29#ifndef _SALOME_CONTAINER_I_HXX_
30#define _SALOME_CONTAINER_I_HXX_
35#include <SALOMEconfig.h>
36#include CORBA_SERVER_HEADER(SALOME_Component)
37#include CORBA_SERVER_HEADER(SALOME_PyNode)
38#include CORBA_SERVER_HEADER(SALOME_Locker)
47#include <omnithread.h>
56 public virtual PortableServer::ServantBase
62 PortableServer::POA_ptr
poa,
64 int argc,
char *
argv[],
66 bool isServantAloneInProcess =
true);
75 virtual bool load_component_Library(
const char *componentName, CORBA::String_out reason);
77 virtual Engines::EngineComponent_ptr
78 create_component_instance(
const char *componentName);
86 void set_big_obj_on_disk_threshold(CORBA::Long thresholdInByte)
override;
88 void set_big_obj_on_disk_directory(
const char *directory)
override;
90 void set_number_of_retry(CORBA::Long nbRetry)
override;
92 void set_timeout_before_retrying(CORBA::Long timeInSecond)
override;
94 void set_current_directory(
const char *
cwd)
override;
96 void set_directory_for_replay_files(
override;
98 void set_startup_code(
const char *codeAtStartUp)
override;
100 char *get_startup_code()
override;
106 void execute_python_code(
const char *code)
override;
108 virtual Engines::EngineComponent_ptr
109 create_component_instance_env(
111 CORBA::String_out reason);
114 create_python_service_instance(
const char *CompName,
115 CORBA::String_out reason);
117 Engines::EngineComponent_ptr
118 find_component_instance(
const char *registeredName);
120 Engines::EngineComponent_ptr
121 load_impl(
const char *nameToRegister,
122 const char *componentName);
126 Engines::EmbeddedNamingService_ptr get_embedded_NS_if_ssl()
override;
130 void remove_impl(Engines::EngineComponent_ptr component_i);
131 void finalize_removal();
136 void setPyScriptForCPULoad(
const char *script);
137 void resetScriptForCPULoad();
143 char *logfilename()
override;
144 void logfilename(
const char *
name)
override;
145 char *locallogfilename()
override;
146 void locallogfilename(
const char *
name)
override;
147 CORBA::Long monitoringtimeresms()
override;
148 void monitoringtimeresms(CORBA::Long intervalInMs)
override;
149 void verbosity(
bool& activated, CORBA::String_out
level)
override;
150 void setVerbosity(
bool activated,
const char *
level)
override;
152 void Shutdown()
override;
153 void ShutdownNow()
override;
155 CORBA::Long getPID();
159 Engines::fileRef_ptr createFileRef(
const char *origFileName);
160 Engines::fileTransfer_ptr getFileTransfer();
162 virtual Engines::Salome_file_ptr createSalome_file(
163 void copyFile(Engines::Container_ptr
container,
const char *remoteFile,
const char *localFile);
164 Engines::PyNode_ptr createPyNode(
const char *nodeName,
const char *code);
165 Engines::PyNode_ptr getDefaultPyNode(
const char *nodeName);
166 Engines::PyScriptNode_ptr createPyScriptNode(
const char *code);
167 void removePyScriptNode(
override;
168 void cleanAllPyScripts()
override;
169 Engines::PyScriptNode_ptr getDefaultPyScriptNode(
172 Engines::EngineComponent_ptr
173 find_or_create_instance(std::string genericRegisterName,
174 std::string componentLibraryName);
176 bool load_component_CppImplementation(
const char *componentName, std::string &reason);
177 bool load_component_PythonImplementation(
178 bool load_component_ExecutableImplementation(
180 Engines::EngineComponent_ptr createPythonInstance(std::string CompName, std::string &
error);
181 Engines::EngineComponent_ptr createExecutableInstance(std::string CompName,
const Engines::FieldsDict &env, std::string &
error);
182 Engines::EngineComponent_ptr createInstance(std::string genericRegisterName,
void *handle, std::string &
error);
185 static void decInstanceCnt(std::string genericRegisterName);
193 void registerTemporaryFile(
const std::string &fileName);
194 void unregisterTemporaryFile(
195 void clearTemporaryFiles();
200 void ShutdownCommonPart();
219 PortableServer::ObjectId *
_id;
248 PortableServer::POA_ptr
poa,
250 int argc,
char *
argv[],
252 bool isServantAloneInProcess =
true) :
262 PortableServer::POA_ptr
poa,
264 int argc,
char *
argv[],
266 bool isServantAloneInProcess =
true) :
275 PortableServer::POA_ptr
poa,
277 int argc,
char *
argv[],
279 bool isServantAloneInProcess =
true) :
287 PortableServer::POA_ptr
poa,
289 int argc,
char *
argv[],
291 bool isServantAloneInProcess =
true) :
299 PortableServer::POA_ptr
poa,
301 int argc,
char *
argv[],
303 bool isServantAloneInProcess =
true) :
311 PortableServer::POA_ptr
poa,
313 int argc,
char *
argv[],
315 bool isServantAloneInProcess =
true) :
323 PortableServer::POA_ptr
poa,
325 int argc,
char *
argv[],
327 bool isServantAloneInProcess =
true) :
bool isPythonContainer(const char *ContainerName)
This is no longer valid (C++ container are also python containers)
Definition: SALOME_ContainerManager.cxx:891
#define CONTAINER_EXPORT
Definition: SALOME_Container.hxx:37
constexpr char PY_CONTAINER_CLS_NAME_OUT_PROCESS_NO_REPLAY_FT[]
Definition: SALOME_Container_i.hxx:240
constexpr char PY_CONTAINER_CLS_NAME_OUT_PROCESS_NO_REPLAY[]
Definition: SALOME_Container_i.hxx:238
constexpr char PY_CONTAINER_CLS_NAME_IN_PROCESS[]
Definition: SALOME_Container_i.hxx:237
constexpr char PY_CONTAINER_CLS_NAME_OUT_PROCESS_WITH_REPLAY[]
Definition: SALOME_Container_i.hxx:239
constexpr char PY_CONTAINER_CLS_NAME_OUT_PROCESS_WITH_REPLAY_FT[]
Definition: SALOME_Container_i.hxx:241
Definition: SALOME_Container_i.hxx:258
bool isSSLMode() const override
Definition: SALOME_Container_i.hxx:268
Abstract_Engines_Container_SSL_i(const std::string &pyContainerClsName, CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:260
Definition: SALOME_Container_i.hxx:57
std::vector< std::vector< std::string > > _groups_of_log_files
Definition: SALOME_Container_i.hxx:229
std::string _library_path
Definition: SALOME_Container_i.hxx:210
bool _isServantAloneInProcess
Definition: SALOME_Container_i.hxx:234
std::map< std::string, Engines::PyNode_var > _dftPyNode
Definition: SALOME_Container_i.hxx:225
static std::map< std::string, void * > _toRemove_map
Definition: SALOME_Container_i.hxx:204
std::string _localfilename
Definition: SALOME_Container_i.hxx:213
Engines::fileTransfer_var _fileTransfer
Definition: SALOME_Container_i.hxx:228
std::string _logfilename
Definition: SALOME_Container_i.hxx:212
static std::map< std::string, void * > _library_map
Definition: SALOME_Container_i.hxx:203
static omni_mutex _numInstanceMutex
Definition: SALOME_Container_i.hxx:205
SALOME_NamingService_Container_Abstract * _NS
Definition: SALOME_Container_i.hxx:209
std::string _py_container_name
Definition: SALOME_Container_i.hxx:215
CORBA::ORB_var _orb
Definition: SALOME_Container_i.hxx:217
bool is_SSL_mode() override
Definition: SALOME_Container_i.hxx:124
std::string getPyContainerClassName() const
Definition: SALOME_Container_i.hxx:71
int getArgc()
Definition: SALOME_Container_i.hxx:190
PortableServer::ObjectId * _id
Definition: SALOME_Container_i.hxx:219
int _argc
Definition: SALOME_Container_i.hxx:231
Utils_Mutex _mutexForDftPy
Definition: SALOME_Container_i.hxx:226
std::string _load_script
Definition: SALOME_Container_i.hxx:214
char ** _argv
Definition: SALOME_Container_i.hxx:232
std::map< std::string, Engines::Salome_file_var > _Salome_file_map
Definition: SALOME_Container_i.hxx:223
std::string _code_at_startup
Definition: SALOME_Container_i.hxx:216
std::map< std::string, Engines::fileRef_var > _fileRef_map
Definition: SALOME_Container_i.hxx:222
PortableServer::ObjectId * getCORBAId() const
Definition: SALOME_Container_i.hxx:196
std::list< std::string > _tmp_files
Definition: SALOME_Container_i.hxx:227
int _numInstance
Definition: SALOME_Container_i.hxx:220
std::map< std::string, Engines::EngineComponent_var > _listInstances_map
Definition: SALOME_Container_i.hxx:221
static std::map< std::string, int > _cntInstances_map
Definition: SALOME_Container_i.hxx:202
std::string _containerName
Definition: SALOME_Container_i.hxx:211
SALOME_NamingService_Container_Abstract * getNS() const
Definition: SALOME_Container_i.hxx:128
static const int DFT_TIME_INTERVAL_BTW_MEASURE
Definition: SALOME_Container_i.hxx:198
std::map< std::string, Engines::PyScriptNode_var > _dftPyScriptNode
Definition: SALOME_Container_i.hxx:224
char ** getArgv()
Definition: SALOME_Container_i.hxx:191
bool _isSupervContainer
Definition: SALOME_Container_i.hxx:207
PortableServer::POA_var _poa
Definition: SALOME_Container_i.hxx:218
virtual bool isSSLMode() const =0
long _pid
Definition: SALOME_Container_i.hxx:233
Definition: SALOME_Container_i.hxx:308
Engines_Container_SSL_OutOfProcess_FT_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:310
Definition: SALOME_Container_i.hxx:320
Engines_Container_SSL_OutOfProcess_Replay_FT_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:322
Definition: SALOME_Container_i.hxx:296
Engines_Container_SSL_OutOfProcess_Replay_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:298
Definition: SALOME_Container_i.hxx:284
Engines_Container_SSL_OutOfProcess_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:286
Definition: SALOME_Container_i.hxx:272
Engines_Container_SSL_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:274
C++ implementation of Engines::Container interface.
Definition: SALOME_Container_i.hxx:244
Engines_Container_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
Definition: SALOME_Container_i.hxx:247
Definition: SALOME_Container_i.hxx:254
Engines_Container_i()
Definition: SALOME_Container_i.hxx:246
Definition: SALOME_NamingService_Abstract.hxx:32
Definition: Utils_Mutex.hxx:37
sequence< vectorOfString > vectorOfVectorOfString
Definition: SALOME_Component.idl:68
sequence< KeyValuePair > FieldsDict
Definition: SALOME_Component.idl:65
sequence< double > vectorOfDouble
Definition: SALOME_Component.idl:66
sequence< string > vectorOfString
Definition: SALOME_Component.idl:67
def error(message)
Definition: IDLparser.py:67
def getTotalPhysicalMemory()
Definition: salome_psutil.py:71
def getTotalPhysicalMemoryInUseByMe()
Definition: salome_psutil.py:87
def getTotalPhysicalMemoryInUse()
Definition: salome_psutil.py:79
def loadOfCPUCores(script=None)
Definition: salome_psutil.py:37
def getNumberOfCPUCores()
Definition: salome_psutil.py:29
Methods to be used in SSL mode to skip NS.
Definition: SALOME_Container_i.hxx:335
Engines::Container_var getContainerRefSA()
Definition: Container_i.cxx:2533
Abstract_Engines_Container_SSL_i * getContainerSA()
Definition: Container_i.cxx:2496
poa
Definition: SALOME_ContainerPy.py:377
containerName
Definition: SALOME_ContainerPy.py:383
container
Definition: TestComponentPy.py:63
level
Definition: TestLauncherSessionArgs.py:29
verbosity
Definition: TestLifeCycleCORBA_SWIG.py:86
argv
Definition: envSalome.py:42
cwd
Definition: launcher_use_case.py:40
string name
Definition: pythfilter.py:56
def getHostName()
Definition: salome_utils.py:137
orb
Definition: salome.py:122
