Launcher_XML_Persistence.hxx
23#ifndef __LAUNCHER_XML_PERSISTENCE_HXX__
24#define __LAUNCHER_XML_PERSISTENCE_HXX__
26#include <list>
27
28#include "Launcher_Utils.hxx"
29#include "Launcher_Job.hxx"
30
31namespace Launcher
32{
33 typedef struct _xmlNode xmlNode;
35 typedef unsigned char xmlChar;
36
38 {
39 public:
40 virtual ~XML_Persistence() {}
41
46 static std::list<Job *> loadJobs(const char* jobs_file);
47
49 static void saveJobs(const char* jobs_file, const std::list<const Job *> & jobs_list);
50
51 static Job* createJobFromString(const std::string& jobDump);
52 static std::string dumpJob(const Job& job);
53
54 private:
55 // This class is static only, not instanciable
57
58 static void addJobToXmlDocument(xmlNodePtr root_node, const Job & job);
59 static Job * createJobFromXmlNode(xmlNodePtr job_node);
60 static void parseUserNode(Job * new_job, xmlNodePtr user_node);
61 static void parseRunNode(Job * new_job, xmlNodePtr run_node);
62 static void parseResourceNode(Job * new_job, xmlNodePtr res_node);
63
64
65 // Useful wrappers around libxml2 functions
66
67 // Return the value of the attribute, or an empty string if it is not defined
68 static std::string getAttrValue(xmlNodePtr node, const std::string & attrName);
69 static inline std::string xmlStrToString(const xmlChar * xmlStr);
70 static std::string getNodeContent(xmlNodePtr node);
71 template<typename T> static T getNumericalNodeContent(xmlNodePtr node);
72 static xmlNodePtr addNode(xmlNodePtr father, const std::string & name,
73 const std::string & content);
74 template<typename T> static xmlNodePtr addNumericalNode(xmlNodePtr father,
75 const std::string & name,
76 T content);
77 static void addAttr(xmlNodePtr node, const std::string & name, const std::string & value);
78 };
79
80}
81
82#endif
#define LAUNCHER_EXPORT
Definition: Launcher_Utils.hxx:39
Definition: Launcher_Job.hxx:49
Definition: Launcher_XML_Persistence.hxx:38
Definition: Launcher_XML_Persistence.hxx:40
XML_Persistence()
Definition: Launcher_XML_Persistence.hxx:56
Definition: Launcher_Job.hxx:47
xmlNode * xmlNodePtr
Definition: Launcher_XML_Persistence.hxx:34
Definition: Launcher_XML_Persistence.hxx:33
Definition: Launcher_XML_Persistence.hxx:35
string name
Definition: pythfilter.py:56
