SALOME_ContainerManager.cxx File Reference
#include "SALOME_ContainerManager.hxx"
#include "SALOME_ResourcesManager.hxx"
#include "SALOME_LoadRateManager.hxx"
#include "SALOME_Container_i.hxx"
#include "SALOME_ResourcesManager_Client.hxx"
#include "SALOME_Embedded_NamingService.hxx"
#include "SALOME_ModuleCatalog.hh"
#include "Basics_Utils.hxx"
#include "Basics_DirUtils.hxx"
#include "PythonCppUtils.hxx"
#include "KernelBasis.hxx"
#include <sys/types.h>
#include <sys/stat.h>
#include <signal.h>
#include <unistd.h>
#include <sstream>
#include <queue>
#include <thread>
#include <chrono>
#include <CORBA_CLIENT_HEADER(SALOME_Session)>
Include dependency graph for SALOME_ContainerManager.cxx:
bool isPythonContainer (const char *ContainerName)
 This is no longer valid (C++ container are also python containers) More...
std::string getScriptTemplateFilePath ()
 Return a path to the directory with scripts templates. More...
std::string GetCommandFromTemplate (const std::string &theScriptName, std::queue< std::string > &theScriptParameters)
 Return a command line constructed based on Python scripts templates. More...
◆ GetCommandFromTemplate()
std::string GetCommandFromTemplate ( const std::string &  theScriptName,
std::queue< std::string > &  theScriptParameters
theScriptNamethe name of Python script template
theScriptParametersthe queue of parameter values
the command line constructed according to the given parameters
References pythfilter::args, TestKernelHelpers::command, getScriptTemplateFilePath(), MESSAGE, and test::res.
Referenced by SALOME_ContainerManager::BuildCommandToLaunchLocalContainer(), and SALOME_ContainerManager::getCommandToRunRemoteProcessCommon().
◆ getScriptTemplateFilePath()
std::string getScriptTemplateFilePath ( )
the path pointed by SALOME_KERNEL_SCRIPTS_DIR environment variable, if it is defined, ${KERNEL_ROOT_DIR}/share/salome/resources/separator/kernel/ScriptsTemplate - otherwise
References SALOME_ContainerManager::GetenvThreadSafeAsString().
Referenced by GetCommandFromTemplate().
◆ isPythonContainer()
bool isPythonContainer ( const char *  ContainerName)
References TestKernelHelpers::ret.
Referenced by SALOME_ContainerManager::BuildCommandToLaunchLocalContainer(), and SALOME_ContainerManager::BuildTempFileToLaunchRemoteContainer().
