SALOMEDS_AttributeParameter.hxx
23// File : SALOMEDS_AttributeParameter.hxx
24// Author : Sergey RUIN
25// Module : SALOME
26//
27#ifndef SALOMEDS_AttributeParameter_HeaderFile
28#define SALOMEDS_AttributeParameter_HeaderFile
33
34// IDL headers
35#include <SALOMEconfig.h>
36#include CORBA_SERVER_HEADER(SALOMEDS)
37#include CORBA_SERVER_HEADER(SALOMEDS_Attributes)
38
40{
41public:
43 SALOMEDS_AttributeParameter(SALOMEDS::AttributeParameter_ptr theAttr);
45
46 virtual void SetInt(const std::string& theID, const int theValue);
47 virtual int GetInt(const std::string& theID);
48
49 virtual void SetReal(const std::string& theID, const double& theValue);
50 virtual double GetReal(const std::string& theID);
51
52 virtual void SetString(const std::string& theID, const std::string& theValue);
53 virtual std::string GetString(const std::string& theID);
54
55 virtual void SetBool(const std::string& theID, const bool& theValue);
56 virtual bool GetBool(const std::string& theID);
57
58 virtual void SetRealArray(const std::string& theID, const std::vector<double>& theArray);
59 virtual std::vector<double> GetRealArray(const std::string& theID);
60
61 virtual void SetIntArray(const std::string& theID, const std::vector<int>& theArray);
62 virtual std::vector<int> GetIntArray(const std::string& theID);
63
64 virtual void SetStrArray(const std::string& theID, const std::vector<std::string>& theArray);
65 virtual std::vector<std::string> GetStrArray(const std::string& theID);
66
67 virtual bool IsSet(const std::string& theID, const int theType);
68
69 virtual bool RemoveID(const std::string& theID, const int theType);
70
71 virtual _PTR(AttributeParameter) GetFather();
72 virtual bool HasFather();
73 virtual bool IsRoot();
74
75 virtual void Clear();
76
77 virtual std::vector<std::string> GetIDs(const int theType);
78};
79
80#endif
Definition: SALOMEDSClient_AttributeParameter.hxx:36
virtual clt_shared_ptr< SALOMEDSClient_AttributeParameter > GetFather()=0
Class: SALOMEDSImpl_AttributeParameter Description : AttributeParameter is a universal container of b...
Definition: SALOMEDSImpl_AttributeParameter.hxx:48
Definition: SALOMEDS_AttributeParameter.hxx:40
~SALOMEDS_AttributeParameter()
Function : Destructor Purpose : Destroys the instance of SALOMEDS_AttributeParameter.
Definition: SALOMEDS_AttributeParameter.cxx:58
virtual void SetStrArray(const std::string &theID, const std::vector< std::string > &theArray)
Function : SetStrArray Purpose : Associates an array of string values with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:307
virtual std::string GetString(const std::string &theID)
Function : GetString Purpose : Returns a string associated with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:157
virtual std::vector< std::string > GetStrArray(const std::string &theID)
Function : GetStrArray Purpose : Returns an array of string values associated with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:332
virtual void SetIntArray(const std::string &theID, const std::vector< int > &theArray)
Function : SetIntArray Purpose : Associates an array of int values with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:258
virtual bool IsSet(const std::string &theID, const int theType)
Function : IsSet Purpose : Returns true if for the ID of given type was assigned a value in the att...
Definition: SALOMEDS_AttributeParameter.cxx:358
virtual void SetReal(const std::string &theID, const double &theValue)
Function : SetReal Purpose : Associates a double value with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:103
Function : IsRoot Purpose : Returns True is the attribute is highest in an hierarchy.
Definition: SALOMEDS_AttributeParameter.cxx:432
Function : HasFather Purpose : Returns True if the attribute has a father attribute.
Definition: SALOMEDS_AttributeParameter.cxx:416
Function : Clear Purpose : Clears the content of the attribute.
Definition: SALOMEDS_AttributeParameter.cxx:448
virtual bool GetBool(const std::string &theID)
Function : GetBool Purpose : Returns a bool value associated with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:193
SALOMEDS_AttributeParameter(SALOMEDSImpl_AttributeParameter *theAttr)
Function : Constructor Purpose : Creates a new instance of SALOMEDS_AttributeParameter.
Definition: SALOMEDS_AttributeParameter.cxx:38
virtual void SetBool(const std::string &theID, const bool &theValue)
Function : SetBool Purpose : Associates a bool value with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:175
virtual int GetInt(const std::string &theID)
Function : GetInt Purpose : Returns a int value associated with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:85
virtual void SetRealArray(const std::string &theID, const std::vector< double > &theArray)
Function : SetRealArray Purpose : Associates an array of double values with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:209
virtual std::vector< int > GetIntArray(const std::string &theID)
Function : GetIntArray Purpose : Returns an array of int values associated with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:283
virtual std::vector< double > GetRealArray(const std::string &theID)
Function : GetRealArray Purpose : Returns an array of double values associated with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:234
virtual double GetReal(const std::string &theID)
Function : GetReal Purpose : Returns a double value associated with the given ID.
Definition: SALOMEDS_AttributeParameter.cxx:121
virtual void SetString(const std::string &theID, const std::string &theValue)
Function : SetString Purpose : Associates a string with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:139
virtual std::vector< std::string > GetIDs(const int theType)
Function : GetIDs Purpose : Returns an array of all ID's of the given type.
Definition: SALOMEDS_AttributeParameter.cxx:464
virtual bool RemoveID(const std::string &theID, const int theType)
Function : RemoveID Purpose : Removes a parameter with given ID.
Definition: SALOMEDS_AttributeParameter.cxx:374
virtual void SetInt(const std::string &theID, const int theValue)
Function : SetInt Purpose : Associates a integer value with the ID.
Definition: SALOMEDS_AttributeParameter.cxx:67
Definition: SALOMEDS_GenericAttribute.hxx:40
