SALOME_ResourcesManager Class Reference
#include <SALOME_ResourcesManager.hxx>
Inheritance diagram for SALOME_ResourcesManager:
 SALOME_ResourcesManager (CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns, const char *xmlFilePath)
 just for test More...
 SALOME_ResourcesManager (CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns)
 Standard constructor, parse resource file. More...
 ~SALOME_ResourcesManager ()
 Standard Destructor. More...
Engines::ResourceList * GetFittingResources (const Engines::ResourceParameters &params)
 get the name of resources fitting the specified constraints (params) More...
char * FindFirst (const Engines::ResourceList &listOfResources)
 dynamically obtains the first machines More...
char * Find (const char *policy, const Engines::ResourceList &listOfResources)
Engines::ResourceDefinition * GetResourceDefinition (const char *name)
void AddResource (const Engines::ResourceDefinition &new_resource, CORBA::Boolean write, const char *xml_file)
void RemoveResource (const char *resource_name, CORBA::Boolean write, const char *xml_file)
char * getMachineFile (const char *resource_name, CORBA::Long nb_procs, const char *parallelLib)
void ListAllAvailableResources (Engines::ResourceList_out machines, Engines::IntegerList_out nbProcsOfMachines)
 Return list of resources available (regarding content of CatalogResources.xml) but select only those with canRunContainers attribute set to true. More...
Engines::ResourceList * ListAllResourcesInCatalog ()
 Return list of resources available (regarding content of CatalogResources.xml) whatever canRunContainers attribute value. More...
Engines::ResourceList * ListAllResourceEntriesInCatalog () override
 Return list of resources entries available. More...
void Shutdown ()
 CORBA method: shutdown all the containers, then the ContainerManager servant. More...
std::shared_ptr< ResourcesManager_cpp > & GetImpl ()
Static Public Attributes
static const char * _ResourcesManagerNameInNS = "/ResourcesManager"
SALOME_NamingService_Abstract * _NS
CORBA::ORB_var _orb
PortableServer::POA_var _poa
std::shared_ptr< ResourcesManager_cpp > _rm
◆ SALOME_ResourcesManager() [1/2]
SALOME_ResourcesManager::SALOME_ResourcesManager ( CORBA::ORB_ptr  orb,
SALOME_NamingService_Abstract *  ns,
const char *  xmlFilePath
◆ SALOME_ResourcesManager() [2/2]
  • if ${APPLI} exists in environment, look for ${HOME}/${APPLI}/CatalogResources.xml
  • else look for default: ${KERNEL_ROOT_DIR}/share/salome/resources/kernel/CatalogResources.xml
  • parse XML resource file.
References _NS, _orb, _poa, _ResourcesManagerNameInNS, KERNEL_PY.batchmode_salome::obj, salome::orb, SALOME_ContainerPy::poa, and SALOME_NamingService_Container_Abstract::Register().
◆ ~SALOME_ResourcesManager()
SALOME_ResourcesManager::~SALOME_ResourcesManager ( )
References MESSAGE.
◆ AddResource()
void SALOME_ResourcesManager::AddResource ( const Engines::ResourceDefinition &  new_resource,
const char *  xml_file
◆ Find()
char * SALOME_ResourcesManager::Find ( const char *  policy,
const Engines::ResourceList &  listOfResources
References _rm, and resourceList_CORBAtoCPP().
◆ FindFirst()
char * SALOME_ResourcesManager::FindFirst ( const Engines::ResourceList &  listOfResources)
◆ GetFittingResources()
Engines::ResourceList * SALOME_ResourcesManager::GetFittingResources ( const Engines::ResourceParameters &  params)
If hostname specified, check it is local or known in resources catalog.
Else
  • select first machines with corresponding OS (all machines if parameter OS empty),
  • then select the sublist of machines on which the component is known (if the result is empty, that probably means that the inventory of components is probably not done, so give complete list from previous step)
References _rm, SALOME::BAD_PARAM, ResourcesException::msg, resourceList_CPPtoCORBA(), resourceParameters_CORBAtoCPP(), TestKernelHelpers::ret, and THROW_SALOME_CORBA_EXCEPTION.
Referenced by SALOME_Launcher::testBatch().
◆ GetImpl()
std::shared_ptr< ResourcesManager_cpp > & SALOME_ResourcesManager::GetImpl ( )
Referenced by SALOME_Launcher::init().
◆ getMachineFile()
◆ GetResourceDefinition()
Engines::ResourceDefinition * SALOME_ResourcesManager::GetResourceDefinition ( const char *  name)
◆ ListAllAvailableResources()
void SALOME_ResourcesManager::ListAllAvailableResources ( Engines::ResourceList_out  machines,
And for each resource the number of proc available of it.
See also
SALOME_ResourcesManager::ListAllResourcesInCatalog, SALOME_ResourcesManager::ListAllResourceEntriesInCatalog
References ResourceDataToSort::_nbOfNodes, ResourceDataToSort::_nbOfProcPerNode, _rm, ParserResourcesType::can_run_containers, ParserResourcesType::DataForSort, and ParserResourcesType::HostName.
◆ ListAllResourceEntriesInCatalog()
Engines::ResourceList * SALOME_ResourcesManager::ListAllResourceEntriesInCatalog ( )
override
Useful to scan remotely the content of the playground
References _rm, and TestKernelHelpers::ret.
◆ ListAllResourcesInCatalog()
Engines::ResourceList * SALOME_ResourcesManager::ListAllResourcesInCatalog ( )
See also
SALOME_ResourcesManager::ListAllAvailableResources, SALOME_ResourcesManager::ListAllResourceEntriesInCatalog
◆ RemoveResource()
void SALOME_ResourcesManager::RemoveResource ( const char *  resource_name,
◆ Shutdown()
void SALOME_ResourcesManager::Shutdown ( )
References _NS, _poa, _ResourcesManagerNameInNS, SALOME_NamingService_Container_Abstract::Destroy_Name(), and MESSAGE.
Referenced by SALOME_Launcher::Shutdown().
◆ _NS
SALOME_NamingService_Abstract* SALOME_ResourcesManager::_NS
◆ _orb
◆ _poa
◆ _ResourcesManagerNameInNS
◆ _rm
