SALOMEDS_AttributeParameter_i Class Reference
Class: SALOMEDS_AttributeParameter Description : AttributeParameter is a universal container of basic types. More...
#include <SALOMEDS_AttributeParameter_i.hxx>
Inheritance diagram for SALOMEDS_AttributeParameter_i:
 SALOMEDS_AttributeParameter_i (SALOMEDSImpl_AttributeParameter *theAttr, CORBA::ORB_ptr orb)
 ~SALOMEDS_AttributeParameter_i ()
virtual void SetInt (const char *theID, CORBA::Long theValue)
virtual CORBA::Long GetInt (const char *theID)
 Function : GetInt Purpose : Returns a int value associated with the given ID. More...
virtual void SetReal (const char *theID, CORBA::Double theValue)
 Function : SetReal Purpose : Associates a double value with the ID. More...
virtual CORBA::Double GetReal (const char *theID)
 Function : GetReal Purpose : Returns a double value associated with the given ID. More...
virtual void SetString (const char *theID, const char *theValue)
 Function : SetString Purpose : Associates a string with the ID. More...
virtual char * GetString (const char *theID)
 Function : GetString Purpose : Returns a string associated with the given ID. More...
virtual void SetBool (const char *theID, CORBA::Boolean theValue)
 Function : SetBool Purpose : Associates a bool value with the ID. More...
virtual CORBA::Boolean GetBool (const char *theID)
 Function : GetBool Purpose : Returns a bool value associated with the ID. More...
virtual void SetRealArray (const char *theID, const SALOMEDS::DoubleSeq &theArray)
 Function : SetRealArray Purpose : Associates an array of double values with the given ID. More...
virtual SALOMEDS::DoubleSeq * GetRealArray (const char *theID)
 Function : GetRealArray Purpose : Returns an array of double values associated with the ID. More...
virtual void SetIntArray (const char *theID, const SALOMEDS::LongSeq &theArray)
 Function : SetIntArray Purpose : Associates an array of int values with the given ID. More...
virtual SALOMEDS::LongSeq * GetIntArray (const char *theID)
 Function : GetIntArray Purpose : Returns an array of int values associated with the ID. More...
virtual void SetStrArray (const char *theID, const SALOMEDS::StringSeq &theArray)
 Function : SetStrArray Purpose : Associates an array of string values with the given ID. More...
virtual SALOMEDS::StringSeq * GetStrArray (const char *theID)
 Function : GetStrArray Purpose : Returns an array of string values associated with the ID. More...
virtual CORBA::Boolean IsSet (const char *theID, CORBA::Long theType)
 Function : IsSet Purpose : Returns true if for the ID of given type was assigned
a value in the attribute. More...
virtual CORBA::Boolean RemoveID (const char *theID, CORBA::Long theType)
 Function : RemoveID Purpose : Removes a parameter with given ID. More...
virtual SALOMEDS::AttributeParameter_ptr GetFather ()
 Function : GetFather Purpose : Returns a father attribute for this attribute. More...
virtual CORBA::Boolean HasFather ()
 Function : HasFather Purpose : Returns True if the attribute has a father attribute. More...
virtual CORBA::Boolean IsRoot ()
 Function : IsRoot Purpose : Returns True is the attribute is highest in an hierarchy. More...
virtual void Clear ()
 Function : IsRoot Purpose : Clears the content of the attribute. More...
virtual SALOMEDS::StringSeq * GetIDs (CORBA::Long theType)
 Function : GetIDs Purpose : Returns an array of all ID's of the given type. More...
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
void CheckLocked ()
virtual char * Type ()
char * GetClassType ()
SALOMEDS::SObject_ptr GetSObject ()
virtual DF_Attribute * GetImpl ()
virtual CORBA::LongLong GetLocalImpl (const char *theHostname, CORBA::Long thePID, CORBA::Boolean &isLocal)
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
static SALOMEDS::GenericAttribute_ptr CreateAttribute (DF_Attribute *theAttr, CORBA::ORB_ptr theOrb)
DF_Attribute * _impl
CORBA::ORB_var _orb
PortableServer::POA_var myPOA
int myRefCounter
◆ SALOMEDS_AttributeParameter_i()
SALOMEDS_AttributeParameter_i::SALOMEDS_AttributeParameter_i ( SALOMEDSImpl_AttributeParameter *  theAttr,
CORBA::ORB_ptr  orb
Referenced by GetFather().
◆ ~SALOMEDS_AttributeParameter_i()
SALOMEDS_AttributeParameter_i::~SALOMEDS_AttributeParameter_i ( )
◆ _default_POA()
PortableServer::POA_ptr SALOMEDS_GenericAttribute_i::_default_POA ( )
reference to the default POA for the servant
◆ CheckLocked()
void SALOMEDS_GenericAttribute_i::CheckLocked ( )
Referenced by SALOMEDS_AttributeSequenceOfReal_i::Add(), SALOMEDS_AttributeSequenceOfInteger_i::Add(), SALOMEDS_AttributeTableOfReal_i::AddColumn(), SALOMEDS_AttributeTableOfInteger_i::AddColumn(), SALOMEDS_AttributeTableOfString_i::AddColumn(), SALOMEDS_AttributeTableOfReal_i::AddRow(), SALOMEDS_AttributeTableOfInteger_i::AddRow(), SALOMEDS_AttributeTableOfString_i::AddRow(), SALOMEDS_AttributeTreeNode_i::Append(), SALOMEDS_AttributeSequenceOfReal_i::Assign(), SALOMEDS_AttributeSequenceOfInteger_i::Assign(), SALOMEDS_AttributeSequenceOfReal_i::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger_i::ChangeValue(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitle(), SALOMEDS_AttributeTableOfString_i::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitle(), SALOMEDS_AttributeTableOfReal_i::GetRowTitle(), SALOMEDS_AttributeTableOfString_i::GetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnit(), SALOMEDS_AttributeTableOfReal_i::GetRowUnit(), SALOMEDS_AttributeTableOfString_i::GetRowUnit(), SALOMEDS_AttributeTreeNode_i::InsertAfter(), SALOMEDS_AttributeTreeNode_i::InsertBefore(), SALOMEDS_AttributeTreeNode_i::Prepend(), SALOMEDS_AttributeTableOfString_i::PutValue(), SALOMEDS_AttributeTableOfReal_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::PutValue(), SALOMEDS_AttributeTreeNode_i::Remove(), SALOMEDS_AttributeSequenceOfInteger_i::Remove(), SALOMEDS_AttributeSequenceOfReal_i::Remove(), RemoveID(), SetBool(), SALOMEDS_AttributeTableOfReal_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumn(), SALOMEDS_AttributeTableOfString_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitle(), SALOMEDS_AttributeTableOfString_i::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitles(), SALOMEDS_AttributeTableOfString_i::SetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::SetComment(), SALOMEDS_AttributeStudyProperties_i::SetCreationDate(), SALOMEDS_AttributeStudyProperties_i::SetCreationMode(), SALOMEDS_AttributeDrawable_i::SetDrawable(), SALOMEDS_AttributeExpandable_i::SetExpandable(), SALOMEDS_AttributeTreeNode_i::SetFather(), SALOMEDS_AttributeTreeNode_i::SetFirst(), SetIntArray(), SALOMEDS_AttributeStudyProperties_i::SetModification(), SALOMEDS_AttributeTreeNode_i::SetNext(), SALOMEDS_AttributePythonObject_i::SetObject(), SALOMEDS_AttributePixMap_i::SetPixMap(), SALOMEDS_AttributeTreeNode_i::SetPrevious(), SetReal(), SetRealArray(), SALOMEDS_AttributeTableOfReal_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRow(), SALOMEDS_AttributeTableOfString_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitle(), SALOMEDS_AttributeTableOfReal_i::SetRowTitle(), SALOMEDS_AttributeTableOfString_i::SetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitles(), SALOMEDS_AttributeTableOfReal_i::SetRowTitles(), SALOMEDS_AttributeTableOfString_i::SetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnit(), SALOMEDS_AttributeTableOfReal_i::SetRowUnit(), SALOMEDS_AttributeTableOfString_i::SetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnits(), SALOMEDS_AttributeTableOfReal_i::SetRowUnits(), SALOMEDS_AttributeTableOfString_i::SetRowUnits(), SetStrArray(), SetString(), SALOMEDS_AttributeTextColor_i::SetTextColor(), SALOMEDS_AttributeTextHighlightColor_i::SetTextHighlightColor(), SALOMEDS_AttributeTreeNode_i::SetTreeID(), SALOMEDS_AttributeStudyProperties_i::SetUnits(), SALOMEDS_AttributeStudyProperties_i::SetUserName(), SALOMEDS_AttributeComment_i::SetValue(), SALOMEDS_AttributeExternalFileDef_i::SetValue(), SALOMEDS_AttributeFileType_i::SetValue(), SALOMEDS_AttributeIOR_i::SetValue(), SALOMEDS_AttributeName_i::SetValue(), SALOMEDS_AttributePersistentRef_i::SetValue(), SALOMEDS_AttributeString_i::SetValue(), SALOMEDS_AttributeUserID_i::SetValue(), SALOMEDS_AttributeReal_i::SetValue(), SALOMEDS_AttributeInteger_i::SetValue(), SALOMEDS_AttributeLocalID_i::SetValue(), SALOMEDS_AttributeTableOfInteger_i::SortByColumn(), SALOMEDS_AttributeTableOfReal_i::SortByColumn(), SALOMEDS_AttributeTableOfString_i::SortByColumn(), SALOMEDS_AttributeTableOfInteger_i::SortByRow(), SALOMEDS_AttributeTableOfReal_i::SortByRow(), SALOMEDS_AttributeTableOfString_i::SortByRow(), SALOMEDS_AttributeTableOfInteger_i::SortColumn(), SALOMEDS_AttributeTableOfReal_i::SortColumn(), SALOMEDS_AttributeTableOfString_i::SortColumn(), SALOMEDS_AttributeTableOfInteger_i::SortRow(), SALOMEDS_AttributeTableOfReal_i::SortRow(), SALOMEDS_AttributeTableOfString_i::SortRow(), SALOMEDS_AttributeTableOfInteger_i::SwapCells(), SALOMEDS_AttributeTableOfReal_i::SwapCells(), SALOMEDS_AttributeTableOfString_i::SwapCells(), SALOMEDS_AttributeTableOfInteger_i::SwapColumns(), SALOMEDS_AttributeTableOfReal_i::SwapColumns(), SALOMEDS_AttributeTableOfString_i::SwapColumns(), SALOMEDS_AttributeTableOfInteger_i::SwapRows(), SALOMEDS_AttributeTableOfReal_i::SwapRows(), SALOMEDS_AttributeTableOfString_i::SwapRows(), and UNEXPECT_CATCH().
◆ Clear()
void SALOMEDS_AttributeParameter_i::Clear ( )
References SALOMEDS_GenericAttribute_i::_impl, Clear(), and SALOMEDS::lock().
Referenced by Clear().
◆ CreateAttribute()
SALOMEDS::GenericAttribute_ptr SALOMEDS_GenericAttribute_i::CreateAttribute ( DF_Attribute *  theAttr,
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ GetBool()
CORBA::Boolean SALOMEDS_AttributeParameter_i::GetBool ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetBool(), and SALOMEDS::lock().
Referenced by GetBool().
◆ GetClassType()
◆ GetFather()
SALOMEDS::AttributeParameter_ptr SALOMEDS_AttributeParameter_i::GetFather ( )
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::_orb, SALOMEDS::lock(), and SALOMEDS_AttributeParameter_i().
◆ GetIDs()
SALOMEDS::StringSeq * SALOMEDS_AttributeParameter_i::GetIDs ( CORBA::Long  theType)
< TODO: conversion from size_t to int
References SALOMEDS_GenericAttribute_i::_impl, GetIDs(), and SALOMEDS::lock().
Referenced by GetIDs().
◆ GetImpl()
virtual DF_Attribute * SALOMEDS_GenericAttribute_i::GetImpl ( )
◆ GetInt()
CORBA::Long SALOMEDS_AttributeParameter_i::GetInt ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetInt(), and SALOMEDS::lock().
Referenced by GetInt().
◆ GetIntArray()
SALOMEDS::LongSeq * SALOMEDS_AttributeParameter_i::GetIntArray ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetIntArray(), and SALOMEDS::lock().
Referenced by GetIntArray().
◆ GetLocalImpl()
CORBA::LongLong SALOMEDS_GenericAttribute_i::GetLocalImpl ( const char *  theHostname,
CORBA::Long  thePID,
CORBA::Boolean &  isLocal
◆ GetReal()
CORBA::Double SALOMEDS_AttributeParameter_i::GetReal ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetReal(), and SALOMEDS::lock().
Referenced by GetReal().
◆ GetRealArray()
SALOMEDS::DoubleSeq * SALOMEDS_AttributeParameter_i::GetRealArray ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetRealArray(), and SALOMEDS::lock().
Referenced by GetRealArray().
◆ GetSObject()
◆ GetStrArray()
SALOMEDS::StringSeq * SALOMEDS_AttributeParameter_i::GetStrArray ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, GetStrArray(), and SALOMEDS::lock().
Referenced by GetStrArray().
◆ GetString()
char * SALOMEDS_AttributeParameter_i::GetString ( const char *  theID)
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDSImpl_AttributeParameter::GetString(), and SALOMEDS::lock().
◆ HasFather()
CORBA::Boolean SALOMEDS_AttributeParameter_i::HasFather ( )
References SALOMEDS_GenericAttribute_i::_impl, HasFather(), and SALOMEDS::lock().
Referenced by HasFather().
◆ IsRoot()
CORBA::Boolean SALOMEDS_AttributeParameter_i::IsRoot ( )
References SALOMEDS_GenericAttribute_i::_impl, IsRoot(), and SALOMEDS::lock().
Referenced by IsRoot().
◆ IsSet()
CORBA::Boolean SALOMEDS_AttributeParameter_i::IsSet ( const char *  theID,
CORBA::Long  theType
References SALOMEDS_GenericAttribute_i::_impl, IsSet(), and SALOMEDS::lock().
Referenced by IsSet().
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ RemoveID()
CORBA::Boolean SALOMEDS_AttributeParameter_i::RemoveID ( const char *  theID,
CORBA::Long  theType
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and RemoveID().
Referenced by RemoveID().
◆ SetBool()
void SALOMEDS_AttributeParameter_i::SetBool ( const char *  theID,
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and SetBool().
Referenced by SetBool().
◆ SetInt()
virtual void SALOMEDS_AttributeParameter_i::SetInt ( const char *  theID,
Referenced by UNEXPECT_CATCH().
◆ SetIntArray()
void SALOMEDS_AttributeParameter_i::SetIntArray ( const char *  theID,
const SALOMEDS::LongSeq &  theArray
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and SetIntArray().
Referenced by SetIntArray().
◆ SetReal()
void SALOMEDS_AttributeParameter_i::SetReal ( const char *  theID,
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and SetReal().
Referenced by SetReal().
◆ SetRealArray()
void SALOMEDS_AttributeParameter_i::SetRealArray ( const char *  theID,
const SALOMEDS::DoubleSeq &  theArray
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and SetRealArray().
Referenced by SetRealArray().
◆ SetStrArray()
void SALOMEDS_AttributeParameter_i::SetStrArray ( const char *  theID,
const SALOMEDS::StringSeq &  theArray
References SALOMEDS_GenericAttribute_i::_impl, SALOMEDS_GenericAttribute_i::CheckLocked(), SALOMEDS::lock(), and SetStrArray().
Referenced by SetStrArray().
◆ SetString()
void SALOMEDS_AttributeParameter_i::SetString ( const char *  theID,
const char *  theValue
◆ Type()
char * SALOMEDS_GenericAttribute_i::Type ( )
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _impl
DF_Attribute* SALOMEDS_GenericAttribute_i::_impl
Referenced by SALOMEDS_AttributeSequenceOfReal_i::Add(), SALOMEDS_AttributeSequenceOfInteger_i::Add(), SALOMEDS_AttributeTarget_i::Add(), SALOMEDS_AttributeTableOfReal_i::AddColumn(), SALOMEDS_AttributeTableOfInteger_i::AddColumn(), SALOMEDS_AttributeTableOfString_i::AddColumn(), SALOMEDS_AttributeTableOfReal_i::AddRow(), SALOMEDS_AttributeTableOfInteger_i::AddRow(), SALOMEDS_AttributeTableOfString_i::AddRow(), SALOMEDS_AttributeTreeNode_i::Append(), SALOMEDS_AttributeSequenceOfReal_i::Assign(), SALOMEDS_AttributeSequenceOfInteger_i::Assign(), SALOMEDS_AttributeSequenceOfReal_i::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger_i::ChangeValue(), SALOMEDS_GenericAttribute_i::CheckLocked(), Clear(), SALOMEDS_AttributeSequenceOfInteger_i::CorbaSequence(), SALOMEDS_AttributeSequenceOfReal_i::CorbaSequence(), SALOMEDS_AttributeTreeNode_i::Depth(), SALOMEDS_AttributeTarget_i::Get(), SALOMEDS_AttributeFlags_i::Get(), GetBool(), SALOMEDS_GenericAttribute_i::GetClassType(), SALOMEDS_AttributeTableOfInteger_i::GetColumn(), SALOMEDS_AttributeTableOfReal_i::GetColumn(), SALOMEDS_AttributeTableOfString_i::GetColumn(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitle(), SALOMEDS_AttributeTableOfString_i::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::GetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::GetColumnTitles(), SALOMEDS_AttributeTableOfString_i::GetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::GetComment(), SALOMEDS_AttributeStudyProperties_i::GetComponentVersion(), SALOMEDS_AttributeStudyProperties_i::GetComponentVersions(), SALOMEDS_AttributeStudyProperties_i::GetCreationDate(), SALOMEDS_AttributeStudyProperties_i::GetCreationMode(), GetFather(), SALOMEDS_AttributeTreeNode_i::GetFather(), SALOMEDS_AttributeTreeNode_i::GetFirst(), SALOMEDS_AttributeFlags_i::GetFlags(), GetIDs(), GetInt(), GetIntArray(), SALOMEDS_GenericAttribute_i::GetLocalImpl(), SALOMEDS_AttributeStudyProperties_i::GetModificationsList(), SALOMEDS_AttributeStudyProperties_i::GetModified(), SALOMEDS_AttributeTableOfInteger_i::GetNbColumns(), SALOMEDS_AttributeTableOfReal_i::GetNbColumns(), SALOMEDS_AttributeTableOfString_i::GetNbColumns(), SALOMEDS_AttributeTableOfInteger_i::GetNbRows(), SALOMEDS_AttributeTableOfReal_i::GetNbRows(), SALOMEDS_AttributeTableOfString_i::GetNbRows(), SALOMEDS_AttributeTreeNode_i::GetNext(), SALOMEDS_AttributePythonObject_i::GetObject(), SALOMEDS_AttributePixMap_i::GetPixMap(), SALOMEDS_AttributeTreeNode_i::GetPrevious(), GetReal(), GetRealArray(), SALOMEDS_AttributeTableOfInteger_i::GetRow(), SALOMEDS_AttributeTableOfReal_i::GetRow(), SALOMEDS_AttributeTableOfString_i::GetRow(), SALOMEDS_AttributeTableOfInteger_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfReal_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfString_i::GetRowSetIndices(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitle(), SALOMEDS_AttributeTableOfReal_i::GetRowTitle(), SALOMEDS_AttributeTableOfString_i::GetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::GetRowTitles(), SALOMEDS_AttributeTableOfReal_i::GetRowTitles(), SALOMEDS_AttributeTableOfString_i::GetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnit(), SALOMEDS_AttributeTableOfReal_i::GetRowUnit(), SALOMEDS_AttributeTableOfString_i::GetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::GetRowUnits(), SALOMEDS_AttributeTableOfReal_i::GetRowUnits(), SALOMEDS_AttributeTableOfString_i::GetRowUnits(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDS_AttributeStudyProperties_i::GetStoredComponents(), GetStrArray(), GetString(), SALOMEDS_AttributeTableOfInteger_i::GetTitle(), SALOMEDS_AttributeTableOfReal_i::GetTitle(), SALOMEDS_AttributeTableOfString_i::GetTitle(), SALOMEDS_AttributeTreeNode_i::GetTreeID(), SALOMEDS_AttributeStudyProperties_i::GetUnits(), SALOMEDS_AttributeStudyProperties_i::GetUserName(), SALOMEDS_AttributeTableOfInteger_i::GetValue(), SALOMEDS_AttributeTableOfReal_i::GetValue(), SALOMEDS_AttributeTableOfString_i::GetValue(), SALOMEDS_AttributeGraphic_i::GetVisibility(), HasFather(), SALOMEDS_AttributeTreeNode_i::HasFather(), SALOMEDS_AttributeTreeNode_i::HasFirst(), SALOMEDS_AttributeTreeNode_i::HasNext(), SALOMEDS_AttributePixMap_i::HasPixMap(), SALOMEDS_AttributeTreeNode_i::HasPrevious(), SALOMEDS_AttributeTableOfInteger_i::HasValue(), SALOMEDS_AttributeTableOfReal_i::HasValue(), SALOMEDS_AttributeTableOfString_i::HasValue(), SALOMEDS_AttributeTreeNode_i::InsertAfter(), SALOMEDS_AttributeTreeNode_i::InsertBefore(), SALOMEDS_AttributeTreeNode_i::IsChild(), SALOMEDS_AttributeTreeNode_i::IsDescendant(), SALOMEDS_AttributeDrawable_i::IsDrawable(), SALOMEDS_AttributeExpandable_i::IsExpandable(), SALOMEDS_AttributeTreeNode_i::IsFather(), SALOMEDS_AttributeStudyProperties_i::IsLocked(), SALOMEDS_AttributeStudyProperties_i::IsModified(), SALOMEDS_AttributeOpened_i::IsOpened(), IsRoot(), SALOMEDS_AttributeTreeNode_i::IsRoot(), SALOMEDS_AttributePythonObject_i::IsScript(), SALOMEDS_AttributeSelectable_i::IsSelectable(), IsSet(), SALOMEDS_AttributeTreeNode_i::Label(), SALOMEDS_AttributeSequenceOfInteger_i::Length(), SALOMEDS_AttributeSequenceOfReal_i::Length(), SALOMEDS_AttributeTreeNode_i::Prepend(), SALOMEDS_AttributeTableOfString_i::PutValue(), SALOMEDS_AttributeTableOfReal_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::PutValue(), SALOMEDS_AttributeTableOfInteger_i::ReadFromFile(), SALOMEDS_AttributeTableOfReal_i::ReadFromFile(), SALOMEDS_AttributeTableOfString_i::ReadFromFile(), SALOME_Embedded_NamingService.SALOME_Embedded_NamingService::Register(), SALOMEDS_AttributeTreeNode_i::Remove(), SALOMEDS_AttributeSequenceOfInteger_i::Remove(), SALOMEDS_AttributeSequenceOfReal_i::Remove(), SALOMEDS_AttributeTarget_i::Remove(), RemoveID(), SALOMEDS_AttributeTableOfInteger_i::RemoveValue(), SALOMEDS_AttributeTableOfReal_i::RemoveValue(), SALOMEDS_AttributeTableOfString_i::RemoveValue(), SALOME_Embedded_NamingService.SALOME_Embedded_NamingService::Resolve(), SALOMEDS_AttributeTableOfInteger_i::SaveToFile(), SALOMEDS_AttributeTableOfReal_i::SaveToFile(), SALOMEDS_AttributeTableOfString_i::SaveToFile(), SALOMEDS_AttributeFlags_i::Set(), SetBool(), SALOMEDS_AttributeTableOfReal_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumn(), SALOMEDS_AttributeTableOfString_i::SetColumn(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitle(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitle(), SALOMEDS_AttributeTableOfString_i::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger_i::SetColumnTitles(), SALOMEDS_AttributeTableOfReal_i::SetColumnTitles(), SALOMEDS_AttributeTableOfString_i::SetColumnTitles(), SALOMEDS_AttributeStudyProperties_i::SetComment(), SALOMEDS_AttributeStudyProperties_i::SetCreationDate(), SALOMEDS_AttributeStudyProperties_i::SetCreationMode(), SALOMEDS_AttributeDrawable_i::SetDrawable(), SALOMEDS_AttributeExpandable_i::SetExpandable(), SALOMEDS_AttributeTreeNode_i::SetFather(), SALOMEDS_AttributeTreeNode_i::SetFirst(), SALOMEDS_AttributeFlags_i::SetFlags(), SetIntArray(), SALOMEDS_AttributeStudyProperties_i::SetLocked(), SALOMEDS_AttributeStudyProperties_i::SetModification(), SALOMEDS_AttributeStudyProperties_i::SetModified(), SALOMEDS_AttributeTableOfInteger_i::SetNbColumns(), SALOMEDS_AttributeTableOfReal_i::SetNbColumns(), SALOMEDS_AttributeTableOfString_i::SetNbColumns(), SALOMEDS_AttributeTreeNode_i::SetNext(), SALOMEDS_AttributePythonObject_i::SetObject(), SALOMEDS_AttributeOpened_i::SetOpened(), SALOMEDS_AttributePixMap_i::SetPixMap(), SALOMEDS_AttributeTreeNode_i::SetPrevious(), SetReal(), SetRealArray(), SALOMEDS_AttributeTableOfReal_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRow(), SALOMEDS_AttributeTableOfString_i::SetRow(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitle(), SALOMEDS_AttributeTableOfReal_i::SetRowTitle(), SALOMEDS_AttributeTableOfString_i::SetRowTitle(), SALOMEDS_AttributeTableOfInteger_i::SetRowTitles(), SALOMEDS_AttributeTableOfReal_i::SetRowTitles(), SALOMEDS_AttributeTableOfString_i::SetRowTitles(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnit(), SALOMEDS_AttributeTableOfReal_i::SetRowUnit(), SALOMEDS_AttributeTableOfString_i::SetRowUnit(), SALOMEDS_AttributeTableOfInteger_i::SetRowUnits(), SALOMEDS_AttributeTableOfReal_i::SetRowUnits(), SALOMEDS_AttributeTableOfString_i::SetRowUnits(), SALOMEDS_AttributeSelectable_i::SetSelectable(), SetStrArray(), SetString(), SALOMEDS_AttributeTextColor_i::SetTextColor(), SALOMEDS_AttributeTextHighlightColor_i::SetTextHighlightColor(), SALOMEDS_AttributeTreeNode_i::SetTreeID(), SALOMEDS_AttributeStudyProperties_i::SetUnits(), SALOMEDS_AttributeStudyProperties_i::SetUserName(), SALOMEDS_AttributeComment_i::SetValue(), SALOMEDS_AttributeExternalFileDef_i::SetValue(), SALOMEDS_AttributeFileType_i::SetValue(), SALOMEDS_AttributeIOR_i::SetValue(), SALOMEDS_AttributeName_i::SetValue(), SALOMEDS_AttributePersistentRef_i::SetValue(), SALOMEDS_AttributeString_i::SetValue(), SALOMEDS_AttributeUserID_i::SetValue(), SALOMEDS_AttributeReal_i::SetValue(), SALOMEDS_AttributeInteger_i::SetValue(), SALOMEDS_AttributeLocalID_i::SetValue(), SALOMEDS_AttributeGraphic_i::SetVisibility(), SALOMEDS_AttributeTableOfInteger_i::SortByColumn(), SALOMEDS_AttributeTableOfReal_i::SortByColumn(), SALOMEDS_AttributeTableOfString_i::SortByColumn(), SALOMEDS_AttributeTableOfInteger_i::SortByRow(), SALOMEDS_AttributeTableOfReal_i::SortByRow(), SALOMEDS_AttributeTableOfString_i::SortByRow(), SALOMEDS_AttributeTableOfInteger_i::SortColumn(), SALOMEDS_AttributeTableOfReal_i::SortColumn(), SALOMEDS_AttributeTableOfString_i::SortColumn(), SALOMEDS_AttributeTableOfInteger_i::SortRow(), SALOMEDS_AttributeTableOfReal_i::SortRow(), SALOMEDS_AttributeTableOfString_i::SortRow(), SALOMEDS_AttributeTableOfInteger_i::SwapCells(), SALOMEDS_AttributeTableOfReal_i::SwapCells(), SALOMEDS_AttributeTableOfString_i::SwapCells(), SALOMEDS_AttributeTableOfInteger_i::SwapColumns(), SALOMEDS_AttributeTableOfReal_i::SwapColumns(), SALOMEDS_AttributeTableOfString_i::SwapColumns(), SALOMEDS_AttributeTableOfInteger_i::SwapRows(), SALOMEDS_AttributeTableOfReal_i::SwapRows(), SALOMEDS_AttributeTableOfString_i::SwapRows(), SALOMEDS_AttributeTextColor_i::TextColor(), SALOMEDS_AttributeTextHighlightColor_i::TextHighlightColor(), SALOMEDS_GenericAttribute_i::Type(), UNEXPECT_CATCH(), SALOMEDS_AttributeComment_i::Value(), SALOMEDS_AttributeExternalFileDef_i::Value(), SALOMEDS_AttributeFileType_i::Value(), SALOMEDS_AttributeInteger_i::Value(), SALOMEDS_AttributeIOR_i::Value(), SALOMEDS_AttributeLocalID_i::Value(), SALOMEDS_AttributeName_i::Value(), SALOMEDS_AttributePersistentRef_i::Value(), SALOMEDS_AttributeReal_i::Value(), SALOMEDS_AttributeString_i::Value(), SALOMEDS_AttributeUserID_i::Value(), SALOMEDS_AttributeSequenceOfInteger_i::Value(), and SALOMEDS_AttributeSequenceOfReal_i::Value().
◆ _orb
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
