Abstract_Engines_Container_SSL_i Class Reference
#include <SALOME_Container_i.hxx>
Inheritance diagram for Abstract_Engines_Container_SSL_i:
 Abstract_Engines_Container_SSL_i (const std::string &pyContainerClsName, CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, char *containerName, int argc, char *argv[], SALOME_NamingService_Container_Abstract *ns=nullptr, bool isServantAloneInProcess=true)
bool isSSLMode () const override
std::string getPyContainerClassName () const
virtual bool load_component_Library (const char *componentName, CORBA::String_out reason)
 load a component implementation More...
virtual Engines::EngineComponent_ptr create_component_instance (const char *componentName)
 Create a new component instance. More...
void override_environment_python (const Engines::FieldsDict &env) override
void override_environment (const Engines::FieldsDict &env) override
Engines::FieldsDict * get_os_environment () override
void set_big_obj_on_disk_threshold (CORBA::Long thresholdInByte) override
void set_big_obj_on_disk_directory (const char *directory) override
void set_number_of_retry (CORBA::Long nbRetry) override
void set_timeout_before_retrying (CORBA::Long timeInSecond) override
void set_current_directory (const char *cwd) override
void set_directory_for_replay_files (const char *directory) override
void set_startup_code (const char *codeAtStartUp) override
char * get_startup_code () override
void addLogFileNameGroup (const Engines::vectorOfString &groupOfLogFileNames) override
Engines::vectorOfVectorOfString * getAllLogFileNameGroups () override
void execute_python_code (const char *code) override
virtual Engines::EngineComponent_ptr create_component_instance_env (const char *componentName, const Engines::FieldsDict &env, CORBA::String_out reason)
 Create a new component instance with environment variables specified. More...
virtual char * create_python_service_instance (const char *CompName, CORBA::String_out reason)
Engines::EngineComponent_ptr find_component_instance (const char *registeredName)
 Find an existing (in the container) component instance. More...
Engines::EngineComponent_ptr load_impl (const char *nameToRegister, const char *componentName)
 Find or create a new component instance. More...
bool is_SSL_mode () override
Engines::EmbeddedNamingService_ptr get_embedded_NS_if_ssl () override
SALOME_NamingService_Container_Abstract * getNS () const
void remove_impl (Engines::EngineComponent_ptr component_i)
 Remove the component instance from container. More...
void finalize_removal ()
 Unload component libraries from the container. More...
virtual void ping ()
 Ping the servant to check it is still alive. More...
CORBA::Long getNumberOfCPUCores ()
 Get number of CPU cores in the calculation node. More...
Engines::vectorOfDouble * loadOfCPUCores ()
void setPyScriptForCPULoad (const char *script)
 Set custom script to calculate a load of each CPU core. More...
void resetScriptForCPULoad ()
 Nullify custom script to calculate each CPU core's load. More...
CORBA::Long getTotalPhysicalMemory ()
 Get total physical memory of calculation node, in megabytes. More...
CORBA::Long getTotalPhysicalMemoryInUse ()
 Get used physical memory of calculation node, in megabytes. More...
CORBA::Long getTotalPhysicalMemoryInUseByMe ()
 Obtain physical memory, used by the current process, in megabytes. More...
char * name ()
 Get container name. More...
char * workingdir ()
 Get container working directory. More...
char * logfilename () override
 Get container log file name. More...
void logfilename (const char *name) override
 Set container log file name. More...
char * locallogfilename () override
void locallogfilename (const char *name) override
CORBA::Long monitoringtimeresms () override
void monitoringtimeresms (CORBA::Long intervalInMs) override
void verbosity (bool &activated, CORBA::String_out level) override
void setVerbosity (bool activated, const char *level) override
void Shutdown () override
 Shutdown the container. More...
void ShutdownNow () override
char * getHostName ()
 Get container host name. More...
CORBA::Long getPID ()
 Get container PID. More...
bool Kill_impl ()
 Kill current container. More...
Engines::fileRef_ptr createFileRef (const char *origFileName)
 Get or create a file reference object associated to a local file (to transfer it) More...
Engines::fileTransfer_ptr getFileTransfer ()
 Get a fileTransfer reference. More...
virtual Engines::Salome_file_ptr createSalome_file (const char *origFileName)
 Create a Salome file. More...
void copyFile (Engines::Container_ptr container, const char *remoteFile, const char *localFile)
 copy a file from a remote host (container) to the local host More...
Engines::PyNode_ptr createPyNode (const char *nodeName, const char *code)
 create a PyNode object to execute remote python code More...
Engines::PyNode_ptr getDefaultPyNode (const char *nodeName)
 Retrieves the last created PyNode instance with createPyNode. More...
Engines::PyScriptNode_ptr createPyScriptNode (const char *nodeName, const char *code)
 create a PyScriptNode object to execute remote python code More...
void removePyScriptNode (const char *nodeName) override
void cleanAllPyScripts () override
Engines::PyScriptNode_ptr getDefaultPyScriptNode (const char *nodeName)
 Retrieves the last created PyScriptNode instance with createPyScriptNode. More...
Engines::EngineComponent_ptr find_or_create_instance (std::string genericRegisterName, std::string componentLibraryName)
 Finds an already existing component instance or create a new instance. More...
bool load_component_CppImplementation (const char *componentName, std::string &reason)
 try to load a C++ component implementation More...
bool load_component_PythonImplementation (const char *componentName, std::string &reason)
 try to load a Python component implementation More...
bool load_component_ExecutableImplementation (const char *componentName, std::string &reason)
 try to load a Executable component implementation More...
Engines::EngineComponent_ptr createPythonInstance (std::string CompName, std::string &error)
 Create a new component instance (Python implementation) More...
Engines::EngineComponent_ptr createExecutableInstance (std::string CompName, const Engines::FieldsDict &env, std::string &error)
 Create a new component instance (Executable implementation) More...
Engines::EngineComponent_ptr createInstance (std::string genericRegisterName, void *handle, std::string &error)
 Create a new component instance (C++ implementation) More...
int getArgc ()
char ** getArgv ()
void registerTemporaryFile (const std::string &fileName)
void unregisterTemporaryFile (const std::string &fileName)
void clearTemporaryFiles ()
PortableServer::ObjectId * getCORBAId () const
static bool isPythonContainer (const char *ContainerName)
 Indicate if container is a python one. More...
static void decInstanceCnt (std::string genericRegisterName)
 Decrement component instance reference count. More...
Static Public Attributes
static const int DFT_TIME_INTERVAL_BTW_MEASURE = 500
bool _isSupervContainer
SALOME_NamingService_Container_Abstract * _NS
std::string _library_path
std::string _containerName
std::string _logfilename
std::string _localfilename
std::string _load_script
std::string _py_container_name
std::string _code_at_startup
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
int _numInstance
std::map< std::string, Engines::EngineComponent_var > _listInstances_map
std::map< std::string, Engines::fileRef_var > _fileRef_map
std::map< std::string, Engines::Salome_file_var > _Salome_file_map
std::map< std::string, Engines::PyScriptNode_var > _dftPyScriptNode
std::map< std::string, Engines::PyNode_var > _dftPyNode
Utils_Mutex _mutexForDftPy
std::list< std::string > _tmp_files
Engines::fileTransfer_var _fileTransfer
std::vector< std::vector< std::string > > _groups_of_log_files
int _argc
char ** _argv
long _pid
bool _isServantAloneInProcess
Static Protected Attributes
static std::map< std::string, int > _cntInstances_map
static std::map< std::string, void * > _library_map
static std::map< std::string, void * > _toRemove_map
static omni_mutex _numInstanceMutex
void ShutdownCommonPart ()
◆ Abstract_Engines_Container_SSL_i()
Abstract_Engines_Container_SSL_i::Abstract_Engines_Container_SSL_i ( const std::string &  pyContainerClsName,
CORBA::ORB_ptr  orb,
char *  containerName,
int  argc,
char *  argv[],
SALOME_NamingService_Container_Abstract *  ns = nullptr,
bool  isServantAloneInProcess = true
◆ addLogFileNameGroup()
void Abstract_Engines_Container_i::addLogFileNameGroup ( const Engines::vectorOfString &  groupOfLogFileNames)
overrideinherited
◆ cleanAllPyScripts()
◆ clearTemporaryFiles()
void Abstract_Engines_Container_i::clearTemporaryFiles ( )
◆ copyFile()
void Abstract_Engines_Container_i::copyFile ( Engines::Container_ptr  container,
const char *  remoteFile,
const char *  localFile
containerthe remote container
remoteFilethe file to copy locally from the remote host into localFile
localFilethe local file
References TestComponentPy::container, and MESSAGE.
◆ create_component_instance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::create_component_instance ( const char *  genericRegisterName)
CORBA method: Creates a new servant instance of a component. The servant registers itself to naming service and Registry.tdlib
genericRegisterNameName of the component instance to register in Registry & Name Service (without _inst_n suffix)
a loaded component
References Abstract_Engines_Container_i::create_component_instance_env().
Referenced by SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::create_component_instance_env(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::create_python_service_instance().
◆ create_component_instance_env()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::create_component_instance_env ( const char *  genericRegisterName,
const Engines::FieldsDict &  env,
envdict of env variables
reasonexplains error when create_component_instance_env fails
a loaded component
Reimplemented in Engines_MPIContainer_i.
References Abstract_Engines_Container_i::_library_map, Abstract_Engines_Container_i::createExecutableInstance(), Abstract_Engines_Container_i::createInstance(), Abstract_Engines_Container_i::createPythonInstance(), ENGINESO, IDLparser::error(), and LIB.
Referenced by Abstract_Engines_Container_i::create_component_instance().
◆ create_python_service_instance()
char * Abstract_Engines_Container_i::create_python_service_instance ( const char *  CompName,
◆ createExecutableInstance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::createExecutableInstance ( std::string  CompName,
std::string &  reason
CompNameName of the component instance
reasonexplains error when creation fails
a loaded component
This component is implemented in an executable with name genericRegisterName.exe It must register itself in Naming Service. The container waits some time (10 s max) it's registration.
References Abstract_Engines_Container_i::_containerName, Abstract_Engines_Container_i::_listInstances_map, Abstract_Engines_Container_i::_NS, Abstract_Engines_Container_i::_numInstance, Abstract_Engines_Container_i::_numInstanceMutex, Abstract_Engines_Container_i::_orb, TestKernelHelpers::command, SALOME_NamingService_Container_Abstract::Destroy_Name(), EffectiveOverrideEnvironment(), MESSAGE, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService_Container_Abstract::Resolve(), and salomeContext::status.
Referenced by Abstract_Engines_Container_i::create_component_instance_env().
◆ createFileRef()
Engines::fileRef_ptr Abstract_Engines_Container_i::createFileRef ( const char *  origFileName)
CORBA method: get or create a fileRef object associated to a local file (a file on the computer on which runs the container server), which stores a list of (machine, localFileName) corresponding to copies already done.
origFileNameabsolute path for a local file to copy on other computers
a fileRef object associated to the file.
References Abstract_Engines_Container_i::_fileRef_map, Abstract_Engines_Container_i::_id, Abstract_Engines_Container_i::_numInstanceMutex, Abstract_Engines_Container_i::_poa, and KERNEL_PY.batchmode_salome::obj.
◆ createInstance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::createInstance ( std::string  genericRegisterName,
void *  handle,
C++ method: create a servant instance of a component.
genericRegisterNameName of the component instance to register in Registry & Name Service, (without _inst_n suffix, like "COMPONENT")
handleloaded library handle
a loaded component
example with names:
  • aGenRegisterName = COMPONENT (= first argument)
  • _containerName = /Containers/cli76ce/FactoryServer
  • factoryName = COMPONENTEngine_factory
  • component_registerBase = /Containers/cli76ce/FactoryServer/COMPONENT
  • instanceName = COMPONENT_inst_1
  • component_registerName = /Containers/cli76ce/FactoryServer/COMPONENT_inst_1
References Abstract_Engines_Container_i::_cntInstances_map, Abstract_Engines_Container_i::_containerName, Abstract_Engines_Container_i::_id, Abstract_Engines_Container_i::_listInstances_map, Abstract_Engines_Container_i::_NS, Abstract_Engines_Container_i::_numInstance, Abstract_Engines_Container_i::_numInstanceMutex, Abstract_Engines_Container_i::_orb, Abstract_Engines_Container_i::_poa, MESSAGE, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService_Container_Abstract::Register(), and SALOME_utilities::SCRUTE().
Referenced by Abstract_Engines_Container_i::create_component_instance_env(), and Abstract_Engines_Container_i::find_or_create_instance().
◆ createPyNode()
Engines::PyNode_ptr Abstract_Engines_Container_i::createPyNode ( const char *  nodeName,
const char *  code
nodeNamethe name of the node
codethe python code to load
the PyNode
References Abstract_Engines_Container_i::_dftPyNode, Abstract_Engines_Container_i::_mutexForDftPy, Abstract_Engines_Container_i::_orb, _pyCont, SALOME::INTERNAL_ERROR, KERNEL_PY.batchmode_salome::obj, test::res, SALOME::ExceptionStruct::text, and SALOME::ExceptionStruct::type.
◆ createPyScriptNode()
Engines::PyScriptNode_ptr Abstract_Engines_Container_i::createPyScriptNode ( const char *  nodeName,
const char *  code
◆ createPythonInstance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::createPythonInstance ( std::string  CompName,
◆ createSalome_file()
Engines::Salome_file_ptr Abstract_Engines_Container_i::createSalome_file ( const char *  origFileName)
◆ decInstanceCnt()
◆ execute_python_code()
void Abstract_Engines_Container_i::execute_python_code ( const char *  code)
overrideinherited
◆ finalize_removal()
void Abstract_Engines_Container_i::finalize_removal ( )
CORBA method: Discharges unused libraries from the container.
References Abstract_Engines_Container_i::_numInstanceMutex, Abstract_Engines_Container_i::_toRemove_map, MESSAGE, and SALOME_utilities::SCRUTE().
◆ find_component_instance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::find_component_instance ( const char *  registeredName)
CORBA method: Finds a servant instance of a component
registeredNameName of the component in Registry or Name Service, without instance suffix number
the first found instance
References Abstract_Engines_Container_i::_listInstances_map, and SALOME_utilities::SCRUTE().
◆ find_or_create_instance()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::find_or_create_instance ( std::string  genericRegisterName,
C++ method: Finds an already existing servant instance of a component, or create an instance. -— USE ONLY FOR MULTISTUDY INSTANCES ! -----—
componentLibraryNamelike "libCOMPONENTEngine.so"
a loaded component
example with names:
  • impl_name = libCOMPONENTEngine.so (= second argument)
References Abstract_Engines_Container_i::_containerName, Abstract_Engines_Container_i::_library_map, Abstract_Engines_Container_i::_NS, Abstract_Engines_Container_i::createInstance(), KERNEL_PY.batchmode_salome::obj, and SALOME_NamingService_Container_Abstract::ResolveFirst().
Referenced by Abstract_Engines_Container_i::load_impl().
◆ get_embedded_NS_if_ssl()
Engines::EmbeddedNamingService_ptr Abstract_Engines_Container_i::get_embedded_NS_if_ssl ( )
overrideinherited
◆ get_os_environment()
Engines::FieldsDict * Abstract_Engines_Container_i::get_os_environment ( )
overrideinherited
◆ get_startup_code()
char * Abstract_Engines_Container_i::get_startup_code ( )
overrideinherited
◆ getAllLogFileNameGroups()
Engines::vectorOfVectorOfString * Abstract_Engines_Container_i::getAllLogFileNameGroups ( )
overrideinherited
◆ getArgc()
int Abstract_Engines_Container_i::getArgc ( )
◆ getArgv()
char ** Abstract_Engines_Container_i::getArgv ( )
◆ getCORBAId()
PortableServer::ObjectId * Abstract_Engines_Container_i::getCORBAId ( ) const
Referenced by KERNEL::getContainerSA().
◆ getDefaultPyNode()
Engines::PyNode_ptr Abstract_Engines_Container_i::getDefaultPyNode ( const char *  nodeName)
References Abstract_Engines_Container_i::_dftPyNode, and Abstract_Engines_Container_i::_mutexForDftPy.
◆ getDefaultPyScriptNode()
Engines::PyScriptNode_ptr Abstract_Engines_Container_i::getDefaultPyScriptNode ( const char *  nodeName)
References Abstract_Engines_Container_i::_dftPyScriptNode, and Abstract_Engines_Container_i::_mutexForDftPy.
◆ getFileTransfer()
Engines::fileTransfer_ptr Abstract_Engines_Container_i::getFileTransfer ( )
CORBA method:
a reference to the fileTransfer object
References Abstract_Engines_Container_i::_fileTransfer.
◆ getHostName()
char * Abstract_Engines_Container_i::getHostName ( )
CORBA method: Get the hostName of the Container (without domain extensions)
References Utils_Identity::s.
◆ getNS()
SALOME_NamingService_Container_Abstract * Abstract_Engines_Container_i::getNS ( ) const
◆ getNumberOfCPUCores()
CORBA::Long Abstract_Engines_Container_i::getNumberOfCPUCores ( )
CORBA method: get number of CPU cores
Referenced by Abstract_Engines_Container_i::loadOfCPUCores().
◆ getPID()
CORBA::Long Abstract_Engines_Container_i::getPID ( )
Get container PID.
CORBA method: Get the PID (process identification) of the Container
◆ getPyContainerClassName()
std::string Abstract_Engines_Container_i::getPyContainerClassName ( ) const
◆ getTotalPhysicalMemory()
CORBA::Long Abstract_Engines_Container_i::getTotalPhysicalMemory ( )
CORBA method: get total physical memory of calculation node
◆ getTotalPhysicalMemoryInUse()
CORBA::Long Abstract_Engines_Container_i::getTotalPhysicalMemoryInUse ( )
CORBA method: get used physical memory of calculation node
◆ getTotalPhysicalMemoryInUseByMe()
CORBA::Long Abstract_Engines_Container_i::getTotalPhysicalMemoryInUseByMe ( )
CORBA method: get physical memory, used by the current process
◆ is_SSL_mode()
bool Abstract_Engines_Container_i::is_SSL_mode ( )
overrideinherited
◆ isPythonContainer()
bool Abstract_Engines_Container_i::isPythonContainer ( const char *  ContainerName)
Retrieves only with container naming convention if it is a python container
References TestKernelHelpers::ret.
◆ isSSLMode()
bool Abstract_Engines_Container_SSL_i::isSSLMode ( ) const
overridevirtual
◆ Kill_impl()
bool Abstract_Engines_Container_i::Kill_impl ( )
Kill the container.
CORBA method: Kill the container process with exit(0). To remove : never returns !
References Abstract_Engines_Container_i::_containerName, and MESSAGE.
◆ load_component_CppImplementation()
bool Abstract_Engines_Container_i::load_component_CppImplementation ( const char *  componentName,
C++ method:
componentNamethe name of the component (COMPONENT, for example)
reasonexplains error when load fails
true if loading is successful or already done, false otherwise
References Abstract_Engines_Container_i::_library_map, Abstract_Engines_Container_i::_numInstanceMutex, Abstract_Engines_Container_i::_toRemove_map, ENGINESO, findpathof(), LIB, MESSAGE, ORBConfigFile::path, SALOME_utilities::SCRUTE(), and SEP.
Referenced by Abstract_Engines_Container_i::load_component_Library().
◆ load_component_ExecutableImplementation()
bool Abstract_Engines_Container_i::load_component_ExecutableImplementation ( const char *  componentName,
C++ method:
componentNamename of the component
References Abstract_Engines_Container_i::_library_map, Abstract_Engines_Container_i::_numInstanceMutex, checkifexecutable(), findpathof(), MESSAGE, and ORBConfigFile::path.
◆ load_component_Library()
bool Abstract_Engines_Container_i::load_component_Library ( const char *  componentName,
CORBA method
componentNamecomponent name
true if dlopen successful or already done, false otherwise
References ENGINESO, LIB, Abstract_Engines_Container_i::load_component_CppImplementation(), Abstract_Engines_Container_i::load_component_ExecutableImplementation(), Abstract_Engines_Container_i::load_component_PythonImplementation(), and TestKernelHelpers::ret.
◆ load_component_PythonImplementation()
bool Abstract_Engines_Container_i::load_component_PythonImplementation ( const char *  componentName,
C++ method:
References Abstract_Engines_Container_i::_library_map, Abstract_Engines_Container_i::_numInstanceMutex, _pyCont, MESSAGE, and SALOME_utilities::SCRUTE().
◆ load_impl()
Engines::EngineComponent_ptr Abstract_Engines_Container_i::load_impl ( const char *  genericRegisterName,
CORBA method: find or create an instance of the component (servant), load a new component class (dynamic library) if required,
-— FOR COMPATIBILITY WITH 2.2 -—
genericRegisterNameName of the component to register in Registry & Name Service
componentNameName of the constructed library of the component
a loaded component
References ENGINESO, Abstract_Engines_Container_i::find_or_create_instance(), LIB, and Abstract_Engines_Container_i::load_component_Library().
Referenced by Engines_MPIContainer_i::Lload_impl().
◆ loadOfCPUCores()
◆ locallogfilename() [1/2]
char * Abstract_Engines_Container_i::locallogfilename ( )
overrideinherited
◆ locallogfilename() [2/2]
void Abstract_Engines_Container_i::locallogfilename ( const char *  name)
overrideinherited
◆ logfilename() [1/2]
char * Abstract_Engines_Container_i::logfilename ( )
overrideinherited
CORBA attribute: Container log file name
References Abstract_Engines_Container_i::_logfilename.
◆ logfilename() [2/2]
void Abstract_Engines_Container_i::logfilename ( const char *  name)
overrideinherited
◆ monitoringtimeresms() [1/2]
CORBA::Long Abstract_Engines_Container_i::monitoringtimeresms ( )
overrideinherited
◆ monitoringtimeresms() [2/2]
void Abstract_Engines_Container_i::monitoringtimeresms ( CORBA::Long  intervalInMs)
overrideinherited
◆ override_environment()
void Abstract_Engines_Container_i::override_environment ( const Engines::FieldsDict &  env)
overrideinherited
◆ override_environment_python()
void Abstract_Engines_Container_i::override_environment_python ( const Engines::FieldsDict &  env)
overrideinherited
◆ ping()
void Abstract_Engines_Container_i::ping ( )
CORBA method: check if servant is still alive
References MESSAGE.
◆ registerTemporaryFile()
void Abstract_Engines_Container_i::registerTemporaryFile ( const std::string &  fileName)
◆ remove_impl()
void Abstract_Engines_Container_i::remove_impl ( Engines::EngineComponent_ptr  component_i)
CORBA method: Stops the component servant, and deletes all related objects
component_iComponent to be removed
References Abstract_Engines_Container_i::_listInstances_map, Abstract_Engines_Container_i::_NS, Abstract_Engines_Container_i::_numInstanceMutex, SALOME_NamingService_Container_Abstract::Destroy_Name(), and MESSAGE.
◆ removePyScriptNode()
void Abstract_Engines_Container_i::removePyScriptNode ( const char *  nodeName)
overrideinherited
◆ resetScriptForCPULoad()
void Abstract_Engines_Container_i::resetScriptForCPULoad ( )
CORBA method: reset script for load calculation to default implementation
References Abstract_Engines_Container_i::_load_script.
◆ set_big_obj_on_disk_directory()
void Abstract_Engines_Container_i::set_big_obj_on_disk_directory ( const char *  directory)
overrideinherited
◆ set_big_obj_on_disk_threshold()
void Abstract_Engines_Container_i::set_big_obj_on_disk_threshold ( CORBA::Long  thresholdInByte)
overrideinherited
◆ set_current_directory()
void Abstract_Engines_Container_i::set_current_directory ( const char *  cwd)
overrideinherited
◆ set_directory_for_replay_files()
void Abstract_Engines_Container_i::set_directory_for_replay_files ( const char *  directory)
overrideinherited
◆ set_number_of_retry()
void Abstract_Engines_Container_i::set_number_of_retry ( CORBA::Long  nbRetry)
overrideinherited
◆ set_startup_code()
void Abstract_Engines_Container_i::set_startup_code ( const char *  codeAtStartUp)
overrideinherited
◆ set_timeout_before_retrying()
void Abstract_Engines_Container_i::set_timeout_before_retrying ( CORBA::Long  timeInSecond)
overrideinherited
◆ setPyScriptForCPULoad()
void Abstract_Engines_Container_i::setPyScriptForCPULoad ( const char *  script)
CORBA method: Set custom script to calculate CPU load
scriptPython script to execute
◆ setVerbosity()
void Abstract_Engines_Container_i::setVerbosity ( bool  activated,
const char *  level
overrideinherited
◆ Shutdown()
void Abstract_Engines_Container_i::Shutdown ( )
overrideinherited
CORBA method, oneway: Server shutdown.
  • Container name removed from naming service,
  • servant deactivation,
  • orb shutdown if no other servants in the process
References Abstract_Engines_Container_i::_isServantAloneInProcess, Abstract_Engines_Container_i::_orb, MESSAGE, and Abstract_Engines_Container_i::ShutdownCommonPart().
◆ ShutdownCommonPart()
◆ ShutdownNow()
void Abstract_Engines_Container_i::ShutdownNow ( )
overrideinherited
◆ unregisterTemporaryFile()
void Abstract_Engines_Container_i::unregisterTemporaryFile ( const std::string &  fileName)
◆ verbosity()
void Abstract_Engines_Container_i::verbosity ( bool &  activated,
overrideinherited
◆ workingdir()
char * Abstract_Engines_Container_i::workingdir ( )
CORBA attribute: Container working directory
◆ _argc
int Abstract_Engines_Container_i::_argc
◆ _argv
char** Abstract_Engines_Container_i::_argv
◆ _cntInstances_map
std::map< std::string, int > Abstract_Engines_Container_i::_cntInstances_map
staticprotectedinherited
◆ _code_at_startup
std::string Abstract_Engines_Container_i::_code_at_startup
◆ _containerName
◆ _dftPyNode
std::map<std::string, Engines::PyNode_var> Abstract_Engines_Container_i::_dftPyNode
◆ _dftPyScriptNode
std::map<std::string, Engines::PyScriptNode_var> Abstract_Engines_Container_i::_dftPyScriptNode
◆ _fileRef_map
std::map<std::string, Engines::fileRef_var> Abstract_Engines_Container_i::_fileRef_map
◆ _fileTransfer
Engines::fileTransfer_var Abstract_Engines_Container_i::_fileTransfer
◆ _groups_of_log_files
std::vector< std::vector<std::string> > Abstract_Engines_Container_i::_groups_of_log_files
◆ _id
◆ _isServantAloneInProcess
bool Abstract_Engines_Container_i::_isServantAloneInProcess
◆ _isSupervContainer
◆ _library_map
◆ _library_path
std::string Abstract_Engines_Container_i::_library_path
◆ _listInstances_map
◆ _load_script
◆ _localfilename
std::string Abstract_Engines_Container_i::_localfilename
◆ _logfilename
std::string Abstract_Engines_Container_i::_logfilename
◆ _mutexForDftPy
◆ _NS
◆ _numInstance
◆ _numInstanceMutex
◆ _orb
◆ _pid
long Abstract_Engines_Container_i::_pid
◆ _poa
◆ _py_container_name
std::string Abstract_Engines_Container_i::_py_container_name
◆ _Salome_file_map
std::map<std::string, Engines::Salome_file_var> Abstract_Engines_Container_i::_Salome_file_map
◆ _tmp_files
std::list<std::string> Abstract_Engines_Container_i::_tmp_files
◆ _toRemove_map
◆ DFT_TIME_INTERVAL_BTW_MEASURE
const int Abstract_Engines_Container_i::DFT_TIME_INTERVAL_BTW_MEASURE = 500
