SALOMEDSImpl_AttributeStudyProperties Class Reference
#include <SALOMEDSImpl_AttributeStudyProperties.hxx>
Inheritance diagram for SALOMEDSImpl_AttributeStudyProperties:
 SALOMEDSImpl_AttributeStudyProperties ()
 ~SALOMEDSImpl_AttributeStudyProperties ()
const std::string & ID () const
void Init ()
virtual std::string Save ()
virtual void Load (const std::string &)
void SetModification (const std::string &theUserName, const int theMinute, const int theHour, const int theDay, const int theMonth, const int theYear)
void GetModifications (std::vector< std::string > &theUserNames, std::vector< int > &theMinutes, std::vector< int > &theHours, std::vector< int > &theDays, std::vector< int > &theMonths, std::vector< int > &theYears) const
std::string GetCreatorName () const
bool GetCreationDate (int &theMinute, int &theHour, int &theDay, int &theMonth, int &theYear) const
void ChangeCreatorName (const std::string &theUserName)
void SetUnits (const std::string &theUnits)
std::string GetUnits () const
void SetComment (const std::string &theComment)
std::string GetComment () const
void SetCreationMode (const int theMode)
int GetCreationMode () const
void SetModified (const int theModified)
bool IsModified () const
int GetModified () const
void SetLocked (const bool theLocked)
bool IsLocked () const
bool IsLockChanged (const bool theErase)
void SetComponentsVersions (const std::map< std::string, std::vector< std::string > > &theVersions)
void SetComponentVersion (const std::string &theComponent, const std::string &theVersion)
std::vector< std::string > GetStoredComponents () const
std::string GetComponentVersion (const std::string &theComponent) const
std::vector< std::string > GetComponentVersions (const std::string &theComponent) const
std::map< std::string, std::vector< std::string > > GetComponentsVersions () const
void Restore (DF_Attribute *with)
DF_Attribute * NewEmpty () const
void Paste (DF_Attribute *into)
virtual std::string Type ()
virtual void CheckLocked ()
std::string GetClassType ()
SALOMEDSImpl_SObject GetSObject ()
void SetModifyFlag (int reason=0)
 Set modification flag of the Attribute. More...
DF_Label Label () const
DF_Attribute * FindAttribute (const std::string &theID) const
virtual void AfterAddition ()
virtual void BeforeForget ()
static const std::string & GetID ()
static SALOMEDSImpl_AttributeStudyProperties * Set (const DF_Label &label)
static std::string Impl_GetType (DF_Attribute *theAttr)
static std::string Impl_GetClassType (DF_Attribute *theAttr)
static void Impl_CheckLocked (DF_Attribute *theAttr)
void Backup ()
std::string _type
DF_LabelNode * _node
Private Types
typedef std::vector< std::string > versionList
typedef std::map< std::string, versionList > versionMap
std::vector< std::string > myUserName
std::vector< int > myMinute
std::vector< int > myHour
std::vector< int > myDay
std::vector< int > myMonth
std::vector< int > myYear
std::string myUnits
std::string myComment
int myMode
int myModified
bool myLocked
bool myLockChanged
versionMap myComponentVersions
◆ versionList
typedef std::vector<std::string> SALOMEDSImpl_AttributeStudyProperties::versionList
◆ versionMap
typedef std::map<std::string, versionList> SALOMEDSImpl_AttributeStudyProperties::versionMap
◆ SALOMEDSImpl_AttributeStudyProperties()
SALOMEDSImpl_AttributeStudyProperties::SALOMEDSImpl_AttributeStudyProperties ( )
References Init(), myLockChanged, myLocked, and myModified.
Referenced by NewEmpty(), and Set().
◆ ~SALOMEDSImpl_AttributeStudyProperties()
SALOMEDSImpl_AttributeStudyProperties::~SALOMEDSImpl_AttributeStudyProperties ( )
◆ AfterAddition()
virtual void DF_Attribute::AfterAddition ( )
Reimplemented in SALOMEDSImpl_AttributeTreeNode.
Referenced by DF_Label::AddAttribute().
◆ Backup()
void DF_Attribute::Backup ( )
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTableOfInteger::Load(), SALOMEDSImpl_AttributeTableOfReal::Load(), SALOMEDSImpl_AttributeTableOfString::Load(), SALOMEDSImpl_AttributeParameter::Load(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeFlags::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SetComment(), SetComponentVersion(), SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributeOpened::SetOpened(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeSelectable::SetSelectable(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), and SALOMEDSImpl_AttributeGraphic::SetVisibility().
◆ BeforeForget()
virtual void DF_Attribute::BeforeForget ( )
◆ ChangeCreatorName()
void SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName ( const std::string &  theUserName)
◆ CheckLocked()
void SALOMEDSImpl_GenericAttribute::CheckLocked ( )
References SALOMEDSImpl_Study::_errorCode, SALOMEDSImpl_Study::GetStudyImpl(), SALOMEDSImpl_Study::IsLocked(), DF_Label::IsNull(), and DF_Attribute::Label().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDSImpl_GenericAttribute::Impl_CheckLocked(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SetComment(), SetComponentVersion(), SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SortByColumn(), SALOMEDSImpl_AttributeTableOfReal::SortByColumn(), SALOMEDSImpl_AttributeTableOfString::SortByColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortByRow(), SALOMEDSImpl_AttributeTableOfReal::SortByRow(), SALOMEDSImpl_AttributeTableOfString::SortByRow(), SALOMEDSImpl_AttributeTableOfInteger::SortColumn(), SALOMEDSImpl_AttributeTableOfReal::SortColumn(), SALOMEDSImpl_AttributeTableOfString::SortColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortRow(), SALOMEDSImpl_AttributeTableOfReal::SortRow(), SALOMEDSImpl_AttributeTableOfString::SortRow(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), SALOMEDSImpl_AttributeTableOfString::SwapCells(), SALOMEDSImpl_AttributeTableOfInteger::SwapColumns(), SALOMEDSImpl_AttributeTableOfReal::SwapColumns(), SALOMEDSImpl_AttributeTableOfString::SwapColumns(), SALOMEDSImpl_AttributeTableOfInteger::SwapRows(), SALOMEDSImpl_AttributeTableOfReal::SwapRows(), and SALOMEDSImpl_AttributeTableOfString::SwapRows().
◆ FindAttribute()
◆ GetClassType()
std::string SALOMEDSImpl_GenericAttribute::GetClassType ( )
◆ GetComment()
std::string SALOMEDSImpl_AttributeStudyProperties::GetComment ( ) const
◆ GetComponentsVersions()
std::map< std::string, std::vector< std::string > > SALOMEDSImpl_AttributeStudyProperties::GetComponentsVersions ( ) const
◆ GetComponentVersion()
std::string SALOMEDSImpl_AttributeStudyProperties::GetComponentVersion ( const std::string &  theComponent) const
◆ GetComponentVersions()
std::vector< std::string > SALOMEDSImpl_AttributeStudyProperties::GetComponentVersions ( const std::string &  theComponent) const
References myComponentVersions.
Referenced by GetComponentVersion().
◆ GetCreationDate()
bool SALOMEDSImpl_AttributeStudyProperties::GetCreationDate ( int &  theMinute,
int &  theHour,
int &  theDay,
int &  theMonth,
int &  theYear
◆ GetCreationMode()
int SALOMEDSImpl_AttributeStudyProperties::GetCreationMode ( ) const
◆ GetCreatorName()
std::string SALOMEDSImpl_AttributeStudyProperties::GetCreatorName ( ) const
References myUserName.
◆ GetID()
const std::string & SALOMEDSImpl_AttributeStudyProperties::GetID ( )
Referenced by ID(), and Set().
◆ GetModifications()
void SALOMEDSImpl_AttributeStudyProperties::GetModifications ( std::vector< std::string > &  theUserNames,
std::vector< int > &  theMinutes,
std::vector< int > &  theHours,
std::vector< int > &  theDays,
std::vector< int > &  theMonths,
std::vector< int > &  theYears
◆ GetModified()
int SALOMEDSImpl_AttributeStudyProperties::GetModified ( ) const
◆ GetSObject()
◆ GetStoredComponents()
std::vector< std::string > SALOMEDSImpl_AttributeStudyProperties::GetStoredComponents ( ) const
◆ GetUnits()
std::string SALOMEDSImpl_AttributeStudyProperties::GetUnits ( ) const
References myUnits.
Referenced by SALOMEDSImpl_Study::Impl_SaveProperties(), and Save().
◆ ID()
const std::string & SALOMEDSImpl_AttributeStudyProperties::ID ( ) const
Implements DF_Attribute.
References GetID().
◆ Impl_CheckLocked()
void SALOMEDSImpl_GenericAttribute::Impl_CheckLocked ( DF_Attribute *  theAttr)
◆ Impl_GetClassType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetClassType ( DF_Attribute *  theAttr)
◆ Impl_GetType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetType ( DF_Attribute *  theAttr)
◆ Init()
void SALOMEDSImpl_AttributeStudyProperties::Init ( )
◆ IsLockChanged()
bool SALOMEDSImpl_AttributeStudyProperties::IsLockChanged ( const bool  theErase)
◆ IsLocked()
◆ IsModified()
bool SALOMEDSImpl_AttributeStudyProperties::IsModified ( ) const
References myModified.
◆ Label()
DF_Label DF_Attribute::Label ( ) const
References DF_Attribute::_node, and DF_Attribute::DF_Label.
Referenced by SALOMEDS_AttributeTarget_i::Add(), SALOMEDSImpl_UseCaseBuilder::Append(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_GenericAttribute::CheckLocked(), DF_Attribute::FindAttribute(), SALOMEDSImpl_UseCaseBuilder::GetCurrentObject(), SALOMEDSImpl_AttributeParameter::GetFather(), GetNode(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_UseCaseBuilder::GetSObject(), SALOMEDSImpl_UseCaseBuilder::HasChildren(), SALOMEDSImpl_AttributeParameter::HasFather(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_Study::IORUpdated(), SALOMEDSImpl_UseCaseBuilder::IsUseCaseNode(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeTreeNode_i::Label(), SALOMEDSImpl_AttributeTreeNode::Load(), SALOMEDSImpl_AttributeReference::Load(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_UseCaseBuilder::Remove(), SALOMEDS_AttributeTarget_i::Remove(), SALOMEDSImpl_UseCaseBuilder::SALOMEDSImpl_UseCaseBuilder(), SALOMEDSImpl_AttributeTreeNode::Save(), SALOMEDSImpl_UseCaseBuilder::SetCurrentObject(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), SALOMEDSImpl_UseCaseBuilder::SetName(), SALOMEDSImpl_UseCaseBuilder::SetRootCurrent(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_UseCaseBuilder::SortChildren(), Translate_persistentID_to_IOR(), SALOMEDSImpl_UseCaseIterator::Value(), and SALOMEDSImpl_AttributeIOR::~SALOMEDSImpl_AttributeIOR().
◆ Load()
void SALOMEDSImpl_AttributeStudyProperties::Load ( const std::string &  value)
◆ NewEmpty()
DF_Attribute * SALOMEDSImpl_AttributeStudyProperties::NewEmpty ( ) const
◆ Paste()
void SALOMEDSImpl_AttributeStudyProperties::Paste ( DF_Attribute *  into)
◆ Restore()
void SALOMEDSImpl_AttributeStudyProperties::Restore ( DF_Attribute *  with)
◆ Save()
std::string SALOMEDSImpl_AttributeStudyProperties::Save ( )
< TODO: conversion from size_t to int
Reimplemented from DF_Attribute.
References TestSalomeSDS1::a, GetComment(), GetCreationMode(), GetModifications(), GetUnits(), IsLocked(), and myComponentVersions.
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::SaveASCII().
◆ Set()
◆ SetComment()
void SALOMEDSImpl_AttributeStudyProperties::SetComment ( const std::string &  theComment)
◆ SetComponentsVersions()
void SALOMEDSImpl_AttributeStudyProperties::SetComponentsVersions ( const std::map< std::string, std::vector< std::string > > &  theVersions)
Referenced by Paste().
◆ SetComponentVersion()
void SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion ( const std::string &  theComponent,
const std::string &  theVersion
◆ SetCreationMode()
void SALOMEDSImpl_AttributeStudyProperties::SetCreationMode ( const int  theMode)
◆ SetLocked()
void SALOMEDSImpl_AttributeStudyProperties::SetLocked ( const bool  theLocked)
◆ SetModification()
void SALOMEDSImpl_AttributeStudyProperties::SetModification ( const std::string &  theUserName,
const int  theHour,
const int  theDay,
const int  theMonth,
const int  theYear
◆ SetModified()
void SALOMEDSImpl_AttributeStudyProperties::SetModified ( const int  theModified)
◆ SetModifyFlag()
void SALOMEDSImpl_GenericAttribute::SetModifyFlag ( int  reason = 0)
param reason reason of the modification (by default equal to 0)
References SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_Study::GetStudyImpl(), DF_Label::IsNull(), DF_Attribute::Label(), SALOMEDSImpl_Study::Modify(), and SALOMEDSImpl_Study::modifySO_Notification().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitles(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitles(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitles(), SALOMEDSImpl_AttributeTableOfString::SetRowTitles(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnits(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnits(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeTreeNode::SetTreeID(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), and SALOMEDSImpl_AttributeTableOfString::SwapCells().
◆ SetUnits()
void SALOMEDSImpl_AttributeStudyProperties::SetUnits ( const std::string &  theUnits)
◆ Type()
◆ _node
◆ _type
◆ myComment
std::string SALOMEDSImpl_AttributeStudyProperties::myComment
Referenced by GetComment(), and SetComment().
◆ myComponentVersions
versionMap SALOMEDSImpl_AttributeStudyProperties::myComponentVersions
◆ myDay
std::vector<int> SALOMEDSImpl_AttributeStudyProperties::myDay
◆ myHour
std::vector<int> SALOMEDSImpl_AttributeStudyProperties::myHour
◆ myLockChanged
bool SALOMEDSImpl_AttributeStudyProperties::myLockChanged
◆ myLocked
bool SALOMEDSImpl_AttributeStudyProperties::myLocked
◆ myMinute
std::vector<int> SALOMEDSImpl_AttributeStudyProperties::myMinute
◆ myMode
int SALOMEDSImpl_AttributeStudyProperties::myMode
◆ myModified
int SALOMEDSImpl_AttributeStudyProperties::myModified
◆ myMonth
std::vector<int> SALOMEDSImpl_AttributeStudyProperties::myMonth
◆ myUnits
std::string SALOMEDSImpl_AttributeStudyProperties::myUnits
Referenced by GetUnits(), and SetUnits().
◆ myUserName
std::vector<std::string> SALOMEDSImpl_AttributeStudyProperties::myUserName
◆ myYear
std::vector<int> SALOMEDSImpl_AttributeStudyProperties::myYear
