SALOMEDS_AttributeTreeNode_i Class Reference
#include <SALOMEDS_AttributeTreeNode_i.hxx>
Inheritance diagram for SALOMEDS_AttributeTreeNode_i:
 SALOMEDS_AttributeTreeNode_i (SALOMEDSImpl_AttributeTreeNode *theAttr, CORBA::ORB_ptr orb)
 ~SALOMEDS_AttributeTreeNode_i ()
void SetFather (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean HasFather ()
SALOMEDS::AttributeTreeNode_ptr GetFather ()
void SetPrevious (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean HasPrevious ()
SALOMEDS::AttributeTreeNode_ptr GetPrevious ()
void SetNext (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean HasNext ()
SALOMEDS::AttributeTreeNode_ptr GetNext ()
void SetFirst (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean HasFirst ()
SALOMEDS::AttributeTreeNode_ptr GetFirst ()
void SetTreeID (const char *value)
char * GetTreeID ()
void Append (SALOMEDS::AttributeTreeNode_ptr value)
void Prepend (SALOMEDS::AttributeTreeNode_ptr value)
void InsertBefore (SALOMEDS::AttributeTreeNode_ptr value)
void InsertAfter (SALOMEDS::AttributeTreeNode_ptr value)
void Remove ()
CORBA::Long Depth ()
CORBA::Boolean IsRoot ()
CORBA::Boolean IsDescendant (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean IsFather (SALOMEDS::AttributeTreeNode_ptr value)
CORBA::Boolean IsChild (SALOMEDS::AttributeTreeNode_ptr value)
char * Label ()
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
void CheckLocked ()
virtual char * Type ()
char * GetClassType ()
SALOMEDS::SObject_ptr GetSObject ()
virtual DF_Attribute * GetImpl ()
virtual CORBA::LongLong GetLocalImpl (const char *theHostname, CORBA::Long thePID, CORBA::Boolean &isLocal)
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
static SALOMEDS::GenericAttribute_ptr CreateAttribute (DF_Attribute *theAttr, CORBA::ORB_ptr theOrb)
DF_Attribute * _impl
CORBA::ORB_var _orb
PortableServer::POA_var myPOA
int myRefCounter
◆ SALOMEDS_AttributeTreeNode_i()
SALOMEDS_AttributeTreeNode_i::SALOMEDS_AttributeTreeNode_i ( SALOMEDSImpl_AttributeTreeNode *  theAttr,
CORBA::ORB_ptr  orb
◆ ~SALOMEDS_AttributeTreeNode_i()
SALOMEDS_AttributeTreeNode_i::~SALOMEDS_AttributeTreeNode_i ( )
◆ _default_POA()
PortableServer::POA_ptr SALOMEDS_GenericAttribute_i::_default_POA ( )
reference to the default POA for the servant
◆ Append()
void SALOMEDS_AttributeTreeNode_i::Append ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ CheckLocked()
void SALOMEDS_GenericAttribute_i::CheckLocked ( )
Referenced by SALOMEDS_AttributeSequenceOfReal_i::Add(), SALOMEDS_AttributeSequenceOfInteger_i::Add(), SALOMEDS_AttributeTableOfReal_i::AddColumn(), SALOMEDS_AttributeTableOfInteger_i::AddColumn(), SALOMEDS_AttributeTableOfString_i::AddColumn(), SALOMEDS_AttributeTableOfReal_i::AddRow(), SALOMEDS_AttributeTableOfInteger_i::AddRow(), SALOMEDS_AttributeTableOfString_i::AddRow(), Append(), SALOMEDS_AttributeSequenceOfReal_i::Assign(), SALOMEDS_AttributeSequenceOfInteger_i::Assign(), SALOMEDS_AttributeSequenceOfReal_i::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger_i::ChangeValue(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitle(), SALOMEDS_AttributeTableOfString_i::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitle(), SALOMEDS_AttributeTableOfReal_i::GetRowTitle(), SALOMEDS_AttributeTableOfString_i::GetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnit(), SALOMEDS_AttributeTableOfReal_i::GetRowUnit(), SALOMEDS_AttributeTableOfString_i::GetRowUnit(), InsertAfter(), InsertBefore(), Prepend(), SALOMEDS_AttributeTableOfString_i::PutValue(), SALOMEDS_AttributeTableOfReal_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::PutValue(), Remove(), SALOMEDS_AttributeSequenceOfInteger_i::Remove(), SALOMEDS_AttributeSequenceOfReal_i::Remove(), SALOMEDS_AttributeParameter_i::RemoveID(), SALOMEDS_AttributeParameter_i::SetBool(), SALOMEDS_AttributeTableOfReal_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumn(), SALOMEDS_AttributeTableOfString_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitle(), SALOMEDS_AttributeTableOfString_i::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitles(), SALOMEDS_AttributeTableOfString_i::SetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::SetComment(), SALOMEDS_AttributeStudyProperties_i::SetCreationDate(), SALOMEDS_AttributeStudyProperties_i::SetCreationMode(), SALOMEDS_AttributeDrawable_i::SetDrawable(), SALOMEDS_AttributeExpandable_i::SetExpandable(), SetFather(), SetFirst(), SALOMEDS_AttributeParameter_i::SetIntArray(), SALOMEDS_AttributeStudyProperties_i::SetModification(), SetNext(), SALOMEDS_AttributePythonObject_i::SetObject(), SALOMEDS_AttributePixMap_i::SetPixMap(), SetPrevious(), SALOMEDS_AttributeParameter_i::SetReal(), SALOMEDS_AttributeParameter_i::SetRealArray(), SALOMEDS_AttributeTableOfReal_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRow(), SALOMEDS_AttributeTableOfString_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitle(), SALOMEDS_AttributeTableOfReal_i::SetRowTitle(), SALOMEDS_AttributeTableOfString_i::SetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitles(), SALOMEDS_AttributeTableOfReal_i::SetRowTitles(), SALOMEDS_AttributeTableOfString_i::SetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnit(), SALOMEDS_AttributeTableOfReal_i::SetRowUnit(), SALOMEDS_AttributeTableOfString_i::SetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnits(), SALOMEDS_AttributeTableOfReal_i::SetRowUnits(), SALOMEDS_AttributeTableOfString_i::SetRowUnits(), SALOMEDS_AttributeParameter_i::SetStrArray(), SALOMEDS_AttributeParameter_i::SetString(), SALOMEDS_AttributeTextColor_i::SetTextColor(), SALOMEDS_AttributeTextHighlightColor_i::SetTextHighlightColor(), SetTreeID(), SALOMEDS_AttributeStudyProperties_i::SetUnits(), SALOMEDS_AttributeStudyProperties_i::SetUserName(), SALOMEDS_AttributeComment_i::SetValue(), SALOMEDS_AttributeExternalFileDef_i::SetValue(), SALOMEDS_AttributeFileType_i::SetValue(), SALOMEDS_AttributeIOR_i::SetValue(), SALOMEDS_AttributeName_i::SetValue(), SALOMEDS_AttributePersistentRef_i::SetValue(), SALOMEDS_AttributeString_i::SetValue(), SALOMEDS_AttributeUserID_i::SetValue(), SALOMEDS_AttributeReal_i::SetValue(), SALOMEDS_AttributeInteger_i::SetValue(), SALOMEDS_AttributeLocalID_i::SetValue(), SALOMEDS_AttributeTableOfInteger_i::SortByColumn(), SALOMEDS_AttributeTableOfReal_i::SortByColumn(), SALOMEDS_AttributeTableOfString_i::SortByColumn(), SALOMEDS_AttributeTableOfInteger_i::SortByRow(), SALOMEDS_AttributeTableOfReal_i::SortByRow(), SALOMEDS_AttributeTableOfString_i::SortByRow(), SALOMEDS_AttributeTableOfInteger_i::SortColumn(), SALOMEDS_AttributeTableOfReal_i::SortColumn(), SALOMEDS_AttributeTableOfString_i::SortColumn(), SALOMEDS_AttributeTableOfInteger_i::SortRow(), SALOMEDS_AttributeTableOfReal_i::SortRow(), SALOMEDS_AttributeTableOfString_i::SortRow(), SALOMEDS_AttributeTableOfInteger_i::SwapCells(), SALOMEDS_AttributeTableOfReal_i::SwapCells(), SALOMEDS_AttributeTableOfString_i::SwapCells(), SALOMEDS_AttributeTableOfInteger_i::SwapColumns(), SALOMEDS_AttributeTableOfReal_i::SwapColumns(), SALOMEDS_AttributeTableOfString_i::SwapColumns(), SALOMEDS_AttributeTableOfInteger_i::SwapRows(), SALOMEDS_AttributeTableOfReal_i::SwapRows(), SALOMEDS_AttributeTableOfString_i::SwapRows(), and UNEXPECT_CATCH().
◆ CreateAttribute()
SALOMEDS::GenericAttribute_ptr SALOMEDS_GenericAttribute_i::CreateAttribute ( DF_Attribute *  theAttr,
◆ Depth()
CORBA::Long SALOMEDS_AttributeTreeNode_i::Depth ( )
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ GetClassType()
◆ GetFather()
SALOMEDS::AttributeTreeNode_ptr SALOMEDS_AttributeTreeNode_i::GetFather ( )
◆ GetFirst()
SALOMEDS::AttributeTreeNode_ptr SALOMEDS_AttributeTreeNode_i::GetFirst ( )
◆ GetImpl()
virtual DF_Attribute * SALOMEDS_GenericAttribute_i::GetImpl ( )
◆ GetLocalImpl()
CORBA::LongLong SALOMEDS_GenericAttribute_i::GetLocalImpl ( const char *  theHostname,
CORBA::Long  thePID,
CORBA::Boolean &  isLocal
◆ GetNext()
SALOMEDS::AttributeTreeNode_ptr SALOMEDS_AttributeTreeNode_i::GetNext ( )
◆ GetPrevious()
SALOMEDS::AttributeTreeNode_ptr SALOMEDS_AttributeTreeNode_i::GetPrevious ( )
◆ GetSObject()
◆ GetTreeID()
char * SALOMEDS_AttributeTreeNode_i::GetTreeID ( )
◆ HasFather()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::HasFather ( )
◆ HasFirst()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::HasFirst ( )
◆ HasNext()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::HasNext ( )
◆ HasPrevious()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::HasPrevious ( )
◆ InsertAfter()
void SALOMEDS_AttributeTreeNode_i::InsertAfter ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ InsertBefore()
void SALOMEDS_AttributeTreeNode_i::InsertBefore ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ IsChild()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::IsChild ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ IsDescendant()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::IsDescendant ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ IsFather()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::IsFather ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ IsRoot()
CORBA::Boolean SALOMEDS_AttributeTreeNode_i::IsRoot ( )
◆ Label()
char * SALOMEDS_AttributeTreeNode_i::Label ( )
◆ Prepend()
void SALOMEDS_AttributeTreeNode_i::Prepend ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ Remove()
◆ SetFather()
void SALOMEDS_AttributeTreeNode_i::SetFather ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ SetFirst()
void SALOMEDS_AttributeTreeNode_i::SetFirst ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ SetNext()
void SALOMEDS_AttributeTreeNode_i::SetNext ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ SetPrevious()
void SALOMEDS_AttributeTreeNode_i::SetPrevious ( SALOMEDS::AttributeTreeNode_ptr  value)
◆ SetTreeID()
◆ Type()
char * SALOMEDS_GenericAttribute_i::Type ( )
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _impl
DF_Attribute* SALOMEDS_GenericAttribute_i::_impl
Referenced by SALOMEDS_AttributeSequenceOfReal_i::Add(), SALOMEDS_AttributeSequenceOfInteger_i::Add(), SALOMEDS_AttributeTarget_i::Add(), SALOMEDS_AttributeTableOfReal_i::AddColumn(), SALOMEDS_AttributeTableOfInteger_i::AddColumn(), SALOMEDS_AttributeTableOfString_i::AddColumn(), SALOMEDS_AttributeTableOfReal_i::AddRow(), SALOMEDS_AttributeTableOfInteger_i::AddRow(), SALOMEDS_AttributeTableOfString_i::AddRow(), Append(), SALOMEDS_AttributeSequenceOfReal_i::Assign(), SALOMEDS_AttributeSequenceOfInteger_i::Assign(), SALOMEDS_AttributeSequenceOfReal_i::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger_i::ChangeValue(), SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS_AttributeParameter_i::Clear(), SALOMEDS_AttributeSequenceOfInteger_i::CorbaSequence(), SALOMEDS_AttributeSequenceOfReal_i::CorbaSequence(), Depth(), SALOMEDS_AttributeTarget_i::Get(), SALOMEDS_AttributeFlags_i::Get(), SALOMEDS_AttributeParameter_i::GetBool(), SALOMEDS_GenericAttribute_i::GetClassType(), SALOMEDS_AttributeTableOfInteger_i::GetColumn(), SALOMEDS_AttributeTableOfReal_i::GetColumn(), SALOMEDS_AttributeTableOfString_i::GetColumn(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitle(), SALOMEDS_AttributeTableOfString_i::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitles(), SALOMEDS_AttributeTableOfString_i::GetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::GetComment(), SALOMEDS_AttributeStudyProperties_i::GetComponentVersion(), SALOMEDS_AttributeStudyProperties_i::GetComponentVersions(), SALOMEDS_AttributeStudyProperties_i::GetCreationDate(), SALOMEDS_AttributeStudyProperties_i::GetCreationMode(), SALOMEDS_AttributeParameter_i::GetFather(), GetFather(), GetFirst(), SALOMEDS_AttributeFlags_i::GetFlags(), SALOMEDS_AttributeParameter_i::GetIDs(), SALOMEDS_AttributeParameter_i::GetInt(), SALOMEDS_AttributeParameter_i::GetIntArray(), SALOMEDS_GenericAttribute_i::GetLocalImpl(), SALOMEDS_AttributeStudyProperties_i::GetModificationsList(), SALOMEDS_AttributeStudyProperties_i::GetModified(), SALOMEDS_AttributeTableOfInteger_i::GetNbColumns(), SALOMEDS_AttributeTableOfReal_i::GetNbColumns(), SALOMEDS_AttributeTableOfString_i::GetNbColumns(), SALOMEDS_AttributeTableOfInteger_i::GetNbRows(), SALOMEDS_AttributeTableOfReal_i::GetNbRows(), SALOMEDS_AttributeTableOfString_i::GetNbRows(), GetNext(), SALOMEDS_AttributePythonObject_i::GetObject(), SALOMEDS_AttributePixMap_i::GetPixMap(), GetPrevious(), SALOMEDS_AttributeParameter_i::GetReal(), SALOMEDS_AttributeParameter_i::GetRealArray(), SALOMEDS_AttributeTableOfInteger_i::GetRow(), SALOMEDS_AttributeTableOfReal_i::GetRow(), SALOMEDS_AttributeTableOfString_i::GetRow(), SALOMEDS_AttributeTableOfInteger_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfReal_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfString_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitle(), SALOMEDS_AttributeTableOfReal_i::GetRowTitle(), SALOMEDS_AttributeTableOfString_i::GetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitles(), SALOMEDS_AttributeTableOfReal_i::GetRowTitles(), SALOMEDS_AttributeTableOfString_i::GetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnit(), SALOMEDS_AttributeTableOfReal_i::GetRowUnit(), SALOMEDS_AttributeTableOfString_i::GetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnits(), SALOMEDS_AttributeTableOfReal_i::GetRowUnits(), SALOMEDS_AttributeTableOfString_i::GetRowUnits(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDS_AttributeStudyProperties_i::GetStoredComponents(), SALOMEDS_AttributeParameter_i::GetStrArray(), SALOMEDS_AttributeParameter_i::GetString(), SALOMEDS_AttributeTableOfInteger_i::GetTitle(), SALOMEDS_AttributeTableOfReal_i::GetTitle(), SALOMEDS_AttributeTableOfString_i::GetTitle(), GetTreeID(), SALOMEDS_AttributeStudyProperties_i::GetUnits(), SALOMEDS_AttributeStudyProperties_i::GetUserName(), SALOMEDS_AttributeTableOfInteger_i::GetValue(), SALOMEDS_AttributeTableOfReal_i::GetValue(), SALOMEDS_AttributeTableOfString_i::GetValue(), SALOMEDS_AttributeGraphic_i::GetVisibility(), SALOMEDS_AttributeParameter_i::HasFather(), HasFather(), HasFirst(), HasNext(), SALOMEDS_AttributePixMap_i::HasPixMap(), HasPrevious(), SALOMEDS_AttributeTableOfInteger_i::HasValue(), SALOMEDS_AttributeTableOfReal_i::HasValue(), SALOMEDS_AttributeTableOfString_i::HasValue(), InsertAfter(), InsertBefore(), IsChild(), IsDescendant(), SALOMEDS_AttributeDrawable_i::IsDrawable(), SALOMEDS_AttributeExpandable_i::IsExpandable(), IsFather(), SALOMEDS_AttributeStudyProperties_i::IsLocked(), SALOMEDS_AttributeStudyProperties_i::IsModified(), SALOMEDS_AttributeOpened_i::IsOpened(), SALOMEDS_AttributeParameter_i::IsRoot(), IsRoot(), SALOMEDS_AttributePythonObject_i::IsScript(), SALOMEDS_AttributeSelectable_i::IsSelectable(), SALOMEDS_AttributeParameter_i::IsSet(), Label(), SALOMEDS_AttributeSequenceOfInteger_i::Length(), SALOMEDS_AttributeSequenceOfReal_i::Length(), Prepend(), SALOMEDS_AttributeTableOfString_i::PutValue(), SALOMEDS_AttributeTableOfReal_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::ReadFromFile(), SALOMEDS_AttributeTableOfReal_i::ReadFromFile(), SALOMEDS_AttributeTableOfString_i::ReadFromFile(), SALOME_Embedded_NamingService.SALOME_Embedded_NamingService::Register(), Remove(), SALOMEDS_AttributeSequenceOfInteger_i::Remove(), SALOMEDS_AttributeSequenceOfReal_i::Remove(), SALOMEDS_AttributeTarget_i::Remove(), SALOMEDS_AttributeParameter_i::RemoveID(), SALOMEDS_AttributeTableOfInteger_i::RemoveValue(), SALOMEDS_AttributeTableOfReal_i::RemoveValue(), SALOMEDS_AttributeTableOfString_i::RemoveValue(), SALOME_Embedded_NamingService.SALOME_Embedded_NamingService::Resolve(), SALOMEDS_AttributeTableOfInteger_i::SaveToFile(), SALOMEDS_AttributeTableOfReal_i::SaveToFile(), SALOMEDS_AttributeTableOfString_i::SaveToFile(), SALOMEDS_AttributeFlags_i::Set(), SALOMEDS_AttributeParameter_i::SetBool(), SALOMEDS_AttributeTableOfReal_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumn(), SALOMEDS_AttributeTableOfString_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitle(), SALOMEDS_AttributeTableOfString_i::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitles(), SALOMEDS_AttributeTableOfString_i::SetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::SetComment(), SALOMEDS_AttributeStudyProperties_i::SetCreationDate(), SALOMEDS_AttributeStudyProperties_i::SetCreationMode(), SALOMEDS_AttributeDrawable_i::SetDrawable(), SALOMEDS_AttributeExpandable_i::SetExpandable(), SetFather(), SetFirst(), SALOMEDS_AttributeFlags_i::SetFlags(), SALOMEDS_AttributeParameter_i::SetIntArray(), SALOMEDS_AttributeStudyProperties_i::SetLocked(), SALOMEDS_AttributeStudyProperties_i::SetModification(), SALOMEDS_AttributeStudyProperties_i::SetModified(), SALOMEDS_AttributeTableOfInteger_i::SetNbColumns(), SALOMEDS_AttributeTableOfReal_i::SetNbColumns(), SALOMEDS_AttributeTableOfString_i::SetNbColumns(), SetNext(), SALOMEDS_AttributePythonObject_i::SetObject(), SALOMEDS_AttributeOpened_i::SetOpened(), SALOMEDS_AttributePixMap_i::SetPixMap(), SetPrevious(), SALOMEDS_AttributeParameter_i::SetReal(), SALOMEDS_AttributeParameter_i::SetRealArray(), SALOMEDS_AttributeTableOfReal_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRow(), SALOMEDS_AttributeTableOfString_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitle(), SALOMEDS_AttributeTableOfReal_i::SetRowTitle(), SALOMEDS_AttributeTableOfString_i::SetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitles(), SALOMEDS_AttributeTableOfReal_i::SetRowTitles(), SALOMEDS_AttributeTableOfString_i::SetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnit(), SALOMEDS_AttributeTableOfReal_i::SetRowUnit(), SALOMEDS_AttributeTableOfString_i::SetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnits(), SALOMEDS_AttributeTableOfReal_i::SetRowUnits(), SALOMEDS_AttributeTableOfString_i::SetRowUnits(), SALOMEDS_AttributeSelectable_i::SetSelectable(), SALOMEDS_AttributeParameter_i::SetStrArray(), SALOMEDS_AttributeParameter_i::SetString(), SALOMEDS_AttributeTextColor_i::SetTextColor(), SALOMEDS_AttributeTextHighlightColor_i::SetTextHighlightColor(), SetTreeID(), SALOMEDS_AttributeStudyProperties_i::SetUnits(), SALOMEDS_AttributeStudyProperties_i::SetUserName(), SALOMEDS_AttributeComment_i::SetValue(), SALOMEDS_AttributeExternalFileDef_i::SetValue(), SALOMEDS_AttributeFileType_i::SetValue(), SALOMEDS_AttributeIOR_i::SetValue(), SALOMEDS_AttributeName_i::SetValue(), SALOMEDS_AttributePersistentRef_i::SetValue(), SALOMEDS_AttributeString_i::SetValue(), SALOMEDS_AttributeUserID_i::SetValue(), SALOMEDS_AttributeReal_i::SetValue(), SALOMEDS_AttributeInteger_i::SetValue(), SALOMEDS_AttributeLocalID_i::SetValue(), SALOMEDS_AttributeGraphic_i::SetVisibility(), SALOMEDS_AttributeTableOfInteger_i::SortByColumn(), SALOMEDS_AttributeTableOfReal_i::SortByColumn(), SALOMEDS_AttributeTableOfString_i::SortByColumn(), SALOMEDS_AttributeTableOfInteger_i::SortByRow(), SALOMEDS_AttributeTableOfReal_i::SortByRow(), SALOMEDS_AttributeTableOfString_i::SortByRow(), SALOMEDS_AttributeTableOfInteger_i::SortColumn(), SALOMEDS_AttributeTableOfReal_i::SortColumn(), SALOMEDS_AttributeTableOfString_i::SortColumn(), SALOMEDS_AttributeTableOfInteger_i::SortRow(), SALOMEDS_AttributeTableOfReal_i::SortRow(), SALOMEDS_AttributeTableOfString_i::SortRow(), SALOMEDS_AttributeTableOfInteger_i::SwapCells(), SALOMEDS_AttributeTableOfReal_i::SwapCells(), SALOMEDS_AttributeTableOfString_i::SwapCells(), SALOMEDS_AttributeTableOfInteger_i::SwapColumns(), SALOMEDS_AttributeTableOfReal_i::SwapColumns(), SALOMEDS_AttributeTableOfString_i::SwapColumns(), SALOMEDS_AttributeTableOfInteger_i::SwapRows(), SALOMEDS_AttributeTableOfReal_i::SwapRows(), SALOMEDS_AttributeTableOfString_i::SwapRows(), SALOMEDS_AttributeTextColor_i::TextColor(), SALOMEDS_AttributeTextHighlightColor_i::TextHighlightColor(), SALOMEDS_GenericAttribute_i::Type(), UNEXPECT_CATCH(), SALOMEDS_AttributeComment_i::Value(), SALOMEDS_AttributeExternalFileDef_i::Value(), SALOMEDS_AttributeFileType_i::Value(), SALOMEDS_AttributeInteger_i::Value(), SALOMEDS_AttributeIOR_i::Value(), SALOMEDS_AttributeLocalID_i::Value(), SALOMEDS_AttributeName_i::Value(), SALOMEDS_AttributePersistentRef_i::Value(), SALOMEDS_AttributeReal_i::Value(), SALOMEDS_AttributeString_i::Value(), SALOMEDS_AttributeUserID_i::Value(), SALOMEDS_AttributeSequenceOfInteger_i::Value(), and SALOMEDS_AttributeSequenceOfReal_i::Value().
◆ _orb
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
