ConnectionManager_i::connection_infos Struct Reference
Data Fields
Engines::DSC_var uses_component
std::string uses_port_name
Engines::DSC_var provides_component
std::string provides_port_name
Ports::Port_var provides_port
◆ provides_component
Engines::DSC_var ConnectionManager_i::connection_infos::provides_component
◆ provides_port
Ports::Port_var ConnectionManager_i::connection_infos::provides_port
◆ provides_port_name
std::string ConnectionManager_i::connection_infos::provides_port_name
◆ uses_component
Engines::DSC_var ConnectionManager_i::connection_infos::uses_component
◆ uses_port_name
std::string ConnectionManager_i::connection_infos::uses_port_name
