SALOME_PyNode.idl
20// File : SALOME_PyNode.idl
21// Author : Christian CAREMOLI, EDF
22// $Header:
23//
24#ifndef _SALOME_PYNODE_IDL_
25#define _SALOME_PYNODE_IDL_
26
27#include "SALOME_GenericObj.idl"
28#include "SALOME_Exception.idl"
29#include "SALOME_Comm.idl"
30
37module Engines
38{
39 typedef sequence<octet> pickledArgs;
40 typedef sequence<string> listofstring;
41 interface Container;
42
44 {
46
47 string getCode();
48
49 string getName();
50
55 void defineNewCustomVar(in string varName, in pickledArgs valueOfVar) raises (SALOME::SALOME_Exception);
56
61 void executeAnotherPieceOfCode(in string codeStr) raises (SALOME::SALOME_Exception);
62 };
63
64 interface PyNode : PyNodeBase
65 {
72 pickledArgs execute(in string functionName, in pickledArgs inargs) raises (SALOME::SALOME_Exception);
73
74 };
75
77 {
83 void assignNewCompiledCode(in string codeStr) raises (SALOME::SALOME_Exception);
84
92
94
98
102
104
106
108
110
111 void removeAllVarsInContext() raises (SALOME::SALOME_Exception);
112 } ;
113
115 {
117 void pushOutputContext( in pickledArgs ctx ) raises (SALOME::SALOME_Exception);
118 void finishPushContext() raises (SALOME::SALOME_Exception);
119 };
120
122 {
126 void setAttr(in string ctx, in pickledArgs glbsAttachedToCtx) raises (SALOME::SALOME_Exception);
128 void execute(in listofstring args, out long returnCode, out pickledArgs standardOutput, out pickledArgs standardError) raises (SALOME::SALOME_Exception);
129 };
130};
131
132#endif
static std::ostream * out
Definition: DSC_interface.cxx:381
This file contains a set of interfaces used for communication between components.
This file contains the objects defining the main exception used in SALOME application.
interface for common behavior of SALOME transient CORBA objects
Interface of the Container.
Definition: SALOME_Component.idl:81
Definition: SALOME_PyNode.idl:115
SALOME::SenderByte getInputContext()
Definition: SALOME_PyNode.idl:122
pickledArgs getAttr(in string ctx)
Simply a key / val holder.
Definition: SALOME_PyNode.idl:44
Container getContainer()
This method executes the python code in codeStr and can append/remove symboles in context to make the...
This method allows to define a new global var called varName.
Definition: SALOME_PyNode.idl:65
execute a python function defined in the node
Definition: SALOME_PyNode.idl:77
void assignVarInContext(in string varName, in pickledArgs value)
void executeFirst(in SALOME::SenderByte inargs)
first part of whole execute method.
void executeSimple(in listofstring key, in listofstring val)
pickledArgs getValueOfVarInContext(in string varName)
pickledArgs callMethodOnVarInContext(in string varName, in string methodName, in pickledArgs args)
SALOME::SenderByteSeq executeSecond(in listofstring outargsname)
second and last part of execute method.
pickledArgs execute(in listofstring outargsname, in pickledArgs inargs)
execute a python script defined in the node
This method compiles, but NOT EXECUTE, the code codeStr.
listofstring listAllVarsInContext()
Definition: SALOME_GenericObj.idl:40
Definition: SALOME_Comm.idl:140
sequence< octet > pickledArgs
Definition: SALOME_PyNode.idl:39
sequence< string > listofstring
Definition: SALOME_PyNode.idl:40
sequence< SenderByte > SenderByteSeq
Definition: SALOME_Comm.idl:145
string varName
Definition: TestSalomeSDSHelper0.py:25
args
Definition: pythfilter.py:547
