Engines::ConnectionManager Interface Reference
Interface of the ConnectionManager. More...
import"DSC_Engines.idl";
exception  BadId
 The Id given to the disconnect method is bad. More...
typedef short connectionId
 A connection Id. It's unique. More...
connectionId connect (in Engines::DSC uses_component, in string uses_port_name, in Engines::DSC provides_component, in string provides_port_name) raises (Engines::DSC::PortNotDefined, Engines::DSC::BadPortType, Engines::DSC::NilPort)
 Connect a uses port with a provides port. More...
void disconnect (in connectionId id, in Engines::DSC::Message message) raises (Engines::ConnectionManager::BadId, Engines::DSC::PortNotDefined, Engines::DSC::PortNotConnected, Engines::DSC::BadPortReference)
 Release a connection that has been previously created by the ConnectionManager. More...
oneway void ShutdownWithExit ()
 Shutdown the ConnectionManager process. More...
long getPID ()
 Return the PID of the connection manager. More...
It is a helper object for connection operations. The ConnectionManager is used like other services of SALOME (e.g ContainerManager).
◆ connectionId
◆ connect()
connectionId Engines::ConnectionManager::connect ( in Engines::DSC  uses_component,
uses_componentThe component that have the uses port.
uses_port_nameuses port's name.
provides_componentThe component that have the provides port.
provides_port_nameprovides port's name.
Exceptions
the id of the connection that the ConnectionManager will use to release this connection when the framework (or a user script, ...) will call ConnectionManager::disconnect.
◆ disconnect()
idThe id of the connection previously given by the connect operation of the ConnectionManager.
messagestate associated with the disconnection.
Exceptions
◆ getPID()
long Engines::ConnectionManager::getPID ( )
◆ ShutdownWithExit()
oneway void Engines::ConnectionManager::ShutdownWithExit ( )
