DSC_Engines.idl File Reference
interfaces that permits to add a dynamic port model to the SALOME object model. More...
Include dependency graph for DSC_Engines.idl:
interface  Engines::DSC
 Interface of a DSC component. More...
exception  Engines::DSC::PortNotDefined
 This exception is raised when a port is used before it is added to the component. More...
exception  Engines::DSC::PortAlreadyDefined
 This exception is raised if you try to add a port with the same name than a previous defined port. More...
exception  Engines::DSC::PortNotConnected
 This exception is raised when you try to use a port that is not connected. More...
exception  Engines::DSC::BadPortType
 This exception is raised if the type of the provides port is bad. More...
exception  Engines::DSC::NilPort
 Port's reference is Nil ! More...
exception  Engines::DSC::BadPortReference
 Port's reference is not the right reference. More...
exception  Engines::DSC::BadProperty
 Object property is not good for the port. More...
interface  Engines::ConnectionManager
 Interface of the ConnectionManager. More...
exception  Engines::ConnectionManager::BadId
 The Id given to the disconnect method is bad. More...
interface  Engines::Superv_Component
 Interface of the Superv_Component. More...
struct  Engines::Superv_Component::multiple_param
Modules
module  Engines
