME_ResourcesCatalog_Handler::test_cluster_internal_protocol
◆ test_component_name
const char* SALOME_ResourcesCatalog_Handler::test_component_name
◆ test_components
const char* SALOME_ResourcesCatalog_Handler::test_components
◆ test_cpu_freq_mhz
const char* SALOME_ResourcesCatalog_Handler::test_cpu_freq_mhz
◆ test_hostname
const char* SALOME_ResourcesCatalog_Handler::test_hostname
◆ test_is_cluster_head
const char* SALOME_ResourcesCatalog_Handler::test_is_cluster_head
◆ test_machine
const char* SALOME_ResourcesCatalog_Handler::test_machine
◆ test_mem_in_mb
const char* SALOME_ResourcesCatalog_Handler::test_mem_in_mb
◆ test_members
const char* SALOME_ResourcesCatalog_Handler::test_members
◆ test_mode
const char* SALOME_ResourcesCatalog_Handler::test_mode
◆ test_module_name
const char* SALOME_ResourcesCatalog_Handler::test_module_name
◆ test_modules
const char* SALOME_ResourcesCatalog_Handler::test_modules
◆ test_mpi
const char* SALOME_ResourcesCatalog_Handler::test_mpi
◆ test_name
const char* SALOME_ResourcesCatalog_Handler::test_name
◆ test_nb_of_nodes
const char* SALOME_ResourcesCatalog_Handler::test_nb_of_nodes
◆ test_nb_of_proc
const char* SALOME_ResourcesCatalog_Handler::test_nb_of_proc
◆ test_nb_of_proc_per_node
const char* SALOME_ResourcesCatalog_Handler::test_nb_of_proc_per_node
◆ test_os
const char* SALOME_ResourcesCatalog_Handler::test_os
◆ test_protocol
const char* SALOME_ResourcesCatalog_Handler::test_protocol
◆ test_type
const char* SALOME_ResourcesCatalog_Handler::test_type
◆ test_use
const char* SALOME_ResourcesCatalog_Handler::test_use
◆ test_user_commands
const char* SALOME_ResourcesCatalog_Handler::test_user_commands
◆ test_user_name
const char* SALOME_ResourcesCatalog_Handler::test_user_name
◆ test_working_directory
const char* SALOME_ResourcesCatalog_Handler::test_working_directory
