SALOME_ContainerManager.hxx
23#pragma once
24
25#include "SALOME_Container.hxx"
26
27#include <SALOMEconfig.h>
28#include CORBA_CLIENT_HEADER(SALOME_Component)
29#include CORBA_CLIENT_HEADER(SALOME_ContainerManager)
31
32#include "Utils_Mutex.hxx"
33
34#include <vector>
35#include <string>
36#include <utility>
37#include <functional>
38#include <set>
39
42
44{
45
46public:
47 SALOME_ContainerManager(CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns);
49
50 // Corba Methods
51 Engines::Container_ptr GiveContainer(const Engines::ContainerParameters& params) override;
52
53 void ShutdownContainers() override;
54
55 void ShutdownContainersNow() override;
56
57 void SetOverrideEnvForContainers(const Engines::KeyValDict& env) override;
58
59 Engines::KeyValDict *GetOverrideEnvForContainers() override;
60
61 void SetCodeOnContainerStartUp(const char *code) override;
62
63 char *GetCodeOnContainerStartUp() override;
64
65 // C++ Methods
66 void Shutdown();
67
68 void DeclareUsingSalomeSession() { _isSSL = false; }
69
70 CORBA::Long GetTimeOutToLaunchServerInSecond() override;
71
72 void SetTimeOutToLaunchServerInSecond(CORBA::Long timeInSecond) override;
73
74 CORBA::Long GetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond() override;
75
76 void SetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond(CORBA::Long timeInMS) override;
77
78 CORBA::Long GetDeltaTimeBetweenCPUMemMeasureInMilliSecond() override;
79
80 void SetDeltaTimeBetweenCPUMemMeasureInMilliSecond(CORBA::Long timeInMS) override;
81
82 void SetBigObjOnDiskThreshold(CORBA::Long thresholdInByte) override;
83
84 void SetBigObjOnDiskDirectory(const char *directory) override;
85
86 void SetDirectoryForReplayFiles(const char *directory) override;
87
88 void SetNumberOfRetry(CORBA::Long nbRetry) override;
89
90 CORBA::Long GetNumberOfRetry() override;
91
92 static const char *_ContainerManagerNameInNS;
93
94private:
95
96 void ShutdownContainersGeneric(std::function<void(Engines::Container_ptr)> funcToBeCalledOnContainer);
97
98protected:
99 // C++ methods
100 Engines::Container_ptr
101 FindContainer(const Engines::ContainerParameters& params,
102 const Engines::ResourceList& possibleResources);
103
104 Engines::Container_ptr
105 FindContainer(const Engines::ContainerParameters& params,
106 const std::string& resource);
107
108 std::string GetCppBinaryOfKernelSSLContainer() const;
109
110 std::string GetCppBinaryOfKernelContainer() const;
111
112 std::string GetRunRemoteExecutableScript() const;
113
114 std::string BuildCommandToLaunchRemoteContainer(const std::string & resource_name,
115 const Engines::ContainerParameters& params,
116 const std::string& container_exe="SALOME_Container") const;
117
118 std::string BuildCommandToLaunchLocalContainer(const Engines::ContainerParameters& params,
119 const std::string& machinesFile,
120 const std::string& container_exe,//"SALOME_Container"
121 std::string& tmpFileName) const;
122
123 std::string BuildTempFileToLaunchRemoteContainer(const std::string& resource_name,
124 const Engines::ContainerParameters& params, std::string& tmpFileName) const;
125
126 static void RmTmpFile(std::string& tmpFile);
127
128 void AddOmninamesParams(std::string& command) const;
129
130 void AddOmninamesParams(std::ostream& fileStream) const;
131
132 static std::string BuildTemporaryFileName();
133
134 std::string GetMPIZeroNode(const std::string machine, const std::string machinesFile) const;
135
136 std::string machinesFile(const int nbproc);
137
138 std::string getCommandToRunRemoteProcessCommon(const std::string& templateName, const std::string& remoteScript,
139 AccessProtocolType protocol,
140 const std::string & hostname,
141 const std::string & username,
142 const std::string & applipath,
143 const std::string & workdir) const;
144
145 std::string getCommandToRunRemoteProcess(AccessProtocolType protocol,
146 const std::string & hostname,
147 const std::string & username,
148 const std::string & applipath,
149 const std::string & workdir="") const;
150
151 std::string getCommandToRunRemoteProcessNoAppli(AccessProtocolType protocol,
152 const std::string & hostname,
153 const std::string & username,
154 const std::string & applipath,
155 const std::string & workdir="") const;
156
157 Engines::Container_ptr
158 LaunchContainer(const Engines::ContainerParameters& params,
159 const std::string & resource_selected,
160 const std::string & hostname,
161 const std::string & machFile,
162 const std::string & containerNameInNS);
163
164 CORBA::ORB_var _orb;
165 PortableServer::POA_var _poa;
166
169
172
175
177 bool _isSSL = true;
178
179 static omni_mutex _numInstanceMutex ; // lib and instance protection
180
183
185
186 // Begin of PacO++ Parallel extension
187 typedef std::vector<std::string> actual_launch_machine_t;
188
189 bool checkPaCOParameters(Engines::ContainerParameters & params, std::string resource_selected);
190
191 Engines::Container_ptr
192 StartPaCOPPContainer(const Engines::ContainerParameters& params, std::string resource_selected);
193
194
195
196 std::string BuildCommandToLaunchPaCOProxyContainer(const Engines::ContainerParameters& params,
197 std::string machine_file_name,
198 std::string & proxy_hostname);
199
200 std::string BuildCommandToLaunchPaCONodeContainer(const Engines::ContainerParameters& params,
201 const std::string & machine_file_name,
203 const std::string & proxy_hostname);
204
205 void LogConfiguration(const std::string & log_type,
206 const std::string & exe_type,
207 const std::string & container_name,
208 const std::string & hostname,
209 std::string & begin,
210 std::string & end);
211
212 CORBA::Object_ptr
213 LaunchPaCOProxyContainer(const std::string& command,
214 const Engines::ContainerParameters& params,
215 const std::string& hostname);
216
217 bool
218 LaunchPaCONodeContainer(const std::string& command,
219 const Engines::ContainerParameters& params,
220 const std::string& name,
222 // End of PaCO++ Parallel extension
223public:
224 static char *GetenvThreadSafe(const char *name);
225 static std::string GetenvThreadSafeAsString(const char *name);
226 static int SystemThreadSafe(const char *command);
227 static long SystemWithPIDThreadSafe(const std::vector<std::string>& command);
228 static void AddOmninamesParams(std::ostream& fileStream, SALOME_NamingService_Abstract *ns);
229 static void MakeTheCommandToBeLaunchedASync(std::string& command);
230 static int GetTimeOutToLoaunchServer();
231 static void SleepInSecond(int ellapseTimeInSecond);
232 private:
233 static const int TIME_OUT_TO_LAUNCH_CONT;
237private:
238 std::vector< std::pair<std::string, std::string> > _override_env;
243};
#define CONTAINER_EXPORT
Definition: SALOME_Container.hxx:37
AccessProtocolType
Definition: SALOME_ResourcesCatalog_Parser.hxx:44
Definition: SALOME_ContainerManager.hxx:44
Definition: SALOME_ContainerManager.hxx:68
Definition: SALOME_ContainerManager.hxx:165
std::vector< std::pair< std::string, std::string > > _override_env
Definition: SALOME_ContainerManager.hxx:238
SALOME_NamingService_Abstract * _NS
Definition: SALOME_ContainerManager.hxx:168
std::string _code_to_exe_on_startup
Definition: SALOME_ContainerManager.hxx:242
int _nbprocUsed
attribute that contains the number of processes used in batch mode by MPI containers
Definition: SALOME_ContainerManager.hxx:174
static Utils_Mutex _systemMutex
Definition: SALOME_ContainerManager.hxx:236
Definition: SALOME_ContainerManager.hxx:179
Definition: SALOME_ContainerManager.hxx:233
static Utils_Mutex _getenvMutex
Definition: SALOME_ContainerManager.hxx:235
pid_t _pid_mpiServer
Definition: SALOME_ContainerManager.hxx:184
static const int DFT_DELTA_TIME_NS_LOOKUP_IN_MS
Definition: SALOME_ContainerManager.hxx:234
CORBA::ORB_var _orb
Definition: SALOME_ContainerManager.hxx:164
int _delta_time_ns_lookup_in_ms
Definition: SALOME_ContainerManager.hxx:240
int _time_out_in_second
Definition: SALOME_ContainerManager.hxx:239
int _delta_time_measure_in_ms
Definition: SALOME_ContainerManager.hxx:241
static const char * _ContainerManagerNameInNS
Definition: SALOME_ContainerManager.hxx:92
Utils_Mutex _giveContainerMutex1
attributes to allow concurrency for // GiveContainer
Definition: SALOME_ContainerManager.hxx:182
std::vector< std::string > actual_launch_machine_t
Definition: SALOME_ContainerManager.hxx:187
SALOME_ResourcesManager_Client * _resManager
Definition: SALOME_ContainerManager.hxx:167
bool _isAppliSalomeDefined
different behaviour if $APPLI exists (SALOME Application)
Definition: SALOME_ContainerManager.hxx:171
Definition: SALOME_NamingService_Abstract.hxx:46
Definition: SALOME_ResourcesManager_Client.hxx:33
Definition: Utils_Mutex.hxx:37
sequence< string > ResourceList
Type to transmit list of resources.
Definition: SALOME_ResourcesManager.idl:35
sequence< KeyValPairString > KeyValDict
Definition: SALOME_ContainerManager.idl:76
poa
Definition: SALOME_ContainerPy.py:377
list command
Definition: TestKernelHelpers.py:48
container_name
Definition: TestLifeCycleCORBA.py:42
ContainerManager
Definition: TestLifeCycleCORBA.py:57
string name
Definition: pythfilter.py:56
orb
Definition: salome.py:122
hostname
Definition: test.py:29
Type to describe required properties of a container.
Definition: SALOME_ContainerManager.idl:38
