SALOME_ResourcesManager.hxx
23#ifndef __SALOME_RESOURCESMANAGER_HXX__
24#define __SALOME_RESOURCESMANAGER_HXX__
26#include "Utils_SALOME_Exception.hxx"
27#include "utilities.h"
28#include <SALOMEconfig.h>
30#include CORBA_CLIENT_HEADER(SALOME_ContainerManager)
31#include <string>
32#include <fstream>
33#include <vector>
34#include <memory>
35#include "ResourcesManager.hxx"
36
38
39#ifdef WIN32
40#pragma warning(disable:4275) // Disable warning interface non dll
41#endif
42
43// --- WARNING ---
44// The call of BuildTempFileToLaunchRemoteContainer and RmTmpFile must be done
45// in a critical section to be sure to be clean.
46// Only one thread should use the SALOME_ResourcesManager class in a SALOME
47// session.
48
50 public POA_Engines::ResourcesManager,
51 public PortableServer::RefCountServantBase
52 {
53
54 public:
55
56 SALOME_ResourcesManager(CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns, const char *xmlFilePath);
57 SALOME_ResourcesManager(CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns);
58
60
61 // CORBA Methods
62 Engines::ResourceList * GetFittingResources(const Engines::ResourceParameters& params);
63 char* FindFirst(const Engines::ResourceList& listOfResources);
64 char* Find(const char *policy, const Engines::ResourceList& listOfResources);
65 Engines::ResourceDefinition * GetResourceDefinition(const char * name);
66 void AddResource(const Engines::ResourceDefinition& new_resource,
67 CORBA::Boolean write,
68 const char * xml_file);
69
70 void RemoveResource(const char * resource_name,
71 CORBA::Boolean write,
72 const char * xml_file);
73 char* getMachineFile(const char * resource_name,
74 CORBA::Long nb_procs,
75 const char * parallelLib);
76 void ListAllAvailableResources(Engines::ResourceList_out machines, Engines::IntegerList_out nbProcsOfMachines);
77
78 Engines::ResourceList *ListAllResourcesInCatalog();
79
80 Engines::ResourceList *ListAllResourceEntriesInCatalog() override;
81
82 // Cpp Methods
83 void Shutdown();
84 std::shared_ptr<ResourcesManager_cpp>& GetImpl() { return _rm; }
85
86
87 static const char *_ResourcesManagerNameInNS;
88 protected:
89
91 CORBA::ORB_var _orb;
92 PortableServer::POA_var _poa;
93 std::shared_ptr<ResourcesManager_cpp> _rm;
94 };
95
96#endif // RESSOURCESCATALOG_IMPL_H
#define SALOMERESOURCESMANAGER_EXPORT
Definition: SALOME_ResourcesManager_Common.hxx:33
Definition: SALOME_NamingService_Abstract.hxx:46
Definition: SALOME_ResourcesManager.hxx:52
Definition: SALOME_ResourcesManager.hxx:92
CORBA::ORB_var _orb
Definition: SALOME_ResourcesManager.hxx:91
std::shared_ptr< ResourcesManager_cpp > _rm
Definition: SALOME_ResourcesManager.hxx:93
SALOME_NamingService_Abstract * _NS
Definition: SALOME_ResourcesManager.hxx:90
std::shared_ptr< ResourcesManager_cpp > & GetImpl()
Definition: SALOME_ResourcesManager.hxx:84
static const char * _ResourcesManagerNameInNS
Definition: SALOME_ResourcesManager.hxx:87
sequence< string > ResourceList
Type to transmit list of resources.
Definition: SALOME_ResourcesManager.idl:35
poa
Definition: SALOME_ContainerPy.py:377
string name
Definition: pythfilter.py:56
orb
Definition: salome.py:122
Type to describe a resource.
Definition: SALOME_ResourcesManager.idl:106
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
