ConnectionManager_i.hxx
23// File : ConnectionManager_i.hxx
24// Author : André RIBES (EDF)
25// Module : KERNEL
26//
27#ifndef _CONNECTION_MANAGER_I_HXX_
28#define _CONNECTION_MANAGER_I_HXX_
30#include "DSC_Basic.hxx"
32
33#include <iostream>
34#include <map>
35#include <pthread.h>
36
37#include <SALOMEconfig.h>
38#include CORBA_SERVER_HEADER(DSC_Engines)
39
44 public virtual POA_Engines::ConnectionManager
45{
46 public :
47 ConnectionManager_i(CORBA::ORB_ptr orb);
48 virtual ~ConnectionManager_i();
49
54 Engines::ConnectionManager::connectionId connect(Engines::DSC_ptr uses_component,
55 const char* uses_port_name,
56 Engines::DSC_ptr provides_component,
57 const char* provides_port_name);
58
66 Engines::DSC::Message message);
67
71 void ShutdownWithExit();
72
76 CORBA::Long getPID();
77
78 static const char *_ConnectionManagerNameInNS;
79
80 private :
81
83 Engines::DSC_var uses_component;
84 std::string uses_port_name;
85 Engines::DSC_var provides_component;
86 std::string provides_port_name;
87 Ports::Port_var provides_port;
88 };
89
94
97
99 pthread_mutex_t mutex;
100 protected:
101 CORBA::ORB_var _orb;
103};
104
105#endif
This class implements the interface Engines::ConnectionManager.
Definition: ConnectionManager_i.hxx:45
Definition: ConnectionManager_i.hxx:99
Definition: ConnectionManager_i.cxx:37
Shutdown the ConnectionManager process.
Definition: ConnectionManager_i.cxx:125
static const char * _ConnectionManagerNameInNS
Definition: ConnectionManager_i.hxx:78
int current_id
Definition: ConnectionManager_i.hxx:98
Returns the PID of the connection manager.
Definition: ConnectionManager_i.cxx:141
ids_it_type ids_it
Definition: ConnectionManager_i.hxx:96
std::map< Engines::ConnectionManager::connectionId, connection_infos * >::iterator ids_it_type
Definition: ConnectionManager_i.hxx:93
Definition: ConnectionManager_i.cxx:48
std::map< Engines::ConnectionManager::connectionId, connection_infos * > ids_type
Definition: ConnectionManager_i.hxx:91
SALOME_NamingService * _NS
Definition: ConnectionManager_i.hxx:102
ids_type ids
Definition: ConnectionManager_i.hxx:95
Engines::ConnectionManager::connectionId connect(Engines::DSC_ptr uses_component, const char *uses_port_name, Engines::DSC_ptr provides_component, const char *provides_port_name)
CORBA method : connect two ports of two components.
Definition: ConnectionManager_i.cxx:54
void disconnect(Engines::ConnectionManager::connectionId id, Engines::DSC::Message message)
CORBA method : releases a connection performed with ConnectionManager_i::connect.
Definition: ConnectionManager_i.cxx:86
CORBA::ORB_var _orb
Definition: ConnectionManager_i.hxx:101
A class to manage the SALOME naming service.
Definition: SALOME_NamingService.hxx:48
short connectionId
A connection Id. It's unique.
Definition: DSC_Engines.idl:293
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
orb
Definition: salome.py:122
Definition: ConnectionManager_i.hxx:82
Definition: ConnectionManager_i.hxx:87
Definition: ConnectionManager_i.hxx:86
Definition: ConnectionManager_i.hxx:83
Definition: ConnectionManager_i.hxx:85
Definition: ConnectionManager_i.hxx:84
