SALOMEDSImpl_AttributeSequenceOfReal Class Reference
#include <SALOMEDSImpl_AttributeSequenceOfReal.hxx>
Inheritance diagram for SALOMEDSImpl_AttributeSequenceOfReal:
virtual std::string Save ()
virtual void Load (const std::string &)
 SALOMEDSImpl_AttributeSequenceOfReal ()
void Assign (const std::vector< double > &other)
void ChangeValue (const int Index, const double &Value)
void Add (const double &Value)
double Value (const int Index)
void Remove (const int Index)
int Length ()
const std::string & ID () const
void Restore (DF_Attribute *with)
DF_Attribute * NewEmpty () const
void Paste (DF_Attribute *into)
 ~SALOMEDSImpl_AttributeSequenceOfReal ()
const std::vector< double > & Array ()
virtual std::string Type ()
virtual void CheckLocked ()
std::string GetClassType ()
SALOMEDSImpl_SObject GetSObject ()
void SetModifyFlag (int reason=0)
 Set modification flag of the Attribute. More...
DF_Label Label () const
DF_Attribute * FindAttribute (const std::string &theID) const
virtual void AfterAddition ()
virtual void BeforeForget ()
static const std::string & GetID ()
static SALOMEDSImpl_AttributeSequenceOfReal * Set (const DF_Label &label)
static std::string Impl_GetType (DF_Attribute *theAttr)
static std::string Impl_GetClassType (DF_Attribute *theAttr)
static void Impl_CheckLocked (DF_Attribute *theAttr)
void Backup ()
std::string _type
DF_LabelNode * _node
std::vector< double > myValue
◆ SALOMEDSImpl_AttributeSequenceOfReal()
SALOMEDSImpl_AttributeSequenceOfReal::SALOMEDSImpl_AttributeSequenceOfReal ( )
References myValue.
Referenced by NewEmpty(), and Set().
◆ ~SALOMEDSImpl_AttributeSequenceOfReal()
SALOMEDSImpl_AttributeSequenceOfReal::~SALOMEDSImpl_AttributeSequenceOfReal ( )
◆ Add()
void SALOMEDSImpl_AttributeSequenceOfReal::Add ( const double &  Value)
◆ AfterAddition()
virtual void DF_Attribute::AfterAddition ( )
Reimplemented in SALOMEDSImpl_AttributeTreeNode.
Referenced by DF_Label::AddAttribute().
◆ Array()
const std::vector< double > & SALOMEDSImpl_AttributeSequenceOfReal::Array ( )
◆ Assign()
void SALOMEDSImpl_AttributeSequenceOfReal::Assign ( const std::vector< double > &  other)
◆ Backup()
void DF_Attribute::Backup ( )
Referenced by Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTableOfInteger::Load(), SALOMEDSImpl_AttributeTableOfReal::Load(), SALOMEDSImpl_AttributeTableOfString::Load(), SALOMEDSImpl_AttributeParameter::Load(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeFlags::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributeOpened::SetOpened(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeSelectable::SetSelectable(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), and SALOMEDSImpl_AttributeGraphic::SetVisibility().
◆ BeforeForget()
virtual void DF_Attribute::BeforeForget ( )
◆ ChangeValue()
void SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue ( const int  Index,
◆ CheckLocked()
void SALOMEDSImpl_GenericAttribute::CheckLocked ( )
References SALOMEDSImpl_Study::_errorCode, SALOMEDSImpl_Study::GetStudyImpl(), SALOMEDSImpl_Study::IsLocked(), DF_Label::IsNull(), and DF_Attribute::Label().
Referenced by Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDSImpl_GenericAttribute::Impl_CheckLocked(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), Remove(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SortByColumn(), SALOMEDSImpl_AttributeTableOfReal::SortByColumn(), SALOMEDSImpl_AttributeTableOfString::SortByColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortByRow(), SALOMEDSImpl_AttributeTableOfReal::SortByRow(), SALOMEDSImpl_AttributeTableOfString::SortByRow(), SALOMEDSImpl_AttributeTableOfInteger::SortColumn(), SALOMEDSImpl_AttributeTableOfReal::SortColumn(), SALOMEDSImpl_AttributeTableOfString::SortColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortRow(), SALOMEDSImpl_AttributeTableOfReal::SortRow(), SALOMEDSImpl_AttributeTableOfString::SortRow(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), SALOMEDSImpl_AttributeTableOfString::SwapCells(), SALOMEDSImpl_AttributeTableOfInteger::SwapColumns(), SALOMEDSImpl_AttributeTableOfReal::SwapColumns(), SALOMEDSImpl_AttributeTableOfString::SwapColumns(), SALOMEDSImpl_AttributeTableOfInteger::SwapRows(), SALOMEDSImpl_AttributeTableOfReal::SwapRows(), and SALOMEDSImpl_AttributeTableOfString::SwapRows().
◆ FindAttribute()
◆ GetClassType()
std::string SALOMEDSImpl_GenericAttribute::GetClassType ( )
◆ GetID()
const std::string & SALOMEDSImpl_AttributeSequenceOfReal::GetID ( )
Referenced by ID(), and Set().
◆ GetSObject()
◆ ID()
const std::string & SALOMEDSImpl_AttributeSequenceOfReal::ID ( ) const
Implements DF_Attribute.
References GetID().
◆ Impl_CheckLocked()
void SALOMEDSImpl_GenericAttribute::Impl_CheckLocked ( DF_Attribute *  theAttr)
◆ Impl_GetClassType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetClassType ( DF_Attribute *  theAttr)
◆ Impl_GetType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetType ( DF_Attribute *  theAttr)
◆ Label()
DF_Label DF_Attribute::Label ( ) const
References DF_Attribute::_node, and DF_Attribute::DF_Label.
Referenced by SALOMEDS_AttributeTarget_i::Add(), SALOMEDSImpl_UseCaseBuilder::Append(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_GenericAttribute::CheckLocked(), DF_Attribute::FindAttribute(), SALOMEDSImpl_UseCaseBuilder::GetCurrentObject(), SALOMEDSImpl_AttributeParameter::GetFather(), GetNode(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_UseCaseBuilder::GetSObject(), SALOMEDSImpl_UseCaseBuilder::HasChildren(), SALOMEDSImpl_AttributeParameter::HasFather(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_Study::IORUpdated(), SALOMEDSImpl_UseCaseBuilder::IsUseCaseNode(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeTreeNode_i::Label(), SALOMEDSImpl_AttributeTreeNode::Load(), SALOMEDSImpl_AttributeReference::Load(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_UseCaseBuilder::Remove(), SALOMEDS_AttributeTarget_i::Remove(), SALOMEDSImpl_UseCaseBuilder::SALOMEDSImpl_UseCaseBuilder(), SALOMEDSImpl_AttributeTreeNode::Save(), SALOMEDSImpl_UseCaseBuilder::SetCurrentObject(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), SALOMEDSImpl_UseCaseBuilder::SetName(), SALOMEDSImpl_UseCaseBuilder::SetRootCurrent(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_UseCaseBuilder::SortChildren(), Translate_persistentID_to_IOR(), SALOMEDSImpl_UseCaseIterator::Value(), and SALOMEDSImpl_AttributeIOR::~SALOMEDSImpl_AttributeIOR().
◆ Length()
int SALOMEDSImpl_AttributeSequenceOfReal::Length ( )
< TODO: conversion from size_t to int, possible loss of data
References myValue.
Referenced by SALOMEDS_AttributeSequenceOfReal::CorbaSequence(), Restore(), and Save().
◆ Load()
void SALOMEDSImpl_AttributeSequenceOfReal::Load ( const std::string &  value)
◆ NewEmpty()
DF_Attribute * SALOMEDSImpl_AttributeSequenceOfReal::NewEmpty ( ) const
◆ Paste()
void SALOMEDSImpl_AttributeSequenceOfReal::Paste ( DF_Attribute *  into)
References Assign(), and myValue.
◆ Remove()
void SALOMEDSImpl_AttributeSequenceOfReal::Remove ( const int  Index)
◆ Restore()
void SALOMEDSImpl_AttributeSequenceOfReal::Restore ( DF_Attribute *  with)
References Length(), and myValue.
◆ Save()
std::string SALOMEDSImpl_AttributeSequenceOfReal::Save ( )
◆ Set()
SALOMEDSImpl_AttributeSequenceOfReal * SALOMEDSImpl_AttributeSequenceOfReal::Set ( const DF_Label &  label)
◆ SetModifyFlag()
void SALOMEDSImpl_GenericAttribute::SetModifyFlag ( int  reason = 0)
param reason reason of the modification (by default equal to 0)
References SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_Study::GetStudyImpl(), DF_Label::IsNull(), DF_Attribute::Label(), SALOMEDSImpl_Study::Modify(), and SALOMEDSImpl_Study::modifySO_Notification().
Referenced by Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitles(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitles(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitles(), SALOMEDSImpl_AttributeTableOfString::SetRowTitles(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnits(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnits(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeTreeNode::SetTreeID(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), and SALOMEDSImpl_AttributeTableOfString::SwapCells().
◆ Type()
◆ Value()
double SALOMEDSImpl_AttributeSequenceOfReal::Value ( const int  Index)
◆ _node
◆ _type
◆ myValue
std::vector<double> SALOMEDSImpl_AttributeSequenceOfReal::myValue
