Launcher::XML_Persistence Class Reference
#include <Launcher_XML_Persistence.hxx>
virtual ~XML_Persistence ()
static std::list< Job * > loadJobs (const char *jobs_file)
 Load the jobs from the XML file "jobs_file". More...
static void saveJobs (const char *jobs_file, const std::list< const Job * > &jobs_list)
 Save the jobs in the list "jobs_list" to the XML file "jobs_file". More...
static Job * createJobFromString (const std::string &jobDump)
static std::string dumpJob (const Job &job)
 XML_Persistence ()
static void addJobToXmlDocument (xmlNodePtr root_node, const Job &job)
static Job * createJobFromXmlNode (xmlNodePtr job_node)
static void parseUserNode (Job *new_job, xmlNodePtr user_node)
static void parseRunNode (Job *new_job, xmlNodePtr run_node)
static void parseResourceNode (Job *new_job, xmlNodePtr res_node)
static std::string getAttrValue (xmlNodePtr node, const std::string &attrName)
static std::string xmlStrToString (const xmlChar *xmlStr)
static std::string getNodeContent (xmlNodePtr node)
template<typename T >
static T getNumericalNodeContent (xmlNodePtr node)
static xmlNodePtr addNode (xmlNodePtr father, const std::string &name, const std::string &content)
static xmlNodePtr addNumericalNode (xmlNodePtr father, const std::string &name, T content)
static void addAttr (xmlNodePtr node, const std::string &name, const std::string &value)
◆ ~XML_Persistence()
virtual Launcher::XML_Persistence::~XML_Persistence ( )
◆ XML_Persistence()
Launcher::XML_Persistence::XML_Persistence ( )
◆ addAttr()
void Launcher::XML_Persistence::addAttr ( xmlNodePtr  node,
const std::string &  name,
const std::string &  value
staticprivate
References pythfilter::name.
Referenced by addJobToXmlDocument().
◆ addJobToXmlDocument()
◆ addNode()
xmlNodePtr Launcher::XML_Persistence::addNode ( xmlNodePtr  father,
const std::string &  content
staticprivate
◆ addNumericalNode()
xmlNodePtr Launcher::XML_Persistence::addNumericalNode ( xmlNodePtr  father,
T  content
staticprivate
References addNode(), and pythfilter::name.
◆ createJobFromString()
Job * Launcher::XML_Persistence::createJobFromString ( const std::string &  jobDump)
◆ createJobFromXmlNode()
◆ dumpJob()
std::string Launcher::XML_Persistence::dumpJob ( const Job &  job)
References addJobToXmlDocument().
◆ getAttrValue()
string Launcher::XML_Persistence::getAttrValue ( xmlNodePtr  node,
const std::string &  attrName
staticprivate
Referenced by createJobFromXmlNode().
◆ getNodeContent()
string Launcher::XML_Persistence::getNodeContent ( xmlNodePtr  node)
staticprivate
◆ getNumericalNodeContent()
T Launcher::XML_Persistence::getNumericalNodeContent ( xmlNodePtr  node)
staticprivate
◆ loadJobs()
list< Job * > Launcher::XML_Persistence::loadJobs ( const char *  jobs_file)
Return a list with the jobs that were successfully loaded. The ownership of the created jobs is transferred to the caller.
References createJobFromXmlNode(), IDLparser::error(), LAUNCHER_INFOS, and xmlStrToString().
Referenced by Launcher_cpp::loadJobs().
◆ parseResourceNode()
◆ parseRunNode()
void Launcher::XML_Persistence::parseRunNode ( Job *  new_job,
xmlNodePtr  run_node
staticprivate
◆ parseUserNode()
◆ saveJobs()
void Launcher::XML_Persistence::saveJobs ( const char *  jobs_file,
const std::list< const Job * > &  jobs_list
References addJobToXmlDocument(), IDLparser::error(), LAUNCHER_INFOS, and LAUNCHER_MESSAGE.
Referenced by Launcher_cpp::saveJobs().
◆ xmlStrToString()
string Launcher::XML_Persistence::xmlStrToString ( const xmlChar *  xmlStr)
staticprivate
