SALOMEDS_UseCaseBuilder_i Class Reference
#include <SALOMEDS_UseCaseBuilder_i.hxx>
Inheritance diagram for SALOMEDS_UseCaseBuilder_i:
 SALOMEDS_UseCaseBuilder_i (SALOMEDSImpl_UseCaseBuilder *theDocument, CORBA::ORB_ptr)
 standard constructor
More...
 ~SALOMEDS_UseCaseBuilder_i ()
 standard destructor More...
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
virtual CORBA::Boolean Append (SALOMEDS::SObject_ptr theObject)
 Function : Append Purpose : More...
virtual CORBA::Boolean Remove (SALOMEDS::SObject_ptr theObject)
 Function : Remove Purpose : More...
virtual CORBA::Boolean AppendTo (SALOMEDS::SObject_ptr theFather, SALOMEDS::SObject_ptr theObject)
 Function : AppendTo Purpose : More...
virtual CORBA::Long GetIndexInFather (SALOMEDS::SObject_ptr theFather, SALOMEDS::SObject_ptr theObject)
 Function : GetIndexInFather Purpose : More...
virtual CORBA::Boolean InsertBefore (SALOMEDS::SObject_ptr theFirst, SALOMEDS::SObject_ptr theNext)
 Function : InsertBefore Purpose : More...
virtual CORBA::Boolean SetCurrentObject (SALOMEDS::SObject_ptr theObject)
 Function : SetCurrentObject Purpose : More...
virtual CORBA::Boolean SetRootCurrent ()
 Function : SetRootCurrent Purpose : More...
virtual CORBA::Boolean HasChildren (SALOMEDS::SObject_ptr theObject)
 Function : HasChildren Purpose : More...
virtual CORBA::Boolean SortChildren (SALOMEDS::SObject_ptr theObject, CORBA::Boolean theAscendingOrder)
 Function : SortChildren Purpose : More...
virtual SALOMEDS::SObject_ptr GetFather (SALOMEDS::SObject_ptr theObject)
 Function : GetFather Purpose : More...
virtual CORBA::Boolean IsUseCase (SALOMEDS::SObject_ptr theObject)
 Function : IsUseCase Purpose :
More...
virtual CORBA::Boolean IsUseCaseNode (SALOMEDS::SObject_ptr theObject)
 Function : IsUseCaseNode Purpose :
More...
virtual CORBA::Boolean SetName (const char *theName)
 Function : SetName Purpose : More...
virtual SALOMEDS::SObject_ptr GetCurrentObject ()
 Function : GetCurrentObject Purpose : More...
virtual char * GetName ()
 Function : GetName Purpose : More...
virtual SALOMEDS::SObject_ptr AddUseCase (const char *theName)
 Function : NewUseCase Purpose :
More...
virtual SALOMEDS::UseCaseIterator_ptr GetUseCaseIterator (SALOMEDS::SObject_ptr anObject)
 Function : GetUseCaseIterator Purpose : Creates a new UseCase iterator, if anObject is null all use cases are iterated. More...
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
PortableServer::POA_var myPOA
int myRefCounter
CORBA::ORB_var _orb
SALOMEDSImpl_UseCaseBuilder * _impl
◆ SALOMEDS_UseCaseBuilder_i()
SALOMEDS_UseCaseBuilder_i::SALOMEDS_UseCaseBuilder_i ( SALOMEDSImpl_UseCaseBuilder *  theDocument,
CORBA::ORB_ptr  orb
Function : constructor Purpose :
References _impl, _orb, and salome::orb.
◆ ~SALOMEDS_UseCaseBuilder_i()
SALOMEDS_UseCaseBuilder_i::~SALOMEDS_UseCaseBuilder_i ( )
standard destructor
Function : destructor Purpose :
◆ _default_POA()
PortableServer::POA_ptr SALOMEDS_UseCaseBuilder_i::_default_POA ( )
reference to the default POA for the servant
◆ AddUseCase()
SALOMEDS::SObject_ptr SALOMEDS_UseCaseBuilder_i::AddUseCase ( const char *  theName)
◆ Append()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::Append ( SALOMEDS::SObject_ptr  theObject)
◆ AppendTo()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::AppendTo ( SALOMEDS::SObject_ptr  theFather,
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ GetCurrentObject()
SALOMEDS::SObject_ptr SALOMEDS_UseCaseBuilder_i::GetCurrentObject ( )
◆ GetFather()
SALOMEDS::SObject_ptr SALOMEDS_UseCaseBuilder_i::GetFather ( SALOMEDS::SObject_ptr  theObject)
◆ GetIndexInFather()
CORBA::Long SALOMEDS_UseCaseBuilder_i::GetIndexInFather ( SALOMEDS::SObject_ptr  theFather,
◆ GetName()
char * SALOMEDS_UseCaseBuilder_i::GetName ( )
References _impl, SALOMEDSImpl_UseCaseBuilder::GetName(), and SALOMEDS::lock().
◆ GetUseCaseIterator()
SALOMEDS::UseCaseIterator_ptr SALOMEDS_UseCaseBuilder_i::GetUseCaseIterator ( SALOMEDS::SObject_ptr  anObject)
References _impl, _orb, SALOMEDSImpl_UseCaseBuilder::GetSObject(), SALOMEDSImpl_UseCaseBuilder::GetUseCaseIterator(), and SALOMEDS::lock().
◆ HasChildren()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::HasChildren ( SALOMEDS::SObject_ptr  theObject)
◆ InsertBefore()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::InsertBefore ( SALOMEDS::SObject_ptr  theFirst,
◆ IsUseCase()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::IsUseCase ( SALOMEDS::SObject_ptr  theObject)
◆ IsUseCaseNode()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::IsUseCaseNode ( SALOMEDS::SObject_ptr  theObject)
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ Remove()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::Remove ( SALOMEDS::SObject_ptr  theObject)
◆ SetCurrentObject()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::SetCurrentObject ( SALOMEDS::SObject_ptr  theObject)
◆ SetName()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::SetName ( const char *  theName)
References _impl, SALOMEDS::lock(), and SALOMEDSImpl_UseCaseBuilder::SetName().
◆ SetRootCurrent()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::SetRootCurrent ( )
References _impl, SALOMEDS::lock(), and SALOMEDSImpl_UseCaseBuilder::SetRootCurrent().
◆ SortChildren()
CORBA::Boolean SALOMEDS_UseCaseBuilder_i::SortChildren ( SALOMEDS::SObject_ptr  theObject,
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _impl
◆ _orb
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
