Engines::ResourcesManager Interface Reference
Interface of the resourcesManager This interface is used for interaction with the unique instance of ResourcesManager. More...
import"SALOME_ResourcesManager.idl";
string FindFirst (in ResourceList possibleResources)
 Find first available resource in a resources list. More...
string Find (in string policy, in ResourceList possibleResources)
 Find best available computer according to policy in a computers list. More...
ResourceList GetFittingResources (in ResourceParameters params) raises (SALOME::SALOME_Exception)
 Get a list of resources that are best suited to launch a container given constraints. More...
ResourceDefinition GetResourceDefinition (in string name) raises (SALOME::SALOME_Exception)
 Get definition of a resource. More...
void AddResource (in ResourceDefinition new_resource, in boolean write, in string xml_file) raises (SALOME::SALOME_Exception)
 Add a new resource to the resource_manager. More...
void RemoveResource (in string resource_name, in boolean write, in string xml_file) raises (SALOME::SALOME_Exception)
 Remove a new resource to the resource_manager. More...
string getMachineFile (in string resource_name, in long nb_procs, in string parallelLib) raises (SALOME::SALOME_Exception)
 Create a machine file for PaCO container. More...
void ListAllAvailableResources (out ResourceList machines, out IntegerList nbProcsOfMachines) raises (SALOME::SALOME_Exception)
 Return list of resources available (regarding content of CatalogResources.xml). And for each resource the number of proc available of it. More...
ResourceList ListAllResourcesInCatalog () raises (SALOME::SALOME_Exception)
ResourceList ListAllResourceEntriesInCatalog () raises (SALOME::SALOME_Exception)
◆ AddResource()
void Engines::ResourcesManager::AddResource ( in ResourceDefinition  new_resource,
in boolean  write,
in string  xml_file
write -> true, resource manager will add it into a xml_file xml_file -> could be empty, in this case if write is true, resource manager will write the resource in its first ResourceCatalog file
◆ Find()
string Engines::ResourcesManager::Find ( in string  policy,
◆ FindFirst()
string Engines::ResourcesManager::FindFirst ( in ResourceList  possibleResources)
◆ GetFittingResources()
ResourceList Engines::ResourcesManager::GetFittingResources ( in ResourceParameters  params)
The constraints are resource constraints (params) and components constraints (componentList)
◆ getMachineFile()
string Engines::ResourcesManager::getMachineFile ( in string  resource_name,
in long  nb_procs,
◆ GetResourceDefinition()
ResourceDefinition Engines::ResourcesManager::GetResourceDefinition ( in string  name)
◆ ListAllAvailableResources()
void Engines::ResourcesManager::ListAllAvailableResources ( out ResourceList  machines,
◆ ListAllResourceEntriesInCatalog()
ResourceList Engines::ResourcesManager::ListAllResourceEntriesInCatalog ( )
◆ ListAllResourcesInCatalog()
ResourceList Engines::ResourcesManager::ListAllResourcesInCatalog ( )
◆ RemoveResource()
void Engines::ResourcesManager::RemoveResource ( in string  resource_name,
in boolean  write,
in string  xml_file
write -> true, resource manager will write a new xml_file xml_file -> could be empty, in this case if write is true, resource manager will write the resource in its first ResourceCatalog file
