Launcher::Job_CommandSALOME Class Reference
#include <Launcher_Job_CommandSALOME.hxx>
Inheritance diagram for Launcher::Job_CommandSALOME:
 Job_CommandSALOME ()
virtual ~Job_CommandSALOME ()
virtual void update_job ()
void setState (const std::string &state)
std::string getState () const
std::string getAssignedHostnames ()
void setNumber (const int &number)
int getNumber ()
virtual void setResourceDefinition (const ParserResourcesType &resource_definition)
ParserResourcesType getResourceDefinition () const
void setJobName (const std::string &job_name)
virtual void setJobFile (const std::string &job_file)
void setPreCommand (const std::string &preCommand)
void setWorkDirectory (const std::string &work_directory)
void setLocalDirectory (const std::string &local_directory)
void setResultDirectory (const std::string &result_directory)
void add_in_file (const std::string &file)
void add_out_file (const std::string &file)
void setMaximumDuration (const std::string &maximum_duration)
void setResourceRequiredParams (const resourceParams &resource_required_params)
void setQueue (const std::string &queue)
void setPartition (const std::string &partition)
void setEnvFile (const std::string &env_file)
void setExclusive (bool exclusive)
void setExclusiveStr (const std::string &exclusiveStr)
void setMemPerCpu (unsigned long mem_per_cpu)
void setWCKey (const std::string &wckey)
void setExtraParams (const std::string &extra_params)
void setReference (const std::string &reference)
void setVerbosePyLogLevel (const std::string &verbosePyLogLevel)
void setLauncherFile (const std::string &launcher_file)
void setLauncherArgs (const std::string &launcher_args)
std::string getJobName () const
std::string getJobFile () const
std::string getPreCommand () const
std::string getWorkDirectory () const
std::string getLocalDirectory () const
std::string getResultDirectory () const
const std::list< std::string > & get_in_files () const
const std::list< std::string > & get_out_files () const
std::string getMaximumDuration () const
long getMaximumDurationInSecond () const
resourceParams getResourceRequiredParams () const
std::string getQueue () const
std::string getPartition () const
std::string getEnvFile () const
std::string getJobType () const
bool getExclusive () const
std::string getExclusiveStr () const
unsigned long getMemPerCpu () const
std::string getWCKey () const
std::string getExtraParams () const
std::string getReference () const
std::string getVerbosePyLogLevel () const
std::string getLauncherFile () const
std::string getLauncherArgs () const
std::string updateJobState ()
void addSpecificParameter (const std::string &name, const std::string &value)
const std::map< std::string, std::string > & getSpecificParameters () const
virtual void checkSpecificParameters ()
void checkMaximumDuration (const std::string &maximum_duration)
void checkResourceRequiredParams (const resourceParams &resource_required_params)
long convertMaximumDuration (const std::string &maximum_duration)
std::string getLaunchDate () const
void stopJob ()
void removeJob ()
Static Public Attributes
static const char TYPE_NAME [] = "command_salome"
int _number
std::string _job_type
std::string _state
std::string _assigned_hostnames
std::string _launch_date
std::string _env_file
ParserResourcesType _resource_definition
std::string _job_name
std::string _job_file
std::string _job_file_name
std::string _job_file_name_complete
std::string _pre_command
std::string _work_directory
std::string _local_directory
std::string _result_directory
std::list< std::string > _in_files
std::list< std::string > _out_files
std::map< std::string, std::string > _specific_parameters
std::string _maximum_duration
long _maximum_duration_in_second
resourceParams _resource_required_params
std::string _queue
std::string _partition
bool _exclusive
unsigned long _mem_per_cpu
std::string _wckey
std::string _extra_params
std::string _reference
std::string _verbose_py_log_level
 Reference of the job for the batch manager. More...
std::string _launcher_file
 same semantics than driver –verbose_level More...
std::string _launcher_args
int _cnt = 1
◆ Job_CommandSALOME()
Launcher::Job_CommandSALOME::Job_CommandSALOME ( )
◆ ~Job_CommandSALOME()
Launcher::Job_CommandSALOME::~Job_CommandSALOME ( )
◆ add_in_file()
void Launcher::Job::add_in_file ( const std::string &  file)
◆ add_out_file()
void Launcher::Job::add_out_file ( const std::string &  file)
◆ addSpecificParameter()
void Launcher::Job::addSpecificParameter ( const std::string &  name,
const std::string &  value
◆ checkMaximumDuration()
void Launcher::Job::checkMaximumDuration ( const std::string &  maximum_duration)
◆ checkResourceRequiredParams()
void Launcher::Job::checkResourceRequiredParams ( const resourceParams &  resource_required_params)
◆ checkSpecificParameters()
void Launcher::Job::checkSpecificParameters ( )
Reimplemented in Launcher::Job_YACSFile.
◆ convertMaximumDuration()
long Launcher::Job::convertMaximumDuration ( const std::string &  maximum_duration)
◆ get_in_files()
const std::list< std::string > & Launcher::Job::get_in_files ( ) const
◆ get_out_files()
const std::list< std::string > & Launcher::Job::get_out_files ( ) const
◆ getAssignedHostnames()
std::string Launcher::Job::getAssignedHostnames ( )
◆ getEnvFile()
std::string Launcher::Job::getEnvFile ( ) const
◆ getExclusive()
bool Launcher::Job::getExclusive ( ) const
◆ getExclusiveStr()
std::string Launcher::Job::getExclusiveStr ( ) const
◆ getExtraParams()
std::string Launcher::Job::getExtraParams ( ) const
◆ getJobFile()
std::string Launcher::Job::getJobFile ( ) const
◆ getJobName()
std::string Launcher::Job::getJobName ( ) const
◆ getJobType()
std::string Launcher::Job::getJobType ( ) const
◆ getLaunchDate()
std::string Launcher::Job::getLaunchDate ( ) const
Referenced by Launcher::Job::Job().
◆ getLauncherArgs()
std::string Launcher::Job::getLauncherArgs ( ) const
◆ getLauncherFile()
std::string Launcher::Job::getLauncherFile ( ) const
◆ getLocalDirectory()
std::string Launcher::Job::getLocalDirectory ( ) const
◆ getMaximumDuration()
std::string Launcher::Job::getMaximumDuration ( ) const
◆ getMaximumDurationInSecond()
long Launcher::Job::getMaximumDurationInSecond ( ) const
◆ getMemPerCpu()
unsigned long Launcher::Job::getMemPerCpu ( ) const
◆ getNumber()
int Launcher::Job::getNumber ( )
◆ getPartition()
std::string Launcher::Job::getPartition ( ) const
◆ getPreCommand()
std::string Launcher::Job::getPreCommand ( ) const
◆ getQueue()
std::string Launcher::Job::getQueue ( ) const
◆ getReference()
std::string Launcher::Job::getReference ( ) const
◆ getResourceDefinition()
ParserResourcesType Launcher::Job::getResourceDefinition ( ) const
◆ getResourceRequiredParams()
resourceParams Launcher::Job::getResourceRequiredParams ( ) const
◆ getResultDirectory()
std::string Launcher::Job::getResultDirectory ( ) const
◆ getSpecificParameters()
const std::map< std::string, std::string > & Launcher::Job::getSpecificParameters ( ) const
◆ getState()
std::string Launcher::Job::getState ( ) const
◆ getVerbosePyLogLevel()
std::string Launcher::Job::getVerbosePyLogLevel ( ) const
◆ getWCKey()
std::string Launcher::Job::getWCKey ( ) const
◆ getWorkDirectory()
std::string Launcher::Job::getWorkDirectory ( ) const
◆ removeJob()
void Launcher::Job::removeJob ( )
References LAUNCHER_INFOS, and LAUNCHER_MESSAGE.
◆ setEnvFile()
void Launcher::Job::setEnvFile ( const std::string &  env_file)
◆ setExclusive()
void Launcher::Job::setExclusive ( bool  exclusive)
◆ setExclusiveStr()
void Launcher::Job::setExclusiveStr ( const std::string &  exclusiveStr)
◆ setExtraParams()
void Launcher::Job::setExtraParams ( const std::string &  extra_params)
◆ setJobFile()
void Launcher::Job::setJobFile ( const std::string &  job_file)
◆ setJobName()
void Launcher::Job::setJobName ( const std::string &  job_name)
◆ setLauncherArgs()
void Launcher::Job::setLauncherArgs ( const std::string &  launcher_args)
◆ setLauncherFile()
void Launcher::Job::setLauncherFile ( const std::string &  launcher_file)
◆ setLocalDirectory()
void Launcher::Job::setLocalDirectory ( const std::string &  local_directory)
◆ setMaximumDuration()
void Launcher::Job::setMaximumDuration ( const std::string &  maximum_duration)
◆ setMemPerCpu()
void Launcher::Job::setMemPerCpu ( unsigned long  mem_per_cpu)
◆ setNumber()
void Launcher::Job::setNumber ( const int &  number)
◆ setPartition()
void Launcher::Job::setPartition ( const std::string &  partition)
◆ setPreCommand()
void Launcher::Job::setPreCommand ( const std::string &  preCommand)
◆ setQueue()
void Launcher::Job::setQueue ( const std::string &  queue)
◆ setReference()
void Launcher::Job::setReference ( const std::string &  reference)
◆ setResourceDefinition()
void Launcher::Job::setResourceDefinition ( const ParserResourcesType &  resource_definition)
◆ setResourceRequiredParams()
void Launcher::Job::setResourceRequiredParams ( const resourceParams &  resource_required_params)
◆ setResultDirectory()
void Launcher::Job::setResultDirectory ( const std::string &  result_directory)
◆ setState()
void Launcher::Job::setState ( const std::string &  state)
◆ setVerbosePyLogLevel()
void Launcher::Job::setVerbosePyLogLevel ( const std::string &  verbosePyLogLevel)
◆ setWCKey()
void Launcher::Job::setWCKey ( const std::string &  wckey)
◆ setWorkDirectory()
void Launcher::Job::setWorkDirectory ( const std::string &  work_directory)
◆ stopJob()
void Launcher::Job::stopJob ( )
◆ update_job()
void Launcher::Job_Command::update_job ( )
Implements Launcher::Job.
◆ updateJobState()
std::string Launcher::Job::updateJobState ( )
◆ _assigned_hostnames
std::string Launcher::Job::_assigned_hostnames
◆ _cnt
int Launcher::Job::_cnt = 1
mutableprotectedinherited
◆ _env_file
std::string Launcher::Job::_env_file
◆ _exclusive
bool Launcher::Job::_exclusive
◆ _extra_params
std::string Launcher::Job::_extra_params
◆ _in_files
std::list<std::string> Launcher::Job::_in_files
◆ _job_file
std::string Launcher::Job::_job_file
◆ _job_file_name
std::string Launcher::Job::_job_file_name
◆ _job_file_name_complete
std::string Launcher::Job::_job_file_name_complete
◆ _job_name
std::string Launcher::Job::_job_name
◆ _job_type
◆ _launch_date
std::string Launcher::Job::_launch_date
◆ _launcher_args
std::string Launcher::Job::_launcher_args
◆ _launcher_file
std::string Launcher::Job::_launcher_file
◆ _local_directory
std::string Launcher::Job::_local_directory
◆ _maximum_duration
std::string Launcher::Job::_maximum_duration
◆ _maximum_duration_in_second
long Launcher::Job::_maximum_duration_in_second
◆ _mem_per_cpu
unsigned long Launcher::Job::_mem_per_cpu
◆ _number
int Launcher::Job::_number
◆ _out_files
std::list<std::string> Launcher::Job::_out_files
◆ _partition
std::string Launcher::Job::_partition
◆ _pre_command
std::string Launcher::Job::_pre_command
◆ _queue
std::string Launcher::Job::_queue
◆ _reference
std::string Launcher::Job::_reference
◆ _resource_definition
ParserResourcesType Launcher::Job::_resource_definition
◆ _resource_required_params
resourceParams Launcher::Job::_resource_required_params
◆ _result_directory
std::string Launcher::Job::_result_directory
◆ _specific_parameters
std::map<std::string, std::string> Launcher::Job::_specific_parameters
◆ _state
std::string Launcher::Job::_state
◆ _verbose_py_log_level
std::string Launcher::Job::_verbose_py_log_level
◆ _wckey
std::string Launcher::Job::_wckey
◆ _work_directory
std::string Launcher::Job::_work_directory
◆ TYPE_NAME
const char Launcher::Job_CommandSALOME::TYPE_NAME = "command_salome"
