SALOMEDS_AttributeParameter Class Referenceabstract
#include <SALOMEDS_AttributeParameter.hxx>
Inheritance diagram for SALOMEDS_AttributeParameter:
 SALOMEDS_AttributeParameter (SALOMEDSImpl_AttributeParameter *theAttr)
 Function : Constructor Purpose : Creates a new instance of SALOMEDS_AttributeParameter. More...
 SALOMEDS_AttributeParameter (SALOMEDS::AttributeParameter_ptr theAttr)
 ~SALOMEDS_AttributeParameter ()
 Function : Destructor Purpose : Destroys the instance of SALOMEDS_AttributeParameter. More...
virtual void SetInt (const std::string &theID, const int theValue)
 Function : SetInt Purpose : Associates a integer value with the ID. More...
virtual int GetInt (const std::string &theID)
 Function : GetInt Purpose : Returns a int value associated with the given ID. More...
virtual void SetReal (const std::string &theID, const double &theValue)
 Function : SetReal Purpose : Associates a double value with the ID. More...
virtual double GetReal (const std::string &theID)
 Function : GetReal Purpose : Returns a double value associated with the given ID. More...
virtual void SetString (const std::string &theID, const std::string &theValue)
 Function : SetString Purpose : Associates a string with the ID. More...
virtual std::string GetString (const std::string &theID)
 Function : GetString Purpose : Returns a string associated with the given ID. More...
virtual void SetBool (const std::string &theID, const bool &theValue)
 Function : SetBool Purpose : Associates a bool value with the ID. More...
virtual bool GetBool (const std::string &theID)
 Function : GetBool Purpose : Returns a bool value associated with the ID. More...
virtual void SetRealArray (const std::string &theID, const std::vector< double > &theArray)
 Function : SetRealArray Purpose : Associates an array of double values with the given ID. More...
virtual std::vector< double > GetRealArray (const std::string &theID)
 Function : GetRealArray Purpose : Returns an array of double values associated with the ID. More...
virtual void SetIntArray (const std::string &theID, const std::vector< int > &theArray)
 Function : SetIntArray Purpose : Associates an array of int values with the given ID. More...
virtual std::vector< int > GetIntArray (const std::string &theID)
 Function : GetIntArray Purpose : Returns an array of int values associated with the ID. More...
virtual void SetStrArray (const std::string &theID, const std::vector< std::string > &theArray)
 Function : SetStrArray Purpose : Associates an array of string values with the given ID. More...
virtual std::vector< std::string > GetStrArray (const std::string &theID)
 Function : GetStrArray Purpose : Returns an array of string values associated with the ID. More...
virtual bool IsSet (const std::string &theID, const int theType)
 Function : IsSet Purpose : Returns true if for the ID of given type was assigned
a value in the attribute. More...
virtual bool RemoveID (const std::string &theID, const int theType)
 Function : RemoveID Purpose : Removes a parameter with given ID. More...
virtual _PTR (AttributeParameter) GetFather()
virtual bool HasFather ()
 Function : HasFather Purpose : Returns True if the attribute has a father attribute. More...
virtual bool IsRoot ()
 Function : IsRoot Purpose : Returns True is the attribute is highest in an hierarchy. More...
virtual void Clear ()
 Function : Clear Purpose : Clears the content of the attribute. More...
virtual std::vector< std::string > GetIDs (const int theType)
 Function : GetIDs Purpose : Returns an array of all ID's of the given type. More...
void CheckLocked ()
std::string Type ()
std::string GetClassType ()
 _PTR (SObject) GetSObject()
virtual clt_shared_ptr< SALOMEDSClient_SObject > GetSObject ()=0
virtual clt_shared_ptr< SALOMEDSClient_AttributeParameter > GetFather ()=0
static SALOMEDS_GenericAttribute * CreateAttribute (SALOMEDSImpl_GenericAttribute *theGA)
static SALOMEDS_GenericAttribute * CreateAttribute (SALOMEDS::GenericAttribute_ptr theGA)
bool _isLocal
SALOMEDSImpl_GenericAttribute * _local_impl
SALOMEDS::GenericAttribute_var _corba_impl
◆ SALOMEDS_AttributeParameter() [1/2]
SALOMEDS_AttributeParameter::SALOMEDS_AttributeParameter ( SALOMEDSImpl_AttributeParameter *  theAttr)
Referenced by _PTR().
◆ SALOMEDS_AttributeParameter() [2/2]
SALOMEDS_AttributeParameter::SALOMEDS_AttributeParameter ( SALOMEDS::AttributeParameter_ptr  theAttr)
◆ ~SALOMEDS_AttributeParameter()
SALOMEDS_AttributeParameter::~SALOMEDS_AttributeParameter ( )
◆ _PTR() [1/2]
virtual SALOMEDS_AttributeParameter::_PTR ( AttributeParameter  )
◆ _PTR() [2/2]
SALOMEDS_GenericAttribute::_PTR ( SObject  )
◆ CheckLocked()
void SALOMEDS_GenericAttribute::CheckLocked ( )
Implements SALOMEDSClient_GenericAttribute.
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDS::lock().
Referenced by SALOMEDS_AttributeSequenceOfReal::Add(), SALOMEDS_AttributeSequenceOfInteger::Add(), SALOMEDS_AttributeTableOfReal::AddColumn(), SALOMEDS_AttributeTableOfInteger::AddColumn(), SALOMEDS_AttributeTableOfString::AddColumn(), SALOMEDS_AttributeTableOfReal::AddRow(), SALOMEDS_AttributeTableOfInteger::AddRow(), SALOMEDS_AttributeTableOfString::AddRow(), SALOMEDS_AttributeTreeNode::Append(), SALOMEDS_AttributeSequenceOfReal::Assign(), SALOMEDS_AttributeSequenceOfInteger::Assign(), SALOMEDS_AttributeSequenceOfReal::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_AttributeTreeNode::InsertAfter(), SALOMEDS_AttributeTreeNode::InsertBefore(), SALOMEDS_AttributeTreeNode::Prepend(), SALOMEDS_AttributeTableOfString::PutValue(), SALOMEDS_AttributeTableOfReal::PutValue(), SALOMEDS_AttributeTableOfInteger::PutValue(), SALOMEDS_AttributeTreeNode::Remove(), SALOMEDS_AttributeSequenceOfInteger::Remove(), SALOMEDS_AttributeSequenceOfReal::Remove(), RemoveID(), SetBool(), SALOMEDS_AttributeTableOfReal::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumn(), SALOMEDS_AttributeTableOfString::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumnTitle(), SALOMEDS_AttributeTableOfReal::SetColumnTitle(), SALOMEDS_AttributeTableOfString::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger::SetColumnTitles(), SALOMEDS_AttributeTableOfReal::SetColumnTitles(), SALOMEDS_AttributeTableOfString::SetColumnTitles(), SALOMEDS_AttributeStudyProperties::SetComment(), SALOMEDS_AttributeStudyProperties::SetCreationDate(), SALOMEDS_AttributeStudyProperties::SetCreationMode(), SALOMEDS_AttributeDrawable::SetDrawable(), SALOMEDS_AttributeExpandable::SetExpandable(), SALOMEDS_AttributeTreeNode::SetFather(), SALOMEDS_AttributeTreeNode::SetFirst(), SetInt(), SetIntArray(), SALOMEDS_AttributeStudyProperties::SetModification(), SALOMEDS_AttributeTreeNode::SetNext(), SALOMEDS_AttributePythonObject::SetObject(), SALOMEDS_AttributePixMap::SetPixMap(), SALOMEDS_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDS_AttributeTableOfReal::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRow(), SALOMEDS_AttributeTableOfString::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRowTitle(), SALOMEDS_AttributeTableOfReal::SetRowTitle(), SALOMEDS_AttributeTableOfString::SetRowTitle(), SALOMEDS_AttributeTableOfInteger::SetRowTitles(), SALOMEDS_AttributeTableOfReal::SetRowTitles(), SALOMEDS_AttributeTableOfString::SetRowTitles(), SALOMEDS_AttributeTableOfInteger::SetRowUnit(), SALOMEDS_AttributeTableOfReal::SetRowUnit(), SALOMEDS_AttributeTableOfString::SetRowUnit(), SALOMEDS_AttributeTableOfInteger::SetRowUnits(), SALOMEDS_AttributeTableOfReal::SetRowUnits(), SALOMEDS_AttributeTableOfString::SetRowUnits(), SetStrArray(), SetString(), SALOMEDS_AttributeTextColor::SetTextColor(), SALOMEDS_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDS_AttributeTableOfInteger::SetTitle(), SALOMEDS_AttributeTableOfReal::SetTitle(), SALOMEDS_AttributeTableOfString::SetTitle(), SALOMEDS_AttributeTreeNode::SetTreeID(), SALOMEDS_AttributeStudyProperties::SetUnits(), SALOMEDS_AttributeStudyProperties::SetUserName(), SALOMEDS_AttributeComment::SetValue(), SALOMEDS_AttributeExternalFileDef::SetValue(), SALOMEDS_AttributeFileType::SetValue(), SALOMEDS_AttributeIOR::SetValue(), SALOMEDS_AttributeName::SetValue(), SALOMEDS_AttributePersistentRef::SetValue(), SALOMEDS_AttributeString::SetValue(), SALOMEDS_AttributeUserID::SetValue(), SALOMEDS_AttributeReal::SetValue(), SALOMEDS_AttributeInteger::SetValue(), and SALOMEDS_AttributeLocalID::SetValue().
◆ Clear()
void SALOMEDS_AttributeParameter::Clear ( )
Implements SALOMEDSClient_AttributeParameter.
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, Clear(), and SALOMEDS::lock().
Referenced by Clear().
◆ CreateAttribute() [1/2]
SALOMEDS_GenericAttribute * SALOMEDS_GenericAttribute::CreateAttribute ( SALOMEDS::GenericAttribute_ptr  theGA)
◆ CreateAttribute() [2/2]
◆ GetBool()
bool SALOMEDS_AttributeParameter::GetBool ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetBool(), and SALOMEDS::lock().
Referenced by GetBool().
◆ GetClassType()
◆ GetFather()
virtual clt_shared_ptr< SALOMEDSClient_AttributeParameter > SALOMEDSClient_AttributeParameter::GetFather ( )
pure virtualinherited
◆ GetIDs()
std::vector< std::string > SALOMEDS_AttributeParameter::GetIDs ( const int  theType)
◆ GetInt()
int SALOMEDS_AttributeParameter::GetInt ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetInt(), and SALOMEDS::lock().
Referenced by GetInt().
◆ GetIntArray()
std::vector< int > SALOMEDS_AttributeParameter::GetIntArray ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetIntArray(), and SALOMEDS::lock().
Referenced by GetIntArray().
◆ GetReal()
double SALOMEDS_AttributeParameter::GetReal ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetReal(), and SALOMEDS::lock().
Referenced by GetReal().
◆ GetRealArray()
std::vector< double > SALOMEDS_AttributeParameter::GetRealArray ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetRealArray(), and SALOMEDS::lock().
Referenced by GetRealArray().
◆ GetSObject()
virtual clt_shared_ptr< SALOMEDSClient_SObject > SALOMEDSClient_GenericAttribute::GetSObject ( )
◆ GetStrArray()
std::vector< std::string > SALOMEDS_AttributeParameter::GetStrArray ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetStrArray(), and SALOMEDS::lock().
Referenced by GetStrArray().
◆ GetString()
std::string SALOMEDS_AttributeParameter::GetString ( const std::string &  theID)
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, GetString(), and SALOMEDS::lock().
Referenced by GetString().
◆ HasFather()
bool SALOMEDS_AttributeParameter::HasFather ( )
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, HasFather(), and SALOMEDS::lock().
Referenced by HasFather().
◆ IsRoot()
bool SALOMEDS_AttributeParameter::IsRoot ( )
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, IsRoot(), and SALOMEDS::lock().
Referenced by IsRoot().
◆ IsSet()
bool SALOMEDS_AttributeParameter::IsSet ( const std::string &  theID,
const int  theType
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, IsSet(), and SALOMEDS::lock().
Referenced by IsSet().
◆ RemoveID()
bool SALOMEDS_AttributeParameter::RemoveID ( const std::string &  theID,
const int  theType
◆ SetBool()
void SALOMEDS_AttributeParameter::SetBool ( const std::string &  theID,
const bool &  theValue
◆ SetInt()
void SALOMEDS_AttributeParameter::SetInt ( const std::string &  theID,
const int  theValue
◆ SetIntArray()
void SALOMEDS_AttributeParameter::SetIntArray ( const std::string &  theID,
const std::vector< int > &  theArray
< TODO: conversion from size_t to int
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDS::lock(), and SetIntArray().
Referenced by SetIntArray().
◆ SetReal()
void SALOMEDS_AttributeParameter::SetReal ( const std::string &  theID,
const double &  theValue
◆ SetRealArray()
void SALOMEDS_AttributeParameter::SetRealArray ( const std::string &  theID,
const std::vector< double > &  theArray
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDS::lock(), and SetRealArray().
Referenced by SetRealArray().
◆ SetStrArray()
void SALOMEDS_AttributeParameter::SetStrArray ( const std::string &  theID,
const std::vector< std::string > &  theArray
References SALOMEDS_GenericAttribute::_corba_impl, SALOMEDS_GenericAttribute::_isLocal, SALOMEDS_GenericAttribute::_local_impl, SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDS::lock(), and SetStrArray().
Referenced by SetStrArray().
◆ SetString()
void SALOMEDS_AttributeParameter::SetString ( const std::string &  theID,
const std::string &  theValue
◆ Type()
◆ _corba_impl
SALOMEDS::GenericAttribute_var SALOMEDS_GenericAttribute::_corba_impl
Referenced by _PTR(), SALOMEDS_AttributeTarget::Add(), SALOMEDS_AttributeSequenceOfReal::Add(), SALOMEDS_AttributeSequenceOfInteger::Add(), SALOMEDS_AttributeTableOfReal::AddColumn(), SALOMEDS_AttributeTableOfInteger::AddColumn(), SALOMEDS_AttributeTableOfString::AddColumn(), SALOMEDS_AttributeTableOfReal::AddRow(), SALOMEDS_AttributeTableOfInteger::AddRow(), SALOMEDS_AttributeTableOfString::AddRow(), SALOMEDS_AttributeTreeNode::Append(), SALOMEDS_AttributeSequenceOfReal::Assign(), SALOMEDS_AttributeSequenceOfInteger::Assign(), SALOMEDS_AttributeSequenceOfReal::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), Clear(), SALOMEDS_AttributeSequenceOfInteger::CorbaSequence(), SALOMEDS_AttributeSequenceOfReal::CorbaSequence(), SALOMEDS_AttributeTreeNode::Depth(), SALOMEDS_AttributeTarget::Get(), GetBool(), SALOMEDS_GenericAttribute::GetClassType(), SALOMEDS_AttributeTableOfInteger::GetColumn(), SALOMEDS_AttributeTableOfReal::GetColumn(), SALOMEDS_AttributeTableOfString::GetColumn(), SALOMEDS_AttributeTableOfInteger::GetColumnTitle(), SALOMEDS_AttributeTableOfReal::GetColumnTitle(), SALOMEDS_AttributeTableOfString::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger::GetColumnTitles(), SALOMEDS_AttributeTableOfReal::GetColumnTitles(), SALOMEDS_AttributeTableOfString::GetColumnTitles(), SALOMEDS_AttributeStudyProperties::GetComment(), SALOMEDS_AttributeStudyProperties::GetComponentVersion(), SALOMEDS_AttributeStudyProperties::GetComponentVersions(), SALOMEDS_AttributeStudyProperties::GetCreationDate(), SALOMEDS_AttributeStudyProperties::GetCreationMode(), SALOMEDS_AttributeFlags::GetFlags(), GetIDs(), GetInt(), GetIntArray(), SALOMEDS_AttributeStudyProperties::GetModificationsList(), SALOMEDS_AttributeStudyProperties::GetModified(), SALOMEDS_AttributeTableOfInteger::GetNbColumns(), SALOMEDS_AttributeTableOfReal::GetNbColumns(), SALOMEDS_AttributeTableOfString::GetNbColumns(), SALOMEDS_AttributeTableOfInteger::GetNbRows(), SALOMEDS_AttributeTableOfReal::GetNbRows(), SALOMEDS_AttributeTableOfString::GetNbRows(), SALOMEDS_AttributePythonObject::GetObject(), SALOMEDS_AttributePixMap::GetPixMap(), GetReal(), GetRealArray(), SALOMEDS_AttributeTableOfInteger::GetRow(), SALOMEDS_AttributeTableOfReal::GetRow(), SALOMEDS_AttributeTableOfString::GetRow(), SALOMEDS_AttributeTableOfInteger::GetRowSetIndices(), SALOMEDS_AttributeTableOfReal::GetRowSetIndices(), SALOMEDS_AttributeTableOfString::GetRowSetIndices(), SALOMEDS_AttributeTableOfInteger::GetRowTitle(), SALOMEDS_AttributeTableOfReal::GetRowTitle(), SALOMEDS_AttributeTableOfString::GetRowTitle(), SALOMEDS_AttributeTableOfInteger::GetRowTitles(), SALOMEDS_AttributeTableOfReal::GetRowTitles(), SALOMEDS_AttributeTableOfString::GetRowTitles(), SALOMEDS_AttributeTableOfInteger::GetRowUnit(), SALOMEDS_AttributeTableOfReal::GetRowUnit(), SALOMEDS_AttributeTableOfString::GetRowUnit(), SALOMEDS_AttributeTableOfInteger::GetRowUnits(), SALOMEDS_AttributeTableOfReal::GetRowUnits(), SALOMEDS_AttributeTableOfString::GetRowUnits(), SALOMEDS_AttributeStudyProperties::GetStoredComponents(), GetStrArray(), GetString(), SALOMEDS_AttributeTableOfInteger::GetTitle(), SALOMEDS_AttributeTableOfReal::GetTitle(), SALOMEDS_AttributeTableOfString::GetTitle(), SALOMEDS_AttributeTreeNode::GetTreeID(), SALOMEDS_AttributeStudyProperties::GetUnits(), SALOMEDS_AttributeStudyProperties::GetUserName(), SALOMEDS_AttributeTableOfInteger::GetValue(), SALOMEDS_AttributeTableOfReal::GetValue(), SALOMEDS_AttributeTableOfString::GetValue(), SALOMEDS_AttributeGraphic::GetVisibility(), HasFather(), SALOMEDS_AttributeTreeNode::HasFather(), SALOMEDS_AttributeTreeNode::HasFirst(), SALOMEDS_AttributeTreeNode::HasNext(), SALOMEDS_AttributePixMap::HasPixMap(), SALOMEDS_AttributeTreeNode::HasPrevious(), SALOMEDS_AttributeTableOfInteger::HasValue(), SALOMEDS_AttributeTableOfReal::HasValue(), SALOMEDS_AttributeTableOfString::HasValue(), SALOMEDS_AttributeTreeNode::InsertAfter(), SALOMEDS_AttributeTreeNode::InsertBefore(), SALOMEDS_AttributeTreeNode::IsChild(), SALOMEDS_AttributeTreeNode::IsDescendant(), SALOMEDS_AttributeDrawable::IsDrawable(), SALOMEDS_AttributeExpandable::IsExpandable(), SALOMEDS_AttributeTreeNode::IsFather(), SALOMEDS_AttributeStudyProperties::IsLocked(), SALOMEDS_AttributeStudyProperties::IsModified(), SALOMEDS_AttributeOpened::IsOpened(), IsRoot(), SALOMEDS_AttributeTreeNode::IsRoot(), SALOMEDS_AttributePythonObject::IsScript(), SALOMEDS_AttributeSelectable::IsSelectable(), IsSet(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeSequenceOfInteger::Length(), SALOMEDS_AttributeSequenceOfReal::Length(), SALOMEDS_AttributeTreeNode::Prepend(), SALOMEDS_AttributeTableOfString::PutValue(), SALOMEDS_AttributeTableOfReal::PutValue(), SALOMEDS_AttributeTableOfInteger::PutValue(), SALOMEDS_AttributeTreeNode::Remove(), SALOMEDS_AttributeTarget::Remove(), SALOMEDS_AttributeSequenceOfInteger::Remove(), SALOMEDS_AttributeSequenceOfReal::Remove(), RemoveID(), SALOMEDS_AttributeTableOfInteger::RemoveValue(), SALOMEDS_AttributeTableOfReal::RemoveValue(), SALOMEDS_AttributeTableOfString::RemoveValue(), SALOMEDS_GenericAttribute::SALOMEDS_GenericAttribute(), SALOMEDS_AttributeFlags::Set(), SetBool(), SALOMEDS_AttributeTableOfReal::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumn(), SALOMEDS_AttributeTableOfString::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumnTitle(), SALOMEDS_AttributeTableOfReal::SetColumnTitle(), SALOMEDS_AttributeTableOfString::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger::SetColumnTitles(), SALOMEDS_AttributeTableOfReal::SetColumnTitles(), SALOMEDS_AttributeTableOfString::SetColumnTitles(), SALOMEDS_AttributeStudyProperties::SetComment(), SALOMEDS_AttributeStudyProperties::SetCreationDate(), SALOMEDS_AttributeStudyProperties::SetCreationMode(), SALOMEDS_AttributeDrawable::SetDrawable(), SALOMEDS_AttributeExpandable::SetExpandable(), SALOMEDS_AttributeTreeNode::SetFather(), SALOMEDS_AttributeTreeNode::SetFirst(), SALOMEDS_AttributeFlags::SetFlags(), SetInt(), SetIntArray(), SALOMEDS_AttributeStudyProperties::SetLocked(), SALOMEDS_AttributeStudyProperties::SetModification(), SALOMEDS_AttributeStudyProperties::SetModified(), SALOMEDS_AttributeTableOfInteger::SetNbColumns(), SALOMEDS_AttributeTableOfReal::SetNbColumns(), SALOMEDS_AttributeTableOfString::SetNbColumns(), SALOMEDS_AttributeTreeNode::SetNext(), SALOMEDS_AttributePythonObject::SetObject(), SALOMEDS_AttributeOpened::SetOpened(), SALOMEDS_AttributePixMap::SetPixMap(), SALOMEDS_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDS_AttributeTableOfReal::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRow(), SALOMEDS_AttributeTableOfString::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRowTitle(), SALOMEDS_AttributeTableOfReal::SetRowTitle(), SALOMEDS_AttributeTableOfString::SetRowTitle(), SALOMEDS_AttributeTableOfInteger::SetRowTitles(), SALOMEDS_AttributeTableOfReal::SetRowTitles(), SALOMEDS_AttributeTableOfString::SetRowTitles(), SALOMEDS_AttributeTableOfInteger::SetRowUnit(), SALOMEDS_AttributeTableOfReal::SetRowUnit(), SALOMEDS_AttributeTableOfString::SetRowUnit(), SALOMEDS_AttributeTableOfInteger::SetRowUnits(), SALOMEDS_AttributeTableOfReal::SetRowUnits(), SALOMEDS_AttributeTableOfString::SetRowUnits(), SALOMEDS_AttributeSelectable::SetSelectable(), SetStrArray(), SetString(), SALOMEDS_AttributeTextColor::SetTextColor(), SALOMEDS_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDS_AttributeTableOfInteger::SetTitle(), SALOMEDS_AttributeTableOfReal::SetTitle(), SALOMEDS_AttributeTableOfString::SetTitle(), SALOMEDS_AttributeTreeNode::SetTreeID(), SALOMEDS_AttributeStudyProperties::SetUnits(), SALOMEDS_AttributeStudyProperties::SetUserName(), SALOMEDS_AttributeComment::SetValue(), SALOMEDS_AttributeExternalFileDef::SetValue(), SALOMEDS_AttributeFileType::SetValue(), SALOMEDS_AttributeIOR::SetValue(), SALOMEDS_AttributeName::SetValue(), SALOMEDS_AttributePersistentRef::SetValue(), SALOMEDS_AttributeString::SetValue(), SALOMEDS_AttributeUserID::SetValue(), SALOMEDS_AttributeReal::SetValue(), SALOMEDS_AttributeInteger::SetValue(), SALOMEDS_AttributeLocalID::SetValue(), SALOMEDS_AttributeGraphic::SetVisibility(), SALOMEDS_AttributeTableOfInteger::SortByColumn(), SALOMEDS_AttributeTableOfReal::SortByColumn(), SALOMEDS_AttributeTableOfString::SortByColumn(), SALOMEDS_AttributeTableOfInteger::SortByRow(), SALOMEDS_AttributeTableOfReal::SortByRow(), SALOMEDS_AttributeTableOfString::SortByRow(), SALOMEDS_AttributeTableOfInteger::SortColumn(), SALOMEDS_AttributeTableOfReal::SortColumn(), SALOMEDS_AttributeTableOfString::SortColumn(), SALOMEDS_AttributeTableOfInteger::SortRow(), SALOMEDS_AttributeTableOfReal::SortRow(), SALOMEDS_AttributeTableOfString::SortRow(), SALOMEDS_AttributeTableOfInteger::SwapCells(), SALOMEDS_AttributeTableOfReal::SwapCells(), SALOMEDS_AttributeTableOfString::SwapCells(), SALOMEDS_AttributeTableOfInteger::SwapColumns(), SALOMEDS_AttributeTableOfReal::SwapColumns(), SALOMEDS_AttributeTableOfString::SwapColumns(), SALOMEDS_AttributeTableOfInteger::SwapRows(), SALOMEDS_AttributeTableOfReal::SwapRows(), SALOMEDS_AttributeTableOfString::SwapRows(), SALOMEDS_AttributeTextColor::TextColor(), SALOMEDS_AttributeTextHighlightColor::TextHighlightColor(), SALOMEDS_GenericAttribute::Type(), SALOMEDS_AttributeComment::Value(), SALOMEDS_AttributeExternalFileDef::Value(), SALOMEDS_AttributeFileType::Value(), SALOMEDS_AttributeInteger::Value(), SALOMEDS_AttributeIOR::Value(), SALOMEDS_AttributeLocalID::Value(), SALOMEDS_AttributeName::Value(), SALOMEDS_AttributePersistentRef::Value(), SALOMEDS_AttributeReal::Value(), SALOMEDS_AttributeString::Value(), SALOMEDS_AttributeUserID::Value(), SALOMEDS_AttributeSequenceOfInteger::Value(), SALOMEDS_AttributeSequenceOfReal::Value(), and SALOMEDS_GenericAttribute::~SALOMEDS_GenericAttribute().
◆ _isLocal
bool SALOMEDS_GenericAttribute::_isLocal
◆ _local_impl
SALOMEDSImpl_GenericAttribute* SALOMEDS_GenericAttribute::_local_impl
Referenced by _PTR(), SALOMEDS_AttributeTarget::Add(), SALOMEDS_AttributeSequenceOfReal::Add(), SALOMEDS_AttributeSequenceOfInteger::Add(), SALOMEDS_AttributeTableOfReal::AddColumn(), SALOMEDS_AttributeTableOfInteger::AddColumn(), SALOMEDS_AttributeTableOfString::AddColumn(), SALOMEDS_AttributeTableOfReal::AddRow(), SALOMEDS_AttributeTableOfInteger::AddRow(), SALOMEDS_AttributeTableOfString::AddRow(), SALOMEDS_AttributeTreeNode::Append(), SALOMEDS_AttributeSequenceOfReal::Assign(), SALOMEDS_AttributeSequenceOfInteger::Assign(), SALOMEDS_AttributeSequenceOfReal::ChangeValue(), SALOMEDS_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), Clear(), SALOMEDS_AttributeSequenceOfInteger::CorbaSequence(), SALOMEDS_AttributeSequenceOfReal::CorbaSequence(), SALOMEDS_AttributeTreeNode::Depth(), SALOMEDS_AttributeTarget::Get(), GetBool(), SALOMEDS_GenericAttribute::GetClassType(), SALOMEDS_AttributeTableOfInteger::GetColumn(), SALOMEDS_AttributeTableOfReal::GetColumn(), SALOMEDS_AttributeTableOfString::GetColumn(), SALOMEDS_AttributeTableOfInteger::GetColumnTitle(), SALOMEDS_AttributeTableOfReal::GetColumnTitle(), SALOMEDS_AttributeTableOfString::GetColumnTitle(), SALOMEDS_AttributeTableOfInteger::GetColumnTitles(), SALOMEDS_AttributeTableOfReal::GetColumnTitles(), SALOMEDS_AttributeTableOfString::GetColumnTitles(), SALOMEDS_AttributeStudyProperties::GetComment(), SALOMEDS_AttributeStudyProperties::GetComponentVersion(), SALOMEDS_AttributeStudyProperties::GetComponentVersions(), SALOMEDS_AttributeStudyProperties::GetCreationDate(), SALOMEDS_AttributeStudyProperties::GetCreationMode(), SALOMEDS_AttributeFlags::GetFlags(), GetIDs(), GetInt(), GetIntArray(), SALOMEDS_AttributeStudyProperties::GetModificationsList(), SALOMEDS_AttributeStudyProperties::GetModified(), SALOMEDS_AttributeTableOfInteger::GetNbColumns(), SALOMEDS_AttributeTableOfReal::GetNbColumns(), SALOMEDS_AttributeTableOfString::GetNbColumns(), SALOMEDS_AttributeTableOfInteger::GetNbRows(), SALOMEDS_AttributeTableOfReal::GetNbRows(), SALOMEDS_AttributeTableOfString::GetNbRows(), SALOMEDS_AttributePythonObject::GetObject(), SALOMEDS_AttributePixMap::GetPixMap(), GetReal(), GetRealArray(), SALOMEDS_AttributeTableOfInteger::GetRow(), SALOMEDS_AttributeTableOfReal::GetRow(), SALOMEDS_AttributeTableOfString::GetRow(), SALOMEDS_AttributeTableOfInteger::GetRowSetIndices(), SALOMEDS_AttributeTableOfReal::GetRowSetIndices(), SALOMEDS_AttributeTableOfString::GetRowSetIndices(), SALOMEDS_AttributeTableOfInteger::GetRowTitle(), SALOMEDS_AttributeTableOfReal::GetRowTitle(), SALOMEDS_AttributeTableOfString::GetRowTitle(), SALOMEDS_AttributeTableOfInteger::GetRowTitles(), SALOMEDS_AttributeTableOfReal::GetRowTitles(), SALOMEDS_AttributeTableOfString::GetRowTitles(), SALOMEDS_AttributeTableOfInteger::GetRowUnit(), SALOMEDS_AttributeTableOfReal::GetRowUnit(), SALOMEDS_AttributeTableOfString::GetRowUnit(), SALOMEDS_AttributeTableOfInteger::GetRowUnits(), SALOMEDS_AttributeTableOfReal::GetRowUnits(), SALOMEDS_AttributeTableOfString::GetRowUnits(), SALOMEDS_AttributeStudyProperties::GetStoredComponents(), GetStrArray(), GetString(), SALOMEDS_AttributeTableOfInteger::GetTitle(), SALOMEDS_AttributeTableOfReal::GetTitle(), SALOMEDS_AttributeTableOfString::GetTitle(), SALOMEDS_AttributeTreeNode::GetTreeID(), SALOMEDS_AttributeStudyProperties::GetUnits(), SALOMEDS_AttributeStudyProperties::GetUserName(), SALOMEDS_AttributeTableOfInteger::GetValue(), SALOMEDS_AttributeTableOfReal::GetValue(), SALOMEDS_AttributeTableOfString::GetValue(), SALOMEDS_AttributeGraphic::GetVisibility(), HasFather(), SALOMEDS_AttributeTreeNode::HasFather(), SALOMEDS_AttributeTreeNode::HasFirst(), SALOMEDS_AttributeTreeNode::HasNext(), SALOMEDS_AttributePixMap::HasPixMap(), SALOMEDS_AttributeTreeNode::HasPrevious(), SALOMEDS_AttributeTableOfInteger::HasValue(), SALOMEDS_AttributeTableOfReal::HasValue(), SALOMEDS_AttributeTableOfString::HasValue(), SALOMEDS_AttributeTreeNode::InsertAfter(), SALOMEDS_AttributeTreeNode::InsertBefore(), SALOMEDS_AttributeTreeNode::IsChild(), SALOMEDS_AttributeTreeNode::IsDescendant(), SALOMEDS_AttributeDrawable::IsDrawable(), SALOMEDS_AttributeExpandable::IsExpandable(), SALOMEDS_AttributeTreeNode::IsFather(), SALOMEDS_AttributeStudyProperties::IsLocked(), SALOMEDS_AttributeStudyProperties::IsModified(), SALOMEDS_AttributeOpened::IsOpened(), IsRoot(), SALOMEDS_AttributeTreeNode::IsRoot(), SALOMEDS_AttributePythonObject::IsScript(), SALOMEDS_AttributeSelectable::IsSelectable(), IsSet(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeSequenceOfInteger::Length(), SALOMEDS_AttributeSequenceOfReal::Length(), SALOMEDS_AttributeTreeNode::Prepend(), SALOMEDS_AttributeTableOfString::PutValue(), SALOMEDS_AttributeTableOfReal::PutValue(), SALOMEDS_AttributeTableOfInteger::PutValue(), SALOMEDS_AttributeTreeNode::Remove(), SALOMEDS_AttributeTarget::Remove(), SALOMEDS_AttributeSequenceOfInteger::Remove(), SALOMEDS_AttributeSequenceOfReal::Remove(), RemoveID(), SALOMEDS_AttributeTableOfInteger::RemoveValue(), SALOMEDS_AttributeTableOfReal::RemoveValue(), SALOMEDS_AttributeTableOfString::RemoveValue(), SALOMEDS_GenericAttribute::SALOMEDS_GenericAttribute(), SALOMEDS_AttributeFlags::Set(), SetBool(), SALOMEDS_AttributeTableOfReal::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumn(), SALOMEDS_AttributeTableOfString::SetColumn(), SALOMEDS_AttributeTableOfInteger::SetColumnTitle(), SALOMEDS_AttributeTableOfReal::SetColumnTitle(), SALOMEDS_AttributeTableOfString::SetColumnTitle(), SALOMEDS_AttributeTableOfInteger::SetColumnTitles(), SALOMEDS_AttributeTableOfReal::SetColumnTitles(), SALOMEDS_AttributeTableOfString::SetColumnTitles(), SALOMEDS_AttributeStudyProperties::SetComment(), SALOMEDS_AttributeStudyProperties::SetCreationDate(), SALOMEDS_AttributeStudyProperties::SetCreationMode(), SALOMEDS_AttributeDrawable::SetDrawable(), SALOMEDS_AttributeExpandable::SetExpandable(), SALOMEDS_AttributeTreeNode::SetFather(), SALOMEDS_AttributeTreeNode::SetFirst(), SALOMEDS_AttributeFlags::SetFlags(), SetInt(), SetIntArray(), SALOMEDS_AttributeStudyProperties::SetLocked(), SALOMEDS_AttributeStudyProperties::SetModification(), SALOMEDS_AttributeStudyProperties::SetModified(), SALOMEDS_AttributeTableOfInteger::SetNbColumns(), SALOMEDS_AttributeTableOfReal::SetNbColumns(), SALOMEDS_AttributeTableOfString::SetNbColumns(), SALOMEDS_AttributeTreeNode::SetNext(), SALOMEDS_AttributePythonObject::SetObject(), SALOMEDS_AttributeOpened::SetOpened(), SALOMEDS_AttributePixMap::SetPixMap(), SALOMEDS_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDS_AttributeTableOfReal::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRow(), SALOMEDS_AttributeTableOfString::SetRow(), SALOMEDS_AttributeTableOfInteger::SetRowTitle(), SALOMEDS_AttributeTableOfReal::SetRowTitle(), SALOMEDS_AttributeTableOfString::SetRowTitle(), SALOMEDS_AttributeTableOfInteger::SetRowTitles(), SALOMEDS_AttributeTableOfReal::SetRowTitles(), SALOMEDS_AttributeTableOfString::SetRowTitles(), SALOMEDS_AttributeTableOfInteger::SetRowUnit(), SALOMEDS_AttributeTableOfReal::SetRowUnit(), SALOMEDS_AttributeTableOfString::SetRowUnit(), SALOMEDS_AttributeTableOfInteger::SetRowUnits(), SALOMEDS_AttributeTableOfReal::SetRowUnits(), SALOMEDS_AttributeTableOfString::SetRowUnits(), SALOMEDS_AttributeSelectable::SetSelectable(), SetStrArray(), SetString(), SALOMEDS_AttributeTextColor::SetTextColor(), SALOMEDS_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDS_AttributeTableOfInteger::SetTitle(), SALOMEDS_AttributeTableOfReal::SetTitle(), SALOMEDS_AttributeTableOfString::SetTitle(), SALOMEDS_AttributeTreeNode::SetTreeID(), SALOMEDS_AttributeStudyProperties::SetUnits(), SALOMEDS_AttributeStudyProperties::SetUserName(), SALOMEDS_AttributeComment::SetValue(), SALOMEDS_AttributeExternalFileDef::SetValue(), SALOMEDS_AttributeFileType::SetValue(), SALOMEDS_AttributeIOR::SetValue(), SALOMEDS_AttributeName::SetValue(), SALOMEDS_AttributePersistentRef::SetValue(), SALOMEDS_AttributeString::SetValue(), SALOMEDS_AttributeUserID::SetValue(), SALOMEDS_AttributeReal::SetValue(), SALOMEDS_AttributeInteger::SetValue(), SALOMEDS_AttributeLocalID::SetValue(), SALOMEDS_AttributeGraphic::SetVisibility(), SALOMEDS_AttributeTableOfInteger::SortByColumn(), SALOMEDS_AttributeTableOfReal::SortByColumn(), SALOMEDS_AttributeTableOfString::SortByColumn(), SALOMEDS_AttributeTableOfInteger::SortByRow(), SALOMEDS_AttributeTableOfReal::SortByRow(), SALOMEDS_AttributeTableOfString::SortByRow(), SALOMEDS_AttributeTableOfInteger::SortColumn(), SALOMEDS_AttributeTableOfReal::SortColumn(), SALOMEDS_AttributeTableOfString::SortColumn(), SALOMEDS_AttributeTableOfInteger::SortRow(), SALOMEDS_AttributeTableOfReal::SortRow(), SALOMEDS_AttributeTableOfString::SortRow(), SALOMEDS_AttributeTableOfInteger::SwapCells(), SALOMEDS_AttributeTableOfReal::SwapCells(), SALOMEDS_AttributeTableOfString::SwapCells(), SALOMEDS_AttributeTableOfInteger::SwapColumns(), SALOMEDS_AttributeTableOfReal::SwapColumns(), SALOMEDS_AttributeTableOfString::SwapColumns(), SALOMEDS_AttributeTableOfInteger::SwapRows(), SALOMEDS_AttributeTableOfReal::SwapRows(), SALOMEDS_AttributeTableOfString::SwapRows(), SALOMEDS_AttributeTextColor::TextColor(), SALOMEDS_AttributeTextHighlightColor::TextHighlightColor(), SALOMEDS_GenericAttribute::Type(), SALOMEDS_AttributeComment::Value(), SALOMEDS_AttributeExternalFileDef::Value(), SALOMEDS_AttributeFileType::Value(), SALOMEDS_AttributeInteger::Value(), SALOMEDS_AttributeIOR::Value(), SALOMEDS_AttributeLocalID::Value(), SALOMEDS_AttributeName::Value(), SALOMEDS_AttributePersistentRef::Value(), SALOMEDS_AttributeReal::Value(), SALOMEDS_AttributeString::Value(), SALOMEDS_AttributeUserID::Value(), SALOMEDS_AttributeSequenceOfInteger::Value(), and SALOMEDS_AttributeSequenceOfReal::Value().
