SALOMEDSImpl_AttributeTableOfReal Class Reference
#include <SALOMEDSImpl_AttributeTableOfReal.hxx>
Inheritance diagram for SALOMEDSImpl_AttributeTableOfReal:
enum  SortOrder { AscendingOrder , DescendingOrder }
 Sort order. More...
enum  SortPolicy {
  EmptyLowest , EmptyHighest , EmptyFirst , EmptyLast ,
  EmptyIgnore
 Sort policy (specifies how empty cells are taken into account when sorting) More...
virtual std::string Save ()
virtual void Load (const std::string &)
 SALOMEDSImpl_AttributeTableOfReal ()
void SetNbColumns (const int theNbColumns)
void SetTitle (const std::string &theTitle)
std::string GetTitle () const
void SetRowData (const int theRow, const std::vector< double > &theData)
std::vector< double > GetRowData (const int theRow)
void SetRowTitle (const int theRow, const std::string &theTitle)
void SetRowUnit (const int theRow, const std::string &theUnit)
std::string GetRowUnit (const int theRow) const
void SetRowUnits (const std::vector< std::string > &theUnits)
std::vector< std::string > GetRowUnits ()
void SetRowTitles (const std::vector< std::string > &theTitles)
std::vector< std::string > GetRowTitles ()
std::string GetRowTitle (const int theRow) const
void SetColumnData (const int theColumn, const std::vector< double > &theData)
std::vector< double > GetColumnData (const int theColumn)
void SetColumnTitle (const int theColumn, const std::string &theTitle)
void SetColumnTitles (const std::vector< std::string > &theTitles)
std::vector< std::string > GetColumnTitles ()
std::string GetColumnTitle (const int theColumn) const
int GetNbRows () const
int GetNbColumns () const
void PutValue (const double &theValue, const int theRow, const int theColumn)
bool HasValue (const int theRow, const int theColumn)
double GetValue (const int theRow, const int theColumn)
void RemoveValue (const int theRow, const int theColumn)
const std::string & ID () const
void Restore (DF_Attribute *with)
DF_Attribute * NewEmpty () const
void Paste (DF_Attribute *into)
std::vector< int > GetSetRowIndices (const int theRow)
std::vector< int > GetSetColumnIndices (const int theColumn)
std::vector< int > SortRow (const int theRow, SortOrder sortOrder, SortPolicy sortPolicy)
std::vector< int > SortColumn (const int theColumn, SortOrder sortOrder, SortPolicy sortPolicy)
std::vector< int > SortByRow (const int theRow, SortOrder sortOrder, SortPolicy sortPolicy)
std::vector< int > SortByColumn (const int theColumn, SortOrder sortOrder, SortPolicy sortPolicy)
void SwapCells (const int theRow1, const int theColumn1, const int theRow2, const int theColumn2)
void SwapRows (const int theRow1, const int theRow2)
void SwapColumns (const int theColumn1, const int theColumn2)
 ~SALOMEDSImpl_AttributeTableOfReal ()
virtual std::string Type ()
virtual void CheckLocked ()
std::string GetClassType ()
SALOMEDSImpl_SObject GetSObject ()
void SetModifyFlag (int reason=0)
 Set modification flag of the Attribute. More...
DF_Label Label () const
DF_Attribute * FindAttribute (const std::string &theID) const
virtual void AfterAddition ()
virtual void BeforeForget ()
static const std::string & GetID ()
static SALOMEDSImpl_AttributeTableOfReal * Set (const DF_Label &label)
static std::string Impl_GetType (DF_Attribute *theAttr)
static std::string Impl_GetClassType (DF_Attribute *theAttr)
static void Impl_CheckLocked (DF_Attribute *theAttr)
void Backup ()
std::string _type
DF_LabelNode * _node
std::map< int, double > myTable
std::string myTitle
std::vector< std::string > myRows
std::vector< std::string > myCols
int myNbRows
int myNbColumns
◆ SortOrder
Sort order.
AscendingOrder
The items are sorted ascending.
DescendingOrder
The items are sorted descending.
◆ SortPolicy
EmptyLowest
Empty cells are considered as lowest values.
EmptyHighest
Empty cells are considered as highest values.
EmptyFirst
Empty cells are always first.
EmptyLast
Empty cells are always last.
EmptyIgnore
Empty cells are ignored (stay at initial positions)
◆ SALOMEDSImpl_AttributeTableOfReal()
SALOMEDSImpl_AttributeTableOfReal::SALOMEDSImpl_AttributeTableOfReal ( )
References myNbColumns, and myNbRows.
Referenced by NewEmpty(), and Set().
◆ ~SALOMEDSImpl_AttributeTableOfReal()
SALOMEDSImpl_AttributeTableOfReal::~SALOMEDSImpl_AttributeTableOfReal ( )
◆ AfterAddition()
virtual void DF_Attribute::AfterAddition ( )
Reimplemented in SALOMEDSImpl_AttributeTreeNode.
Referenced by DF_Label::AddAttribute().
◆ Backup()
void DF_Attribute::Backup ( )
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTableOfInteger::Load(), Load(), SALOMEDSImpl_AttributeTableOfString::Load(), SALOMEDSImpl_AttributeParameter::Load(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeFlags::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributeOpened::SetOpened(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeSelectable::SetSelectable(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), and SALOMEDSImpl_AttributeGraphic::SetVisibility().
◆ BeforeForget()
virtual void DF_Attribute::BeforeForget ( )
◆ CheckLocked()
void SALOMEDSImpl_GenericAttribute::CheckLocked ( )
References SALOMEDSImpl_Study::_errorCode, SALOMEDSImpl_Study::GetStudyImpl(), SALOMEDSImpl_Study::IsLocked(), DF_Label::IsNull(), and DF_Attribute::Label().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDSImpl_GenericAttribute::Impl_CheckLocked(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SortByColumn(), SortByColumn(), SALOMEDSImpl_AttributeTableOfString::SortByColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortByRow(), SortByRow(), SALOMEDSImpl_AttributeTableOfString::SortByRow(), SALOMEDSImpl_AttributeTableOfInteger::SortColumn(), SortColumn(), SALOMEDSImpl_AttributeTableOfString::SortColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortRow(), SortRow(), SALOMEDSImpl_AttributeTableOfString::SortRow(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SwapCells(), SALOMEDSImpl_AttributeTableOfString::SwapCells(), SALOMEDSImpl_AttributeTableOfInteger::SwapColumns(), SwapColumns(), SALOMEDSImpl_AttributeTableOfString::SwapColumns(), SALOMEDSImpl_AttributeTableOfInteger::SwapRows(), SwapRows(), and SALOMEDSImpl_AttributeTableOfString::SwapRows().
◆ FindAttribute()
◆ GetClassType()
std::string SALOMEDSImpl_GenericAttribute::GetClassType ( )
◆ GetColumnData()
std::vector< double > SALOMEDSImpl_AttributeTableOfReal::GetColumnData ( const int  theColumn)
◆ GetColumnTitle()
std::string SALOMEDSImpl_AttributeTableOfReal::GetColumnTitle ( const int  theColumn) const
◆ GetColumnTitles()
std::vector< std::string > SALOMEDSImpl_AttributeTableOfReal::GetColumnTitles ( )
References myCols.
◆ GetID()
const std::string & SALOMEDSImpl_AttributeTableOfReal::GetID ( )
Referenced by ID(), and Set().
◆ GetNbColumns()
◆ GetNbRows()
◆ GetRowData()
std::vector< double > SALOMEDSImpl_AttributeTableOfReal::GetRowData ( const int  theRow)
◆ GetRowTitle()
std::string SALOMEDSImpl_AttributeTableOfReal::GetRowTitle ( const int  theRow) const
◆ GetRowTitles()
std::vector< std::string > SALOMEDSImpl_AttributeTableOfReal::GetRowTitles ( )
References getTitle(), and myRows.
◆ GetRowUnit()
std::string SALOMEDSImpl_AttributeTableOfReal::GetRowUnit ( const int  theRow) const
◆ GetRowUnits()
std::vector< std::string > SALOMEDSImpl_AttributeTableOfReal::GetRowUnits ( )
References getUnit(), and myRows.
◆ GetSetColumnIndices()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::GetSetColumnIndices ( const int  theColumn)
References myNbColumns, myNbRows, and myTable.
◆ GetSetRowIndices()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::GetSetRowIndices ( const int  theRow)
◆ GetSObject()
◆ GetTitle()
std::string SALOMEDSImpl_AttributeTableOfReal::GetTitle ( ) const
◆ GetValue()
double SALOMEDSImpl_AttributeTableOfReal::GetValue ( const int  theRow,
const int  theColumn
◆ HasValue()
bool SALOMEDSImpl_AttributeTableOfReal::HasValue ( const int  theRow,
const int  theColumn
Referenced by SortByColumn(), SortByRow(), SortColumn(), and SortRow().
◆ ID()
const std::string & SALOMEDSImpl_AttributeTableOfReal::ID ( ) const
Implements DF_Attribute.
References GetID().
◆ Impl_CheckLocked()
void SALOMEDSImpl_GenericAttribute::Impl_CheckLocked ( DF_Attribute *  theAttr)
◆ Impl_GetClassType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetClassType ( DF_Attribute *  theAttr)
◆ Impl_GetType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetType ( DF_Attribute *  theAttr)
◆ Label()
DF_Label DF_Attribute::Label ( ) const
References DF_Attribute::_node, and DF_Attribute::DF_Label.
Referenced by SALOMEDS_AttributeTarget_i::Add(), SALOMEDSImpl_UseCaseBuilder::Append(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_GenericAttribute::CheckLocked(), DF_Attribute::FindAttribute(), SALOMEDSImpl_UseCaseBuilder::GetCurrentObject(), SALOMEDSImpl_AttributeParameter::GetFather(), GetNode(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_UseCaseBuilder::GetSObject(), SALOMEDSImpl_UseCaseBuilder::HasChildren(), SALOMEDSImpl_AttributeParameter::HasFather(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_Study::IORUpdated(), SALOMEDSImpl_UseCaseBuilder::IsUseCaseNode(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeTreeNode_i::Label(), SALOMEDSImpl_AttributeTreeNode::Load(), SALOMEDSImpl_AttributeReference::Load(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_UseCaseBuilder::Remove(), SALOMEDS_AttributeTarget_i::Remove(), SALOMEDSImpl_UseCaseBuilder::SALOMEDSImpl_UseCaseBuilder(), SALOMEDSImpl_AttributeTreeNode::Save(), SALOMEDSImpl_UseCaseBuilder::SetCurrentObject(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), SALOMEDSImpl_UseCaseBuilder::SetName(), SALOMEDSImpl_UseCaseBuilder::SetRootCurrent(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_UseCaseBuilder::SortChildren(), Translate_persistentID_to_IOR(), SALOMEDSImpl_UseCaseIterator::Value(), and SALOMEDSImpl_AttributeIOR::~SALOMEDSImpl_AttributeIOR().
◆ Load()
void SALOMEDSImpl_AttributeTableOfReal::Load ( const std::string &  value)
◆ NewEmpty()
DF_Attribute * SALOMEDSImpl_AttributeTableOfReal::NewEmpty ( ) const
◆ Paste()
void SALOMEDSImpl_AttributeTableOfReal::Paste ( DF_Attribute *  into)
◆ PutValue()
void SALOMEDSImpl_AttributeTableOfReal::PutValue ( const double &  theValue,
const int  theRow,
const int  theColumn
◆ RemoveValue()
void SALOMEDSImpl_AttributeTableOfReal::RemoveValue ( const int  theRow,
const int  theColumn
◆ Restore()
void SALOMEDSImpl_AttributeTableOfReal::Restore ( DF_Attribute *  with)
◆ Save()
std::string SALOMEDSImpl_AttributeTableOfReal::Save ( )
◆ Set()
SALOMEDSImpl_AttributeTableOfReal * SALOMEDSImpl_AttributeTableOfReal::Set ( const DF_Label &  label)
◆ SetColumnData()
void SALOMEDSImpl_AttributeTableOfReal::SetColumnData ( const int  theColumn,
const std::vector< double > &  theData
◆ SetColumnTitle()
void SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle ( const int  theColumn,
const std::string &  theTitle
◆ SetColumnTitles()
void SALOMEDSImpl_AttributeTableOfReal::SetColumnTitles ( const std::vector< std::string > &  theTitles)
◆ SetModifyFlag()
void SALOMEDSImpl_GenericAttribute::SetModifyFlag ( int  reason = 0)
param reason reason of the modification (by default equal to 0)
References SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_Study::GetStudyImpl(), DF_Label::IsNull(), DF_Attribute::Label(), SALOMEDSImpl_Study::Modify(), and SALOMEDSImpl_Study::modifySO_Notification().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitles(), SetColumnTitles(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitles(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitles(), SetRowTitles(), SALOMEDSImpl_AttributeTableOfString::SetRowTitles(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnits(), SetRowUnits(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeTreeNode::SetTreeID(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SwapCells(), and SALOMEDSImpl_AttributeTableOfString::SwapCells().
◆ SetNbColumns()
◆ SetRowData()
void SALOMEDSImpl_AttributeTableOfReal::SetRowData ( const int  theRow,
◆ SetRowTitle()
◆ SetRowTitles()
void SALOMEDSImpl_AttributeTableOfReal::SetRowTitles ( const std::vector< std::string > &  theTitles)
< TODO: conversion from size_t to int
References GetNbRows(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), and SetRowTitle().
◆ SetRowUnit()
◆ SetRowUnits()
void SALOMEDSImpl_AttributeTableOfReal::SetRowUnits ( const std::vector< std::string > &  theUnits)
References GetNbRows(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), and SetRowUnit().
◆ SetTitle()
void SALOMEDSImpl_AttributeTableOfReal::SetTitle ( const std::string &  theTitle)
◆ SortByColumn()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::SortByColumn ( const int  theColumn,
◆ SortByRow()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::SortByRow ( const int  theRow,
◆ SortColumn()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::SortColumn ( const int  theColumn,
◆ SortRow()
std::vector< int > SALOMEDSImpl_AttributeTableOfReal::SortRow ( const int  theRow,
◆ SwapCells()
void SALOMEDSImpl_AttributeTableOfReal::SwapCells ( const int  theRow1,
const int  theRow2,
◆ SwapColumns()
void SALOMEDSImpl_AttributeTableOfReal::SwapColumns ( const int  theColumn1,
◆ SwapRows()
void SALOMEDSImpl_AttributeTableOfReal::SwapRows ( const int  theRow1,
const int  theRow2
◆ Type()
◆ _node
◆ _type
◆ myCols
std::vector<std::string> SALOMEDSImpl_AttributeTableOfReal::myCols
◆ myNbColumns
◆ myNbRows
◆ myRows
std::vector<std::string> SALOMEDSImpl_AttributeTableOfReal::myRows
◆ myTable
◆ myTitle
std::string SALOMEDSImpl_AttributeTableOfReal::myTitle
