Engines::PyScriptNode Interface Reference
import"SALOME_PyNode.idl";
Inheritance diagram for Engines::PyScriptNode:
void assignNewCompiledCode (in string codeStr) raises (SALOME::SALOME_Exception)
 This method compiles, but NOT EXECUTE, the code codeStr. More...
pickledArgs execute (in listofstring outargsname, in pickledArgs inargs) raises (SALOME::SALOME_Exception)
 execute a python script defined in the node More...
void executeSimple (in listofstring key, in listofstring val) raises (SALOME::SALOME_Exception)
void executeFirst (in SALOME::SenderByte inargs) raises (SALOME::SALOME_Exception)
 first part of whole execute method. More...
SALOME::SenderByteSeq executeSecond (in listofstring outargsname) raises (SALOME::SALOME_Exception)
 second and last part of execute method. More...
pickledArgs getValueOfVarInContext (in string varName) raises (SALOME::SALOME_Exception)
void assignVarInContext (in string varName, in pickledArgs value) raises (SALOME::SALOME_Exception)
pickledArgs callMethodOnVarInContext (in string varName, in string methodName, in pickledArgs args) raises (SALOME::SALOME_Exception)
listofstring listAllVarsInContext () raises (SALOME::SALOME_Exception)
void removeAllVarsInContext () raises (SALOME::SALOME_Exception)
Container getContainer ()
string getCode ()
string getName ()
void defineNewCustomVar (in string varName, in pickledArgs valueOfVar) raises (SALOME::SALOME_Exception)
 This method allows to define a new global var called varName. More...
void executeAnotherPieceOfCode (in string codeStr) raises (SALOME::SALOME_Exception)
 This method executes the python code in codeStr and can append/remove symboles in context to make them available or not for future call of execute on this. More...
void Register ()
void UnRegister ()
void Destroy ()
◆ assignNewCompiledCode()
void Engines::PyScriptNode::assignNewCompiledCode ( in string  codeStr)
The result of the compiled code will be used then on execute step.
codeStr- the python code (without statement) to be executed, that can modify the context initialized at initialization.
◆ assignVarInContext()
void Engines::PyScriptNode::assignVarInContext ( in string  varName,
◆ callMethodOnVarInContext()
pickledArgs Engines::PyScriptNode::callMethodOnVarInContext ( in string  varName,
in pickledArgs  args
◆ defineNewCustomVar()
void Engines::PyNodeBase::defineNewCustomVar ( in string  varName,
This newly created var will be set to value valueOfVar.
◆ Destroy()
Use UnRegister() instead.
◆ execute()
pickledArgs Engines::PyScriptNode::execute ( in listofstring  outargsname,
outargsnameoutput argument names
inargsinput argument values (dict) provided as a python pickle
output argument values (tuple) as a python pickle
Referenced by KERNEL_PY.salome_pynode.SmartPyNode::__getattr__().
◆ executeAnotherPieceOfCode()
void Engines::PyNodeBase::executeAnotherPieceOfCode ( in string  codeStr)
[in]codeStr- the python code (without statement) to be executed, that can modify the context initialized at initialization.
◆ executeFirst()
void Engines::PyScriptNode::executeFirst ( in SALOME::SenderByte  inargs)
This split is to reduce the memory peak.
◆ executeSecond()
SALOME::SenderByteSeq Engines::PyScriptNode::executeSecond ( in listofstring  outargsname)
◆ executeSimple()
void Engines::PyScriptNode::executeSimple ( in listofstring  key,
in listofstring  val
◆ getCode()
string Engines::PyNodeBase::getCode ( )
◆ getContainer()
◆ getName()
string Engines::PyNodeBase::getName ( )
◆ getValueOfVarInContext()
pickledArgs Engines::PyScriptNode::getValueOfVarInContext ( in string  varName)
◆ listAllVarsInContext()
listofstring Engines::PyScriptNode::listAllVarsInContext ( )
◆ Register()
◆ removeAllVarsInContext()
void Engines::PyScriptNode::removeAllVarsInContext ( )
◆ UnRegister()
