KERNEL_PY.kernel.uiexception.UiException Class Reference
This exception should be used for functionnal error management, at least in the GUI part of the application, for example to set user oriented messages at point of exception raise. More...
Inheritance diagram for KERNEL_PY.kernel.uiexception.UiException:
def __init__ (self, message, type=TYPES.USER)
 Canonical constructor. More...
def setUIMessage (self, UImessage)
def getUIMessage (self)
def setType (self, type)
 Specify the type of this exception. More...
def getType (self)
def __str__ (self)
Static Public Attributes
 TYPES
 _UImessage
Static Private Attributes
string _UImessage = "An error occurs"
 _type = TYPES.USER
Warning
The exception should NOT be used to hide defaults in the algorithm, but only predicted error in the specified use case.
◆ __init__()
def KERNEL_PY.kernel.uiexception.UiException.__init__ (   self,
  message,
  type = TYPES.USER
◆ __str__()
def KERNEL_PY.kernel.uiexception.UiException.__str__ (   self)
◆ getType()
◆ getUIMessage()
◆ setType()
◆ setUIMessage()
def KERNEL_PY.kernel.uiexception.UiException.setUIMessage (   self,
  UImessage
◆ _type
◆ _UImessage [1/2]
string KERNEL_PY.kernel.uiexception.UiException._UImessage = "An error occurs"
staticprivate
◆ _UImessage [2/2]
◆ TYPES
KERNEL_PY.kernel.uiexception.UiException.TYPES
Initial value:
= Enumerate([
'USER', # This type should be displayed to end user using a dialog box
'ADMIN', # This type should be displayed to admin user in console log
'DEVEL' # This type should be displayed to developer only
Referenced by uiexception.UiException.setType(), and KERNEL_PY.kernel.uiexception.UiException.setType().
