SALOMEDS::Notifier Class Reference
Inheritance diagram for SALOMEDS::Notifier:
 Notifier (CORBA::ORB_ptr orb)
virtual bool addSO_Notification (const SALOMEDSImpl_SObject &theSObject)
 Function : addSO_Notification Purpose : This function tells all the observers that a SO has been added. More...
virtual bool removeSO_Notification (const SALOMEDSImpl_SObject &theSObject)
 Function : removeSO_Notification Purpose : This function tells all the observers that a SO has been removed. More...
virtual bool modifySO_Notification (const SALOMEDSImpl_SObject &theSObject, int reason)
 Function : modifySO_Notification Purpose : This function tells all the observers that a SO has been modified. More...
virtual bool modifyNB_Notification (const char *theVarName)
 Function : modifyNB_Notification Purpose : This function tells all the observers that a NoteBook variable has been added/modified/removed. More...
virtual void attach (SALOMEDS::Observer_ptr theObs, bool modify)
 Function : attach Purpose : register an Observer. More...
virtual void detach (SALOMEDS::Observer_ptr theObs)
 Function : detach Purpose : unregister an Observer. More...
virtual void RegisterGenObj (const std::string &)
virtual void UnRegisterGenObj (const std::string &)
Private Types
typedef std::list< std::pair< SALOMEDS::Observer_var, bool > > ObsList
typedef ObsList::iterator ObsListIter
ObsList myObservers
CORBA::ORB_var _orb
◆ ObsList
typedef std::list< std::pair< SALOMEDS::Observer_var, bool > > SALOMEDS::Notifier::ObsList
◆ ObsListIter
typedef ObsList::iterator SALOMEDS::Notifier::ObsListIter
◆ Notifier()
SALOMEDS::Notifier::Notifier ( CORBA::ORB_ptr  orb)
References _orb, and salome::orb.
◆ addSO_Notification()
virtual bool SALOMEDS::Notifier::addSO_Notification ( const SALOMEDSImpl_SObject &  theSObject)
Reimplemented from SALOMEDSImpl_AbstractCallback.
References SALOMEDSImpl_SObject::GetID(), and myObservers.
◆ attach()
virtual void SALOMEDS::Notifier::attach ( SALOMEDS::Observer_ptr  theObs,
bool  modify
References myObservers.
◆ detach()
virtual void SALOMEDS::Notifier::detach ( SALOMEDS::Observer_ptr  theObs)
◆ modifyNB_Notification()
virtual bool SALOMEDS::Notifier::modifyNB_Notification ( const char *  theVarName)
◆ modifySO_Notification()
virtual bool SALOMEDS::Notifier::modifySO_Notification ( const SALOMEDSImpl_SObject &  theSObject,
int  reason
◆ RegisterGenObj()
virtual void SALOMEDSImpl_AbstractCallback::RegisterGenObj ( const std::string &  )
Reimplemented in SALOMEDS::GenObjRegister.
◆ removeSO_Notification()
virtual bool SALOMEDS::Notifier::removeSO_Notification ( const SALOMEDSImpl_SObject &  theSObject)
◆ UnRegisterGenObj()
virtual void SALOMEDSImpl_AbstractCallback::UnRegisterGenObj ( const std::string &  )
◆ _orb
◆ myObservers
