SALOME_Ports.idl
23// File : SALOME_Ports.idl
24// Author : Andre RIBES, EDF
25//
26#ifndef _SALOME_PORTS_IDL_
27#define _SALOME_PORTS_IDL_
28
36module Ports {
37
42 interface Port {};
43
51 interface Control_Port : Ports::Port {};
52
63 interface Data_Port : Ports::Port {};
64
72
74 exception NotDefined {};
75
77 exception BadType {};
78
80 exception BadValue {};
81
87 interface PortProperties {
88
90
98 void set_property(in string name, in any value) raises (Ports::BadType,
101
103
110 any get_property(in string name) raises (Ports::NotDefined);
111 };
112
120 void put(in short data);
121 };
122};
123
124#endif
This exception indicates that the given value to the property is not of a good type.
Definition: SALOME_Ports.idl:77
This exception indicates that the given value to the property is not authorized.
Definition: SALOME_Ports.idl:80
This exception indicates that the property doesn't not exist.
Definition: SALOME_Ports.idl:74
Interface of a Control_Port.
Definition: SALOME_Ports.idl:51
Data_And_Control_Port.
Definition: SALOME_Ports.idl:71
Interface a Data_Port.
Definition: SALOME_Ports.idl:63
Interface of a basic datastream short port This interface defines a Data_Port that transmit a CORBA::...
Definition: SALOME_Ports.idl:118
this operation can be used by a uses port to send me a short
Interface of a PortProperties.
Definition: SALOME_Ports.idl:87
This operation permits to set a value of a property.
This operation permits to get property's value.
Interface of a DSC Port.
Definition: SALOME_Ports.idl:42
module that contains interfaces to define the kind of ports provided by the SALOME component model.
Definition: Palm_Ports.idl:35
string name
Definition: pythfilter.py:56
