SALOMEDSImpl_AttributeParameter.hxx
23// File : SALOMEDSImpl_AttributeIOR.hxx
24// Author : Sergey RUIN
25// Module : SALOME
26//
27#ifndef _SALOMEDSImpl_AttributeParameter_HeaderFile
28#define _SALOMEDSImpl_AttributeParameter_HeaderFile
31#include "DF_Attribute.hxx"
32#include "DF_Label.hxx"
34
35#include <vector>
36#include <string>
37#include <map>
38
40
48{
49
50private:
51
52 std::map<std::string, int> _ints;
53 std::map<std::string, double> _reals;
54 std::map<std::string, std::string> _strings;
55 std::map<std::string, bool> _bools;
56 std::map< std::string, std::vector<double> > _realarrays;
57 std::map< std::string, std::vector<int> > _intarrays;
58 std::map< std::string, std::vector<std::string> > _strarrays;
59
60public:
61
62 static const std::string& GetID() ;
63
65 static SALOMEDSImpl_AttributeParameter* Set (const DF_Label& L);
66
67 void SetInt(const std::string& theID, const int& theValue);
68 int GetInt(const std::string& theID);
69
70 void SetReal(const std::string& theID, const double& theValue);
71 double GetReal(const std::string& theID);
72
73 void SetString(const std::string& theID, const std::string& theValue);
74 std::string GetString(const std::string& theID);
75
76 void SetBool(const std::string& theID, const bool& theValue);
77 bool GetBool(const std::string& theID);
78
79 void SetRealArray(const std::string& theID, const std::vector<double>& theArray);
80 std::vector<double> GetRealArray(const std::string& theID);
81
82 void SetIntArray(const std::string& theID, const std::vector<int>& theArray);
83 std::vector<int> GetIntArray(const std::string& theID);
84
85 void SetStrArray(const std::string& theID, const std::vector<std::string>& theArray);
86 std::vector<std::string> GetStrArray(const std::string& theID);
87
88 bool IsSet(const std::string& theID, const Parameter_Types theType);
89
90 bool RemoveID(const std::string& theID, const Parameter_Types theType);
91
93 bool HasFather();
94 bool IsRoot();
95
96 std::vector<std::string> GetIDs(const Parameter_Types theType);
97
98 void Clear();
99
100 virtual std::string Save();
101 virtual void Load(const std::string& theValue);
102
103 const std::string& ID() const;
104 void Restore(DF_Attribute* with) ;
105 DF_Attribute* NewEmpty() const;
106 void Paste(DF_Attribute* into);
107
109};
110
111#endif
Parameter_Types
Definition: SALOMEDSImpl_AttributeParameter.hxx:39
@ PT_INTEGER
@ PT_STRING
@ PT_REAL
@ PT_BOOLEAN
@ PT_STRARRAY
@ PT_INTARRAY
@ PT_REALARRAY
#define SALOMEDSIMPL_EXPORT
Definition: SALOMEDSImpl_Defines.hxx:34
Definition: DF_Attribute.hxx:30
virtual void Restore(DF_Attribute *theAttribute)=0
virtual const std::string & ID() const =0
Definition: DF_Attribute.hxx:47
virtual DF_Attribute * NewEmpty() const =0
virtual void Load(const std::string &)
Definition: DF_Attribute.hxx:48
virtual void Paste(DF_Attribute *theIntoAttribute)=0
Definition: DF_Label.hxx:65
Class: SALOMEDSImpl_AttributeParameter Description : AttributeParameter is a universal container of b...
Definition: SALOMEDSImpl_AttributeParameter.hxx:48
std::map< std::string, std::vector< int > > _intarrays
Definition: SALOMEDSImpl_AttributeParameter.hxx:57
~SALOMEDSImpl_AttributeParameter()
Definition: SALOMEDSImpl_AttributeParameter.hxx:108
std::map< std::string, std::vector< double > > _realarrays
Definition: SALOMEDSImpl_AttributeParameter.hxx:56
Definition: SALOMEDSImpl_AttributeParameter.hxx:64
std::map< std::string, std::string > _strings
Definition: SALOMEDSImpl_AttributeParameter.hxx:54
std::map< std::string, std::vector< std::string > > _strarrays
Definition: SALOMEDSImpl_AttributeParameter.hxx:58
std::map< std::string, double > _reals
Definition: SALOMEDSImpl_AttributeParameter.hxx:53
std::map< std::string, bool > _bools
Definition: SALOMEDSImpl_AttributeParameter.hxx:55
std::map< std::string, int > _ints
Definition: SALOMEDSImpl_AttributeParameter.hxx:52
Definition: SALOMEDSImpl_GenericAttribute.hxx:39
