Implementation of the base servant for SALOME objects with reference counter. More...
#include <SALOME_GenericObj_i.hh>
| GenericObj_i (PortableServer::POA_ptr thePOA=PortableServer::POA::_nil()) | |
| Constructor. More... | |
| virtual PortableServer::POA_ptr | _default_POA () |
| Get default POA for the servant object. More... | |
| virtual void | Register () |
| Increment reference counter. More... | |
| virtual void | UnRegister () |
| Decrement reference counter. More... | |
| virtual void | Destroy () |
Protected Attributes | |
| PortableServer::POA_var | myPOA |
| int | myRefCounter |
This class can be used to implement data entities with life-cycle management based on the reference counting.
The object is initially created with the reference counter equal to 1. The function Register() can be used to incrfement the reference counter. Function UnRegister() should be used to decrement reference counter. As soon as reference counter goes to zero, the object is automatically deactivated in POA (and, eventually its destructor is automatically called).
| SALOME::GenericObj_i::GenericObj_i | ( | PortableServer::POA_ptr | thePOA = PortableServer::POA::_nil() | ) |
Creates an object with the reference counter initially set to 1.
The default POA for the servant can be passed as a parameter thePOA. By default, root POA is used.
| thePOA | optional default POA for the servant |
References myPOA.
Reimplemented in SALOMEDS_ChildIterator_i, SALOMEDS_GenericAttribute_i, SALOMEDS_SComponentIterator_i, SALOMEDS_SObject_i, SALOMEDS_UseCaseBuilder_i, and SALOMEDS_UseCaseIterator_i.
References myPOA.
References MESSAGE, and UnRegister().
References IS_OBJ_IN_QUESTION, MESSAGE, and myRefCounter.
References IS_OBJ_IN_QUESTION, MESSAGE, myPOA, and myRefCounter.
Referenced by Destroy(), and SALOME_PyNode.Generic::Destroy().
protected |
Referenced by _default_POA(), SALOMEDS_ChildIterator_i::_default_POA(), SALOMEDS_GenericAttribute_i::_default_POA(), SALOMEDS_SComponentIterator_i::_default_POA(), SALOMEDS_SObject_i::_default_POA(), SALOMEDS_UseCaseBuilder_i::_default_POA(), SALOMEDS_UseCaseIterator_i::_default_POA(), GenericObj_i(), and UnRegister().
protected |
Referenced by Register(), and UnRegister().
