SALOME_ResourcesManager.idl
23#ifndef _SALOME_RESOURCESMANAGER_IDL_
24#define _SALOME_RESOURCESMANAGER_IDL_
26#include "SALOME_Exception.idl"
27
31module Engines
32{
33
35typedef sequence<string> ResourceList;
37typedef sequence<string> CompoList;
38typedef sequence<long> IntegerList;
39
42{
44
48 string name;
49
51 string hostname;
57 string OS;
59
61
62 // Permits to order resources
64
67 long nb_proc;
68
70
89 long mem_mb;
93 long nb_node;
96
97 // Permits to configure SALOME resource management
99 string policy;
102};
103
106{
108 string name;
110 string hostname;
112 string type;
118 string protocol;
120 string username;
122 string applipath;
126
128 string OS;
130 long mem_mb;
138 string batch;
140 string mpiImpl;
143 string iprotocol;
144
149
152};
153
159{
161 string FindFirst(in ResourceList possibleResources);
162
164 string Find(in string policy, in ResourceList possibleResources);
165
167
171
174
176
181 void AddResource(in ResourceDefinition new_resource, in boolean write, in string xml_file)
183
185
190 void RemoveResource(in string resource_name, in boolean write, in string xml_file)
192
194 string getMachineFile(in string resource_name, in long nb_procs, in string parallelLib)
196
199
201
202 ResourceList ListAllResourceEntriesInCatalog() raises (SALOME::SALOME_Exception);
203};
204
205};
206
207#endif
static std::ostream * out
Definition: DSC_interface.cxx:381
This file contains the objects defining the main exception used in SALOME application.
Interface of the resourcesManager This interface is used for interaction with the unique instance of ...
Definition: SALOME_ResourcesManager.idl:159
Add a new resource to the resource_manager.
Create a machine file for PaCO container.
void ListAllAvailableResources(out ResourceList machines, out IntegerList nbProcsOfMachines)
Return list of resources available (regarding content of CatalogResources.xml). And for each resource...
Find best available computer according to policy in a computers list.
Find first available resource in a resources list.
Remove a new resource to the resource_manager.
ResourceList ListAllResourcesInCatalog()
ResourceList GetFittingResources(in ResourceParameters params)
Get a list of resources that are best suited to launch a container given constraints.
ResourceDefinition GetResourceDefinition(in string name)
Get definition of a resource.
sequence< string > ResourceList
Type to transmit list of resources.
Definition: SALOME_ResourcesManager.idl:35
sequence< string > CompoList
components list
Definition: SALOME_ResourcesManager.idl:37
sequence< long > IntegerList
Definition: SALOME_ResourcesManager.idl:38
string name
Definition: pythfilter.py:56
Type to describe a resource.
Definition: SALOME_ResourcesManager.idl:106
string hostname
hostname
Definition: SALOME_ResourcesManager.idl:110
string iprotocol
if the resource is a cluster: internal protocol to use to start a remote container (ssh or rsh) on th...
Definition: SALOME_ResourcesManager.idl:143
string protocol
protocol to connect to the resource and to start a remote container Possible values: "rsh" : uses rsh...
Definition: SALOME_ResourcesManager.idl:118
boolean can_run_containers
Specify if the resource can run containers.
Definition: SALOME_ResourcesManager.idl:148
string batch
batch system
Definition: SALOME_ResourcesManager.idl:138
long mem_mb
memory size per node
Definition: SALOME_ResourcesManager.idl:130
long nb_node
number of node
Definition: SALOME_ResourcesManager.idl:134
string OS
operating system
Definition: SALOME_ResourcesManager.idl:128
string mpiImpl
MPI implementation.
Definition: SALOME_ResourcesManager.idl:140
long nb_proc_per_node
number of proc per node
Definition: SALOME_ResourcesManager.idl:136
string name
name
Definition: SALOME_ResourcesManager.idl:108
string type
Type of the resource ("cluster" or "single_machine")
Definition: SALOME_ResourcesManager.idl:112
long cpu_clock
frequency
Definition: SALOME_ResourcesManager.idl:132
CompoList componentList
list of available components.
Definition: SALOME_ResourcesManager.idl:125
string applipath
salome application to use to start a remote container
Definition: SALOME_ResourcesManager.idl:122
string working_directory
Predefined working directory on the resource.
Definition: SALOME_ResourcesManager.idl:151
boolean can_launch_batch_jobs
Specify if the resource can launch batch jobs.
Definition: SALOME_ResourcesManager.idl:146
string username
login name to use to start a remote container
Definition: SALOME_ResourcesManager.idl:120
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
long nb_proc
required number of processors
Definition: SALOME_ResourcesManager.idl:67
string name
resource name - manual selection
Definition: SALOME_ResourcesManager.idl:48
required number of proc per node
Definition: SALOME_ResourcesManager.idl:95
long mem_mb
required memory size
Definition: SALOME_ResourcesManager.idl:89
ResourceList resList
restricted list of resources to search in
Definition: SALOME_ResourcesManager.idl:101
if given, list of components that could be loaded on a container.
Definition: SALOME_ResourcesManager.idl:60
string hostname
host name
Definition: SALOME_ResourcesManager.idl:51
if true select only resources that can launch batch jobs
Definition: SALOME_ResourcesManager.idl:53
long cpu_clock
required frequency
Definition: SALOME_ResourcesManager.idl:91
if true select only resources that can run containers
Definition: SALOME_ResourcesManager.idl:55
long nb_node
required number of nodes. Can be used when submitting slurm jobs.
Definition: SALOME_ResourcesManager.idl:93
string OS
if given required operating system
Definition: SALOME_ResourcesManager.idl:57
string policy
resource management policy : first, cycl, altcycl or best (can be extended)
Definition: SALOME_ResourcesManager.idl:99
